Old 3rd September 2017, 18:03   #22161  |  Link
clsid
Perhaps it could enable the workarounds by default like it did in the past. Not always, but just when first GOP was skipped.
Old 3rd September 2017, 18:04   #22162  |  Link
sneaker_ger
The workaround breaks spec compliant files so that's a no-go.
Old 3rd September 2017, 22:43   #22163  |  Link
mparade
Does anyone know what could be the reason for getting a LAV filters setting window with half of that hidden?
Both in Kodi itself and in Windows' tray most of the LAV settings windows are covered by part of the grey window inside of which the settings are located and hence cannot be modified.
I hope someone else also encountered with such a problem.
Old 3rd September 2017, 22:52   #22164  |  Link
sneaker_ger
https://www.neunbeere.de/blog/2017/0...urity-updates/
(wild guess)
Old 4th September 2017, 09:39   #22165  |  Link
mparade
Thank you. I will check today the workarounds recommended but I am a bit tremuolus because I am on Win10 64 bit OS.
Old 4th September 2017, 10:09   #22166  |  Link
sneaker_ger
The bug is only on Windows 7. If you are on Windows 10 just ignore my last post.
Both in Kodi itself and in Windows' tray most of the LAV settings windows are covered by part of the grey window inside of which the settings are located and hence cannot be modified..
Can you post a screenshot?
Old 4th September 2017, 10:53   #22167  |  Link
It seems to happen sometimes if your Windows is running an Asian locale, for some reason that screws up font rendering of ordinary "western" fonts. Outside of that, I haven't really received much complaints about the settings page going wrong.
Old 4th September 2017, 14:36   #22168  |  Link
mparade
http://mammutmail.com/hu/download/c8...922e0c26dcada7
Only this way because on my HTPC there is no usable application exists other than wordpad.
Thanks for your help.
EDIT: solved by modifying some display settings in Windows.
Thank you again for your time.
Old 4th September 2017, 14:51   #22169  |  Link
sneaker_ger
Glad you have it solved. Care to tell what fixed it (for others with same problem)?
Old 5th September 2017, 08:12   #22170  |  Link
mparade
The problem was solved on my Windows 10 System as follows:
in display settings window of the OS (entering by right-clicking on the desktop) under Display and "sizing and arrangement" part, "modifying the size of text, applications and other elements" should be set to a lower value. E.g. I had to set it to 150% from 300% to be able to modify the settings in LAV Video window inside Kodi Kripton. After the required modifications are done in LAV Video, you should set it back to the required value otherwise all your icons will use that smaller size (for me it was a big problem because I am currently using a 49' 4K TV as a display on which I prefer larger icons.)
Old 6th September 2017, 22:15   #22171  |  Link
mparade
@nevcairiel
In case of decoding main12 content is there no chance for GPU assistance? You stated through DXVA there isn't but what about CUVID? Whatever settings I use the active decoder is "avcodec" in LAV Video for such sources. Using DGDecNV it is possible to feed main12 content to an encoder without dithering using my GTX1060.
Old 7th September 2017, 07:05   #22172  |  Link
P.J
Δ
This video is interlaced but plays in progressive mode with LAV
https://drive.google.com/open?id=0B8q1LB-YXE2hY2E0RUdfVDJ5TkE
P.J is offline   Reply With Quote
Old 10th September 2017, 19:10   #22173  |  Link
AngelGraves13
Set LAV Video deinterlacing to aggressive.
AngelGraves13 is offline   Reply With Quote
Old 11th September 2017, 13:32   #22174  |  Link
el Filou
el Filou's Avatar
I think what P.J. meant was "why isn't LAV correctly detecting the video as interlaced?" MediaInfo does.
Having to manually change a setting for specific videos isn't optimal.
I think this is an ffmpeg decoding problem, maybe submit a bug report there?
Old 11th September 2017, 13:33   #22175  |  Link
If "aggressive" works, then the video is probably just encoded faulty. It happens all the time. Aggressive basically means that it was detected as interlaced at least once, but then went back to being flagged as progressive - which is generally a sign of bad encoding.
Old 11th September 2017, 17:17   #22176  |  Link
P.J
Δ
I reported this issue to MPC-BE decoder and they fixed it.
Hope Lav fixes it too =/
Old 11th September 2017, 21:10   #22177  |  Link
DragonQ
Mixed 1080p/25 and 1080i/25 is valid for a UK HDTV broadcast over DVB-T2.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7
DragonQ is offline   Reply With Quote
Old 11th September 2017, 21:28   #22178  |  Link
If it's encoded properly then that's not a problem. The progressive parts will be detected as progressive, and interlaced as interlaced. It's only a problem if it's not done properly.
Old 12th September 2017, 17:00   #22179  |  Link
P.J
Δ
But it's not mixed.
Old 19th September 2017, 22:34   #22180  |  Link
jaytrinitron
LAV Mixing Questions
Hi, so I am trying to use the LAV Audio mixer to mix down 6.1/7.1 audio to 5.1, preferably without losing audio information and just dropping channels. What do I need to set the center mix, surround mix, and LFE mix levels sliders to, and what exactly do these settings do? Can I ensure that all of the information in the 6.1/7.1 is folded down into the 5.1?
Also this may be a long shot here but for the ffdshow audio mixer, if I take 5.1 audio and mix down to 2.0, are all the channels in the 5.1 mix carried over to the 2.0 mix, including the LFE channel?
jaytrinitron is offline   Reply With Quote
