Old 12th December 2016, 23:07   #1001  |  Link
Khanattila
Khanattila's Avatar
Originally Posted by WolframRhodium View Post
I'm also looking for official document for new version...
Update: oh the next version will be documented, that's great!
I have to finish to update the wiki
github.com
Khanattila is offline   Reply With Quote
Old 13th December 2016, 01:16   #1002  |  Link
WolframRhodium
That wiki helps me a lot, thank you.
Anyway, isn't the default value of "wmode" is 1(DFT_WMODE)? The wiki says by default the value is 0. And there are 3 kind of Bisquare weighting function but the wiki just mention 2.
WolframRhodium is offline   Reply With Quote
Old 13th December 2016, 09:24   #1003  |  Link
dipje
Easiest is to say, that while the 1.0 branch is in 'beta' the doc and wiki will be outdated or have a chance to be incorrect. It's a beta for a reason, a quick release to find problems, not to have a complete finished and documented release :P.
Then again, there are a lot of plugins and products around here that never leave the beta phase so. mweh .
dipje is offline   Reply With Quote
Old 13th December 2016, 13:33   #1004  |  Link
tormento
Acid fr0g
tormento's Avatar
A beta can't be really tested until parameters are known
@turment on Telegram
Old 13th December 2016, 16:27   #1005  |  Link
Khanattila
Khanattila's Avatar
Done.
github.com
Old 13th December 2016, 17:40   #1006  |  Link
tormento
Acid fr0g
tormento's Avatar
Great. Thanks.
Old 14th December 2016, 10:36   #1007  |  Link
tormento
Acid fr0g
tormento's Avatar
Maybe because "wmode" has changed? For v1.0.0-beta.1, you should set it to 0 (Welsch weighting function), which is used in v0.7.7 by default.
It seems it is the default value for both releases.
So, I dunno why output bitrate changed.
Old 14th December 2016, 10:44   #1008  |  Link
WolframRhodium
I just read the source code and perhaps I made a mistake.
The update log mentions "Improved de-noising quality around image edge." Maybe that's the reason?
Update:
I have made another test of v1.0.0-beta.1 on vapoursynth just now.
Yes, the default value of "wmode" is 1 for both version, but in v0.7.7, it indicates "Welsch weighting function", while in v1.0.0-beta.1, it indicates "Modified Bisquare weighting function", so what I have suggested you before to set it to 0 for v1.0.0-beta.1 is to return to use "Welsch weighting function".
I'm sorry for my poor English expression. I'm not a native English speaker.
Old 14th December 2016, 11:58   #1009  |  Link
Khanattila
Khanattila's Avatar
Update:
There were several problems in the release of v1.0.0-beta1, so before I make other changes I release beta2.
https://github.com/Khanattila/KNLMea.../v1.0.0-beta.2
github.com
Old 14th December 2016, 12:33   #1010  |  Link
tormento
Acid fr0g
tormento's Avatar
Nope. Welsch is the default wmode with both even with different wmode numbers, i.e. 1 for 0.7.7 and 0 for 1.0.
Different noise treatment should be somewhere else. Khanattila, can you please tell us what is under the hood?
Old 14th December 2016, 12:40   #1011  |  Link
WolframRhodium
khanattila just pushed the last commit of v1.0.0-beta.2, which is "Change default value of wmode" (https://github.com/Khanattila/KNLMea...573bd0e5ccedf1)
Old 14th December 2016, 13:08   #1012  |  Link
Khanattila
Khanattila's Avatar
v0.7.7 wmode=1 -> Welsch
v1.0.0 beta1 wmode=1 (my fault) -> Bisquare
v1.0.0 beta2 wmode=0 -> Welsch
github.com
Old 14th December 2016, 13:14   #1013  |  Link
feisty2
I'm Siri
feisty2's Avatar
https://www.mathworks.com/help/stats/robustfit.html
just in case if anyone's curious about the mathematic definition of each weighting function...
feisty2 is offline   Reply With Quote
Old 14th December 2016, 13:23   #1014  |  Link
tormento
Acid fr0g
tormento's Avatar
+3/5% bitrate difference from 0.7.7.
I invite other members to test some samples and report here.
Old 14th December 2016, 13:27   #1015  |  Link
WolframRhodium
I find strange stains at the border when using v1.0.0-beta.2, especially when "a" is large.
examples:
http://screenshotcomparison.com/comparison/193750
Just look at the top border of the filtered image. There are also some stains at the left/right border, but is nearly invisible.
The problems happens on both "channels".
Old 14th December 2016, 13:35   #1016  |  Link
tormento
Acid fr0g
tormento's Avatar
How is possible to denoise a normal DGDecNV output on both Y and UV? If I left auto, it uses Y only, if I try YUV it tells me
error: KNLMeansCL: 'channels = YUV' require a YV24 pixel format!
Old 14th December 2016, 13:41   #1017  |  Link
Khanattila
Khanattila's Avatar
examples:
Just look at the top border of the filtered image. There are also some stains at the left/right border, but is nearly not visible.
I would say that the "Improved denoising image quality around edge" must be fixed
github.com
Old 14th December 2016, 13:56   #1018  |  Link
Khanattila
Khanattila's Avatar
As has always been...
a) Processes each channel independently.
b) Process "Y" and "UV" separately.
c) Converting to RGB, processing, and them back to YUV.
d) Other more elaborate methods.
github.com
Old 14th December 2016, 13:58   #1019  |  Link
feisty2
I'm Siri
feisty2's Avatar
do some padding before the actual process, trivial to fix
Old 14th December 2016, 14:01   #1020  |  Link
tormento
Acid fr0g
tormento's Avatar
e) ask kindly the programmer to add the feature
