Old 28th January 2017, 01:53   #4661  |  Link
Selur
Selur's Avatar
Effective for RD levels 4 and below.
if (m_param->complexAnalysis && (!bIsVbv || !p->rc.aqMode || p->rdLevel > 4))
    p->complexAnalysis = 0;
    x265_log(p, X265_LOG_WARNING, "Complex-analysis disabled, requires RD > 4, VBV and aq-mode enabled\n");
=> 'requires RD > 4' should be 'requires RD <= 4'
Old 28th January 2017, 16:05   #4662  |  Link
Motenai Yoda
Motenai Yoda's Avatar
more "Effective for RD levels 4 and below." should be "Effective for RD levels 5 and over. "
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 28th January 2017, 16:10   #4663  |  Link
Selur
Selur's Avatar
@MontenaiYoda: the code I posted disables complexAnalysis when rdLevel > 4, so "Effective for RD levels 5 and over. " seems strange to me.
Cu Selur
Old 28th January 2017, 16:12   #4664  |  Link
I'd agree to Selur's opinion, it seems to match the documentation: complex analysis "Increases the RD level at points where quality drops due to VBV rate control enforcement", therefore it should be more effective when it was initially rather low. It compensates a bit of the loss in fast presets.
Old 28th January 2017, 16:16   #4665  |  Link
Motenai Yoda
Cu Selur
KK I misread 0 as 1
Old 29th January 2017, 13:36   #4666  |  Link
MonoS
Hi, i do my encode with a command line like this
 vspipe.exe -y script.vpy - | ffmpeg.exe -i - -c:v libx265 -preset veryslow -crf 22 ...
Often my script produce a 16bit output due to scaling or denoising, is it best to dithering the input in vapoursynth, pass the clip undithered as i'm doing or use the parameter --dither of x265 in the command line?
If i should dither it on the script side, what kind of dither is it best for this kind of parameters, if i'm not mistaken ordered dither should be the best when reaching for low bitrate target in every case
rect=0:amp=0:cutree=0:early-skip=0:limit-refs=3:aq-mode=3:limit-modes=1:level-idc=4:me=2:fast-intra=1:max-merge=3:rd=4:rdoq-level=0:psy-rd=1.1:aq-strength=1.9:deblock=-1,-1
Thanks for the attention
MonoS is offline   Reply With Quote
Old 30th January 2017, 12:45   #4667  |  Link
Midzuki
Unavailable
Midzuki's Avatar
x265 2.2+30-fa52b516f5ff
complexAnalysis: clean up
http://www.mediafire.com/file/6vj4jy...a52b516f5ff.7z
Old 30th January 2017, 12:56   #4668  |  Link
Magik Mark
Is there a way to convert bt2020 to bt709 color matrix?
Old 30th January 2017, 15:33   #4669  |  Link
Barough
Barough's Avatar
x265 v2.2+30-fa52b516f5ff (MSYS/MinGW, GCC 6.3.0, 32 & 64bit 8/10/12bit multilib EXEs)
Old 31st January 2017, 11:46   #4670  |  Link
x265 2.2+30-fa52b516f5ff (GCC 6.2.0)
I hope XhmikosR will release updates MSYS packs...
Old 31st January 2017, 14:24   #4671  |  Link
benwaggoner
Not with x265. And not well without some high-end tone mapping technologies.
Ben Waggoner
My Compression Book
Old 31st January 2017, 18:39   #4672  |  Link
Midzuki
Unavailable
Midzuki's Avatar
You can safely replace GCC 6.2 with the GCC 6.3 build compiled by nevcairiel:
https://files.1f0.de/mingw/
OR go the MSYS2 way...
Originally Posted by vBm View Post
Word about MPC-HC was in a dire need of developers was published back in '12.
At the moment only XhmikosR and kasper93 are semi active, you know ... LIFE has happened and not everyone has spare time anymore. Official statement will be drafted and published on MPC-HC's website when the time is right and when there are news to report.
So, perhaps XhmikosR will release a new MSYS1 package only when GCC 7 is out...
Old 1st February 2017, 07:37   #4673  |  Link
youli
youli's Avatar
Hi! Is anybody knows, how to display graphic chart of bitrate distribution for H.265 stream? I mean, just like "Bitrate Viewer" for H.264:
youli is offline   Reply With Quote
Old 1st February 2017, 08:27   #4674  |  Link
Did you try whether this Bitrate Viewer fails when you have HEVC multiplexed in a supported container? It may just not support a raw video stream as long as there is no matching source filter.
An alternative may be to let x265 write a verbose CSV log (csv-log-level > 0), import it into a spreadsheet calculator, sort it to display order (that's a bit tricky e.g. in Excel alone), and let this draw a graph.
Old 1st February 2017, 10:28   #4675  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
https://github.com/zeroepoch/plotbitrate
Old 1st February 2017, 15:37   #4676  |  Link
youli
youli's Avatar
LigH, ApTeM thanks a lot for your advices, but.. it will difficult ways for me.
In the both cases for AVC and HEVC I use mkv container. With AVC in mkv "Bitrate Viewer" works perfect, but with HEVC in mkv I got error "Codec not found".
LAV Filters 0.69 was installed.
Old 1st February 2017, 15:47   #4677  |  Link
Oh, I think I remember that this Bitrate Viewer was built upon some ffmpeg version which is quite outdated today... It will not use LAV Filters. No source available. No longer developed.
Here was the forum thread with my old complaint... The author updated only a Mac OS X version, but not a Windows version.
You will find some more tools there, but they are command line tools, not so user friendly without mouse support.
Old 1st February 2017, 17:10   #4678  |  Link
youli
youli's Avatar
Oh, thanks! I used CheckBitrate from https://onedrive.live.com/?authkey=%...DD4375AC8933C6 and got csv-file.
Chart it in Excel
Old 2nd February 2017, 05:54   #4679  |  Link
x265_Project
No need to sort in display order. The decoder is going to have to decode in decode order, which is the real bit rate.
Old 3rd February 2017, 18:05   #4680  |  Link
davidsama
2.2+31-2014112 avx2 version https://tinyvpn.net/a/c/b/acbdfccb48...78919834ebc.7z
davidsama is offline   Reply With Quote
