11th May 2015, 08:21 | #2062 | Link | |
11th May 2015, 08:36 | #2063 | Link | |
BTW, since you mentioned NNEDI3: I think MPDN is in violation, too. The OpenCL kernel is LGPL, but the weight database is GPL. SEt wrote a "new" kernel, so he probably had the right to license it under LGPL (and I'm happy that he did), but he didn't recreate the weights, so the weights are still part of the original NNEDI3 package, which is GPL. Nobody can recreate the weights because that part of NNEDI3 was never published, not even under GPL, AFAIK. tritical has explicitly allowed me to use the weights in closed source madVR. Has he allowed that for MPDN, too? |
11th May 2015, 09:12 | #2064 | Link |
Suptitle, MediaPlayer.NET
Uh, you do understand what GPL is, don't you? They cover source code, not data files. And the weights are freely available on GitHub from Avisynth plugin source. Unless Tritical makes specific mention of the use of the trained datasets, I'm not sure how you could claim it cannot be used.
11th May 2015, 10:03 | #2067 | Link |
The GPL says: "“The Program” refers to any copyrightable work licensed under this License". I see no limitation to source code. E.g. there are also icons available under GPL (e.g. http://genericons.com). From what I can see, tritical has released the whole NNEDI3 package under GPL, which AFAICS would include the weights. See here:
http://bengal.missouri.edu/~kes25c/ You do understand that the weights are the very core of the NNEDI3 algorithm? The kernel we're using is just a small part of NNEDI3. The weights are where all the magic comes from. Without the weights the kernel is just an empty shell. And whether or not something is "freely available" on some website has no effect on licenses - unless tritical has officially changed his license on that website. Anyway, I'm out of here. I wouldn't have said anything about your use of the NNEDI3 weights. But since you seemed so interested in clearing up any NNEDI3 related legal issues, I thought I'd mention this potential issue, too... |
11th May 2015, 11:40 | #2068 | Link | |
MPDN Extensions Dev
GPLv2 is a very restrictive license asking the developer that use a GPL lib/source code to be GPL also. In other word, if SEt used even a fraction of the code of NNEDI3, he can't release it as LGPL but must use the same license (since you can only go to more and more restrictive). This is were the first mistake was done. Again, this my understanding of the way the license work, it can be wrong, and I'd be happy to be corrected. NNEDI Orignal : http://forum.doom9.org/showthread.php?t=147695 OpenCL SEt : http://forum.doom9.org/showthread.php?t=169766 License compatibility : https://en.wikipedia.org/wiki/GNU_Ge...ulti-licensing |
11th May 2015, 11:40 | #2069 | Link | ||||
Thanks for bringing that to my attention. I am very serious about licensing issues, especially when it comes to free software as I fully believe all credits should always be given to the rightful owners.
However, I'll quote SEt and my believe is in line with his. Quote:
The weights we're using for MPDN extensions (see note1) are similar to SEt's preprocessed ones. They came from tritical's bin file. While the whole package is GPL, SEt chose to not open source the coefficients and it is his believes that it does not fall under GPL. MPDN extensions have not put any explicit licenses on it so it falls under the default license which is LGPL. This can be changed though and MPDN extension's NNEDI3 would simply be GPL. note1: MPDN is render script agnostic - in fact, MPDN does not come distributed with MPDN extensions. This is no different from a user using AviSynth (GPL) and have madVR (closed source) render the frames served. Or the fact that madVR users can use MPC-HC's pixel shader filters. However, the issue still remains that you can't claim the files you have are under LGPL license when in fact you have not adhered to the licensing terms. This applies for madVR's NNEDI3 code, which as you've said, Quote:
I'm just trying to make sure everyone respects free software licenses. |
11th May 2015, 11:52 | #2070 | Link | |
LGPL has a more user-centric spirit, which is why MPDN extensions use it. It mandates that everything that has been done to it can be modified by the end-user (for fixing bugs, optimizing etc.) without having the need to recompile or have access to the host app. However, taking away users' ability to change LGPL portions of the code definitely violates the very spirit of LGPL. Last edited by Zachs; 11th May 2015 at 12:02. |
11th May 2015, 12:01 | #2071 | Link | |
MPDN Extensions Dev
Of course, if you modify it, you need to republish it and provide it to the end-user but just using it, you need to give credit and it need to be separate from the rest of your code. Edit: If you put NNEDI3 as GPL, it can't be used in MPDN since the license will propagate to it. (or that's my understanding of GPL) : https://programmers.stackexchange.co...ce-application Last edited by Belphemur; 11th May 2015 at 12:05. Reason: can't ... not can |
11th May 2015, 12:03 | #2072 | Link | |
11th May 2015, 12:08 | #2074 | Link | |
Like I said, I'm just trying to make sure the license is respected. LGPL only helps, not hinder - e.g. the typical dev gets run over by a bus scenario, any LGPL portions can still be updated. |
11th May 2015, 12:11 | #2075 | Link | |
11th May 2015, 12:12 | #2076 | Link | |
MPDN Extensions Dev
Even the GPL state this : 10. If you wish to incorporate parts of the Program into other free programs whose distribution conditions are different, write to the author to ask for permission. For software which is copyrighted by the Free Software Foundation, write to the Free Software Foundation; we sometimes make exceptions for this. Our decision will be guided by the two goals of preserving the free status of all derivatives of our free software and of promoting the sharing and reuse of software generally. |
11th May 2015, 12:15 | #2077 | Link | |
MPDN Extensions Dev
In the case of MPDN extension, as you said, they are under LGPL, MDPN then link to LGPL extension, that's perfectly fine. Now for MadVR and the MPC-HC Gpl, madvr should then be also under GPL ... or ask for a permission from MPC-HC to not be GPL. |
11th May 2015, 12:35 | #2078 | Link | |||
Sorry, I guess my wording has been a bit unclear. Let me try again: tritical has run thousands (or ten or hundred thousands, I don't remember) of images through some neural network software, to create those weights. Basically this "server side" software has analyzed all those images, extracted edge information from them and somehow fused them into the weight database we're using. The NEDI kernel we're using practically could be considered the "client side" software which just uses the weight database to interpolate images. tritical has released the client side software and the weight database under GPL, but he has not released the server side software with which he created the weights at all. Because of that nobody can create a different/new/updated set of weights. All the NNEDI3 magic is hidden in those weights, they are the center piece of the algorithm. So to sum up, the client side of the NNEDI3 algorithm is available as GPL, which IMHO includes the weights. The server side is not available at all. But my understanding is that tritical is actually quite generous. I had asked him about using NNEDI3 in madVR before the OpenCL kernel even existed, and he was ok with that. I think he would most probably allow SEt and the MPDN extensions to use NNEDI3, too, in their current form as LGPL. So maybe you could just PM him to make sure. The key problem is that tritical hasn't been on doom9 for a long time, so it might be difficult to get a reply from him. Quote:
Well, I do not distribute MPC-HC, nor do I link in any part of MPC-HC. It's not madVR using MPC-HC. It's the other way round. madVR is also not a plugin to MPC-HC, it's simply an official DirectShow renderer which anyone can use who wants to use it. I don't see how that would have any legal effect on madVR. I mean Microsoft also doesn't have to publish their EVR sources as GPL, just because MPC-HC uses EVR, right? |
11th May 2015, 12:47 | #2080 | Link | |
By using COM, individual components are never directly linked, and only communicate through a defined and common API. Its probably impossible for anyone of us to answer if that requires compatible licenses, unless one here is an experienced copyright/license lawyer, and even then if someone would try this in court, it could IMHO go both ways. Commercial products tend to avoid shipping GPL components like LAV Filters directly, but instead recommend simply installing them manually.
direct3d, mpdn, nnedi3, opencl, reclock |
