3rd November 2013, 09:43 | #102 | Link |
Maybe you should add the URL tags to your URLs to make them clickable
But I thought L-Smash muxer.exe was now able to mux HEVC into MP4 but I can't make it working with rev786 while it works with the same source and MP4box rev4868. Am I missing anything ? Example of source file: https://x265.cc/builds/Samples/bigbuckbunny.hevc |
3rd November 2013, 10:05 | #103 | Link | |
Spinner of yarns
HEVC muxing is testing and experimental purposes only at present since the specification is not finalized and published yet. I don't want you to mux HEVC for archival and distribution purposes since there is no guarantee that the file is demuxed and decoded correctly in the future. At least, L-SMASH will reject files based on the draft versions. Be patient, please. If compiled with the latest ffmpeg (which can output POCs of HEVC), L-SMASH Works can seek raw Annex B HEVC stream. So, you can play avs importing the raw stream and audio stream as if AVI.
僕と契約して、L-SMASH developerになってよ! L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software Last edited by VFR maniac; 3rd November 2013 at 10:24. |
3rd November 2013, 10:52 | #104 | Link | |
No! |
7th November 2013, 10:57 | #105 | Link | |
(Confirmed with r688-2; not yet tested with most recent r693) Last edited by LigH; 7th November 2013 at 11:05. |
12th November 2013, 12:25 | #106 | Link |
LWLibavVideoSource seems to have a problem with big ts files (I tested 2 files ; 4,70 GB and 6,02 GB) in interlaced h264 : the framerate is doubled, even when repeat=true is added. It happens on rev 693, 688 and 662.
With a short extract of one of these files (5 minutes, 230 MB cut with TSMuxer), there is no problem, even when repeat=true is not added (with rev693). I don't know which is the size limit to allow a good working, I guess 4 GB. |
12th November 2013, 13:08 | #107 | Link |
Try cutting out 2 clips, one about 1.75GB and other about 3.75GB.
12th November 2013, 13:32 | #111 | Link | ||
or 4GB (unsigned int), but as Lenmaer says unrelated to size, then of no use. Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th November 2013 at 13:34. |
13th November 2013, 08:13 | #113 | Link |
Especially transport streams from DVB [-S2] may always contain transmission errors. They should never be used without cleaning.
And even if direct handling of TS sources is more or less supported by FFMS2 (with the required Haali splitter) or L-SMASH Source, handling a source remultiplexed to MKV is certainly more reliable. |
14th November 2013, 11:07 | #116 | Link |
Tried a 2,5 GB ts : strange behavior (with rev693) : Virtual Dub detects now 25 fps -whatever I specify repeat=true or not-, but in both cases all frames are doubled anyway and the file length too, and it is played at half speed.
edit : same problem with a 1,64 GB TS cut with TSMuxer. edit : different problem when the 2,5 and 1,64 GB files are put in MKV : file length is good but all frames are also doubled -whatever I specify repeat=true or not- and Virtual Dub detects 50 fps (I demuxed streams with TSMuxer, opened them in MKVMerge and specified 50i as framerate). Even below 2 GB, there are problems. Last edited by Music Fan; 14th November 2013 at 12:48. |
30th November 2013, 12:43 | #119 | Link |
r702 is online ;
https://drive.google.com/folderview?...UU&usp=sharing |
