29th September 2009, 07:28 | #5821 | Link | |
By the way I don't have problems playing any other mkv except the ones I made myself using ripbot264 and a HD-DVD-rip.
Bye QUEENFAN |
29th September 2009, 11:44 | #5822 | Link | |
C# Addict
My profile doesn't have that switch . So , it is not the case ... Maybe RipBot uses some "special" builds ?
AviDemux Windows Builds |
29th September 2009, 14:32 | #5823 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 29th September 2009 at 14:38. |
29th September 2009, 18:29 | #5824 | Link | |
29th September 2009, 18:38 | #5825 | Link | |
29th September 2009, 20:11 | #5827 | Link |
@Preludee01
are you launching directly from the exe or using a shortcut? if using a shortcut right click > properties and make sure "start in:" is set to the ripbot main directory. this happened to me then i discovered my "start in" field wasn't correct. a strange error for sure... or its possible ripbot is checking for your temp files on the wrong harddrive. if you know the drive they are currently on, go into ripbot264.ini (main directory i believe) and set the temp drive to the correct one. only type C, D, etc. not C: or C:\ also, not sure if youre a privacy addict or not, but not sure if you want to be displaying what seems to be your full name. Last edited by gohamstergo; 29th September 2009 at 20:17. |
29th September 2009, 23:18 | #5828 | Link |
RipBot264 Not Working? (2)
Hey. I dont use a shorcut, i just run it direct fomr the RipBot264. Ive changed the settings on it -from AUTO to C. Its doing the same ting. Ive try to reinstal all the programmes for it, does work this time..
30th September 2009, 03:02 | #5830 | Link |
Has anyone gotten "The Hunt for Red October" to work correctly? There are two subtitle tracks. One is all of the spoken dialogue in the movie (both English and Russian), and the other is all the hearing impaired subtitles.
How can I build just the forced Russian parts? |
30th September 2009, 03:02 | #5831 | Link | |
30th September 2009, 03:42 | #5832 | Link |
@gohamstergo
First: sorry for that, i just wanted to say ty to remind me to remove name's when added picture. So i modified my picture.
Second: I tried to put "C" for default, and it does the same thing Any thing els you know to do that can work? Third: My english is bad lol Last edited by Preludee01; 30th September 2009 at 03:44. |
30th September 2009, 04:11 | #5833 | Link | |
Understood. Unfortunately, I don't have any experience with HD-DVDs. All of my re-encodes have been mkvs or Blu-rays.
-Hoju Quote:
30th September 2009, 06:52 | #5834 | Link | |
anyway.... i used both 64bit version: ffdshow_rev3078_20090917_clsid_x64 and ffdshow_rev3082_20090921_xxl_x64 but when i start RipBot it say i need a new version!?!?!?!?!?!? why? someone???? thx! |
30th September 2009, 13:56 | #5835 | Link | |
I've used ripbot for a long time now and never had this problem before:
30th September 2009, 16:10 | #5836 | Link |
Just wondering if there is something changed since 1.14.4? Previously I encode my videos using CQ=18, my mkv usually are around 15-25GB range. However, with the current version, the files come out < 10GB all the time. Wondering is because the compression has improved or the CQ=18 is not being enforced?
30th September 2009, 16:21 | #5837 | Link |
This is what I experience too with x264 build 1259 coming from 1251 packaged with the latest Ripbot. I think you'll find there is also a drop in quality as well with identical settings between the builds, although perhaps not to the extent to which the drop in bitrate might suggest. The way I understand it is that the new build has a feature called mbtree and allows for greater swings in the quantizer. So, in complex, fast moving scenery, the quant rises more than it did previously resulting in lower bitrate applied to the frame. In general, I'm finding that an encode @ CRF22 is equivalent in size of encode @ CRF19. However, once you achieve a similar encode file size, there is a definite quality gain in static scenes at least with the newer build.
BTW, what is the point of using CQ over CRF? Last edited by kikker; 30th September 2009 at 16:24. |
30th September 2009, 17:00 | #5838 | Link | |
30th September 2009, 17:10 | #5839 | Link |
Can't get Ripbot264 to make AVCHD disk in correct size and bitrate
What's wrong? I've used BD Rebuilder successfully many times, but wanted to give Ripbot264 a try. I rip the Blu-ray disk using AnyDVD HD to the HD. In Ripbot264, I selected the first *.m2ts stream, and the movie is correctly found. AVCHD is selected, 2-pass Mode, Blu-ray profile, Lock Size set to 8150 MB for burning to a DVD9. The bitrate shown in KBPS looks appropriate at 9793. The resulting AVCHD files are only 1.5 GB, highly pixelated, and definitely not 1080p. Trying again, I explicitly set video Properties to 1080p. I have tried this several times with the same result. Your help is appreciated!
30th September 2009, 17:15 | #5840 | Link | |
Why the x64 version wont be accepted?!?!?!?!?! (the version, i think, is correct) thx! |
