Old 24th November 2017, 08:44   #2721  |  Link
JohnLai
Originally Posted by craigpro View Post
thanks JohnLai! I'll try 385.69
from memory the weighted option resulted in a lot smaller file size but I've been without a PC for a month so I've forgotten what I was testing.
Don't forget to enable adaptive quantization and lookahead too.
Another thing about NVENC Weight.P..........if you turn it on for H264 encoding, B-Frame will be disabled. Not a good idea.
Only enable W.P. for HEVC encoding because NVENC doesn't support B-Frame for HEVC.
JohnLai is offline   Reply With Quote
Old 24th November 2017, 22:53   #2722  |  Link
Malphie
this is a support thread for StaxRip, when I'm active it's OK to post bugs and feature requests here, sometimes I'm offline for weeks or even months, in that case it's better to use the github issue tracker to ensure things don't get lost.
The official website of StaxRip is on GitHub: https://github.com/stax76/staxrip
Are there any merge code for stax? Merge files option doesn't work for me.
Malphie is offline   Reply With Quote
Old 25th November 2017, 02:35   #2723  |  Link
ENiGMA59
Hi Stax76 help me please the solution ? thanx in advance
Error ffmpeg: Re-mux TS to MKV using ffmpeg 3.3.4 (1.7.0.4)
ffmpeg: Re-mux TS to MKV using ffmpeg 3.3.4 failed with exit code: 1 (0x1)
The exit code might be a system error code: STATUS_WAIT_1
The exit code might be a system error code: Fonction incorrecte.
------------- ffmpeg: Re-mux TS to MKV using ffmpeg 3.3.4 -------------
"C:\Program Files (x86)\Staxrip\Apps\ffmpeg\ffmpeg.exe" -i "C:\Users\ENiGMA59\Desktop\24.11.2017.12h00-NUMERO 23.ts" -c copy -map 0 -ignore_unknown -sn -y -hide_banner "C:\Users\ENiGMA59\Desktop\24.11.2017.12h00-NUMERO 23_temp\24.11.2017.12h00-NUMERO 23.mkv"
[h264 @ 0000012b27e23c60] number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one
[h264 @ 0000012b27e23c60] Increasing reorder buffer to 3
[mpegts @ 0000012b26636960] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0000012b26636960] start time for stream 5 is not set in estimate_timings_from_pts
Input #0, mpegts, from 'C:\Users\ENiGMA59\Desktop\24.11.2017.12h00-NUMERO 23.ts':
Duration: 00:43:36.68, start: 0.280000, bitrate: 5062 kb/s
Program 2565
Stream #0:0[0x208]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 24.83 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x212](fra): Audio: eac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, fltp, 128 kb/s
Stream #0:2[0x213](qaa): Audio: eac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, fltp, 128 kb/s
Stream #0:3[0x214](qad): Audio: eac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, fltp, 96 kb/s
Stream #0:4[0x226](fra): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired)
Stream #0:5[0x227](fra): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006)
Output #0, matroska, to 'C:\Users\ENiGMA59\Desktop\24.11.2017.12h00-NUMERO 23_temp\24.11.2017.12h00-NUMERO 23.mkv':
Metadata:
encoder : Lavf57.71.100
Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 24.83 fps, 25 tbr, 1k tbn, 90k tbc
Stream #0:1(fra): Audio: eac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 128 kb/s
Stream #0:2(qaa): Audio: eac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 128 kb/s
Stream #0:3(qad): Audio: eac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 96 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
Stream #0:2 -> #0:2 (copy)
Stream #0:3 -> #0:3 (copy)
Press [q] to stop, [?] for help
[matroska @ 0000012b27e29c40] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[matroska @ 0000012b27e29c40] Can't write packet with unknown timestamp
av_interleaved_write_frame(): Invalid argument
video:70kB audio:7kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Conversion failed!
StaxRip.ErrorAbortException: ffmpeg: Re-mux TS to MKV using ffmpeg 3.3.4 failed with exit code: 1 (0x1)
Program 2565
Metadata:
Stream mapping:
Conversion failed!
à StaxRip.Proc.Start() dans D:\Projekte\VS\VB\StaxRip\General\Proc.vb:ligne 338
à StaxRip.CommandLineDemuxer.Run(Project proj) dans D:\Projekte\VS\VB\StaxRip\General\Demux.vb:ligne 207
à StaxRip.MainForm.Demux() dans D:\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:ligne 3114
à StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) dans D:\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:ligne 1977
ENiGMA59 is offline   Reply With Quote
Old 26th November 2017, 12:55   #2724  |  Link
craigpro
yeah I'm encoding with HEVC - I did some testing and with AQ enabled the file size was between 5-10% larger than AQ disabled.
WP is enabled and my command line is like this:
--cqp 18:20:22 --codec h265 --preset quality --output-depth 10 --weightp --lookahead 16 --transfer auto
craigpro is offline   Reply With Quote
Old 26th November 2017, 13:40   #2725  |  Link
sneaker_ger
That doesn't really tell you much. File size might can be 5%-10% bigger but quality may be 10%-15% better (or not). You need to compare same file size with your eyes.
Old 26th November 2017, 15:06   #2726  |  Link
JohnLai
Just enable AQ, the quality improvement and extra file size is worth it.
I noticed you use CQP mode, why not pseudo CRF mode? (It is VBR-Target Quality mode, but I have difficulty in explaining it)
Take a look on the setting here
https://i.imgur.com/k9Shlwr.png
You will notice there is less "banding" or blockiness on scene with dark background compared to CQP mode.
Trust me on this. or.....test it yourself.
Edit: Because many people complained about weight-p being broken with latest nvidia driver........rigaya@nvencc developer decided to disable weightp option temporary. https://github.com/rigaya/NVEnc/releases/tag/3.25 Thus...stick with version 3.24........
Old 26th November 2017, 16:03   #2727  |  Link
craigpro
will give your suggested settings a try, I use the staxrip compare function - save a few frames from the same timeframe in source and output file, then do a direct pixel comparison between the two to see how much noise / error / garbage is in the output file.
I'm re-encoding my NAS x264 collection anyways, purpose was to maintain similar 720p quality for much smaller file size.
yes, I know. I am the devil.
EDIT: cannot try your settings as I get an error when processing:
NVEncC64.exe --vbr 24329 --codec h265 --preset quality --level 4.1 --output-depth 10 --weightp --lookahead 32 --max-bitrate 24329 --vbr-quality 27 --aq --sar 255:191 --transfer auto -i "Block.mkv" -o "Block_out.h265"
Failed to Initialize the encoder
.: 8 (NVENC indicates that one or more of the parameter passed to the API call is invalid.)
Old 27th November 2017, 20:25   #2728  |  Link
Malphie
guys i want to merge 2 videos but merge files option doesn't work, it gives error. are there any merge code?
Old 28th November 2017, 03:46   #2729  |  Link
JohnLai
Hmm? You didn't follow the settings exactly.
-.- Where is Initial QP = 1 ? (This one is mandatory as we don't dont want set min QP contraint at default 20)
Nvencc max bitrate for L4.1 is 17500kbps.
For L5.1, max bitrate is 38400kbps
EDIT: You should get something like below. Let us modify it a bit to L5.1 as per BD-ROM-AV-WhitePaper_HEVC.
NVEncC64.exe --vbr 38400 --codec h265 --preset quality --level 5.1 --output-depth 10 --weightp --ref 5 --lookahead 32 --qp-init 1 --max-bitrate 38400 --vbr-quality 27 --aq --sar 12:11 -i -o %source_dir%%source_name%_temp\_out.h265
Old 29th November 2017, 13:11   #2730  |  Link
craigpro
Many thanks JohnLai!! I haven't had time to conduct in-depth tests as yet but your settings result in about another 10% file size saving over my settings.
Both your and my settings however result in a slight loss of red, particularly noticeable in skin tones WITH static images side by side for comparison. I doubt very much it'd be noticed on a tv watching the show.. at worst the video may look a little ''cool''.
I'm hoping to have time this weekend to do some frame by frame comparisons (staxrip video comparison tool is awesome!) and report back.
Old 29th November 2017, 14:56   #2731  |  Link
JohnLai
Chroma subsampling issue ~.~
Generation loss = can't do much about this.
EDIT: Consider using "--profile main444" to minimize chroma subsampling generation loss. But your output file size gonna...be a trouble....~.~
EDIT2: You can read more about it at https://cloudinary.com/blog/why_jpeg..._a_photocopier
Old 29th November 2017, 21:22   #2732  |  Link
Crash82
audio stream name
I need some help I've been searching but I'm not sure exactly what I'm looking for or if it's even possible to do, so i hope there is some smart people here who can help me
What I'm trying to do is when i'm muxing I want to have a name on
the audio track with the type of audio it is and channels has and what language it is so I know which one is what.
Normally I see it like this http://prntscr.com/hgypb8
But I wanted more like this
Example
TrueHD 5.1 [Language]
DTS-HD MA 6.1 [Language]
DTS 5.1 [Language]
AC3 2.0 [Language]
and so on
I want to hear if this possible to do it automatically instead of typing it manually
if it is possible how do I do it.
Any help is appreciated
Crash82 is offline   Reply With Quote
Old 30th November 2017, 09:39   #2733  |  Link
hajj_3
x265 v2.6 is out.
Old 4th December 2017, 12:06   #2734  |  Link
VincAlastor
DGDecNV hardware cropping problem
By setting DGSourceNV as Source and hardware cropping filter staxrip's auto crop borders feature uses the wrong values when source is codes in 1088p but displayed in 1080p. This also deactivates the forcing output mod 4 rule for DGDecNV.
How can I fix this?
VincAlastor is offline   Reply With Quote
Old 4th December 2017, 23:11   #2735  |  Link
Marban
HDR to SDR is very bad, something make it wrong.
is it right?
Marban is offline   Reply With Quote
Old 4th December 2017, 23:17   #2736  |  Link
sneaker_ger
Those options do not convert HDR to SDR. They only tell x264 what flags to set in the bitstream (players read the flags in order to know how to interpret/display the content). The HDR->SDR conversion has to be done in VapourSynth/AviSynth.
Old 5th December 2017, 00:52   #2737  |  Link
Marban
ok, thanks.
How does it work with VapourSynth/AviSynth?
Old 6th December 2017, 08:04   #2738  |  Link
Vesdaris
Hey guys. What settings would you recommend using for nvenc hevc for max quality? There are so many and when I try to experiment (like enabling deband, for instance) I usually get errors
So I was wondering if someone would be kind enough to post them .
I've got gtx 1060.
Thanx in advance
PS Should I use these?
https://imgur.com/k9Shlwr
Should I select VBR HQ instead of VBR? What about cabac?
PPS It seems --weightp is still broken in the latest nvidia drivers ;( It makes my encoding process stop at random %
Vesdaris is offline   Reply With Quote
Old 6th December 2017, 13:39   #2739  |  Link
craigpro
I'm using JohnLai's settings and I needed to downgrade my nvidia drivers to version 385.69 for -weightp option to work. I also have a GTX 1060 6GB GPU (intel I5-2500K CPU).
Old 6th December 2017, 13:58   #2740  |  Link
JohnLai
I've got gtx 1060.
Thanx in advance
Dont select VBR HQ with the CQ mode setting, otherwise, you will get full 17500kbps or 38400kbps all the way and ended up with huge file size.
CQ mode only work with standard VBR.
edit: CABAC is the only entropy encoder method that is allowed in HEVC per standard. What with the question? For H264 encoding, nvenc will use CABAC as default
