11th April 2017, 10:23 | #14821 | Link | |
I haven't tried letting ripbot handle the whole file for ages, its just what works for me, perhaps I'll try it with the next Blu-ray I do. I normally keep two audio tracks, a 5.1 and the Atmos or DTSMA. |
11th April 2017, 13:03 | #14822 | Link | |
I you want first 5 minutes then use Trim(0,7200) (24fps*300s=7200 frames)
11th April 2017, 15:01 | #14824 | Link |
It seems as of v1.19.6, loading jobs involving demuxing TrueHD tracks that have issues of a certain caliber result in a failure. This failure happens at the end of the job load; at the gathering info stage. Choosing to convert to wav or presumably FLAC rather than demuxing can generate similar disappointment. You have to wait a while to find out you should have loaded that job without the audio, especially if the source file is M2TS.
Many of us RipBot264 users are aware we can deal with audio conversions outside of RipBot264 with the likes of Eac3to and it's GUIs, but options for TrueHD tracks with issues are often limited to core extractions. Strangely, some 5.1 and 7.1 TrueHD cores are not 640kbps. I've seen some Atmos with 384kbps cores. Adding to this issue is far more TrueHD tracks have conversion issues compared to DTS-MA. Atak, consider changing the job load process to not aboard with an error when TrueHD tracks have issues, but to finish loading the job without the audio. Also consider an option to preselect audio tracks, including no audio, when loading .mkv sources, similar to choices we get when loading M2TS files. Thank you. Last edited by FuzzyNutz; 12th April 2017 at 21:40. |
11th April 2017, 15:13 | #14825 | Link | |
Update: I see that v1.19.6 is downmixing to 6 channel when 7.1 sources are encoded to 5.1. The jobx_a1 file includes the "audio=DownMixTo6ch" instruction. Last edited by FuzzyNutz; 11th April 2017 at 23:20. |
11th April 2017, 15:42 | #14826 | Link | |
Atak, please clarify. Thanks. Last edited by FuzzyNutz; 11th April 2017 at 15:50. |
11th April 2017, 17:35 | #14828 | Link | |
11th April 2017, 17:52 | #14829 | Link | |
It's absurd that an Atmos stream would have a 384kbps core. Grrrrr. I have not watched Suicide Squad. I've surpassed my saturation point of Hollywood's offerings. I watch less of the movies and TV shows I hoard. This hobby is sometimes more about acquisition and the self-empowering knowledge of how to manipulating A/V. Last edited by FuzzyNutz; 12th April 2017 at 21:36. |
11th April 2017, 18:36 | #14830 | Link |
I also find absurd a TrueHD stream with or without Atmos with a core similar to the one used in the early days of the dvd's.
I do not have many problems with bad movies, I consider it a good uncompromising fun. |
11th April 2017, 23:35 | #14831 | Link |
DTS-MA 7.1 Strange Setup
Earlier versions of Eac3to gave low volume warnings when decoding/encoding the notorious "strange setup" version of 7.1 DTS-MA.
Should there be cause for concern when RipBot264 deals with this "strange setup" DTS-MA variant? Last edited by FuzzyNutz; 12th April 2017 at 21:35. |
13th April 2017, 03:15 | #14834 | Link |
In demux mode the track remains intact as it has to be, but in "wav" and "flac" modes RipBot264 downmix. Then the way is to do the conversion on the outside using eac3to, 7.1 source to a 7.1 WAV file.
15th April 2017, 22:50 | #14836 | Link |
Hi, I've been away from encoding for a while, just wondered though, I've made an MKV remux of Moana using MakeMKV. I've opened that up in Ripbot and the audio is DTS-HD MA 7.1. If I choose an output format of AC3 5.1 640kbps, when the surround channels get mixed does it automatically reduce the volume if there is clipping, or do I have to check 'normalize' for this to happen?
16th April 2017, 01:58 | #14837 | Link |
Corrupted or Dropped Frames using Distributed Encoding
I'm running 19.6 and I just upgraded a few days ago. It seems with about half of my encodings since then, that I'm finding a dropped or corrupted frames with what I'm assuming is at the end or beginning of a chunk. Example from the movie Blow at 15:01. According to VLC and the "Jumpt to Time" plugin, the corrupted frame happens at 00:15:01,207:
https://postimg.org/image/6moudmhgl/ The Crucial showed what seems to be a couple of drop frames at pretty much the same time. Going through a frame at a time at 00:15:01,182 shows what looks like a merged frame: https://postimg.org/image/6nys71jad/ Information: Using MDegrain2 with x264. My distributed encoding is a bit of an odd setup. Master Server 1: Four 12-core Opterrons, 256GB of RAM, running Linux and a Hypervisor (KVM/Libvirt). Windows 10 guest with with 42 cores given to it along with 16GB of RAM, runs five RipBot264 threads. Encoding Client 1: Ryzen 1800x, MSI Gaming Pro board. Runs 1 RipBot264 threads. (Ryzen is amazing for encoding. This single proc is almost half as fast at encoding as my master server. Encoding Client 2: Dell R710 with two 4-core sockets running Server 2013 R2, runs 2 RipBot264 threads. Encoding Client 3: Dell R710 with two 4-core sockets running Server 2013 R2, runs 2 RipBot264 threads. I've very rarely noticed this when watching an encoding done by RipBot264. So rare I've have not worried about it. But now, I'm going to have to go back and check all my recent encodings. I'm going to try a few encodes with Blow and different settings to see what I can find out. |
16th April 2017, 15:07 | #14838 | Link |
@Ryushin
1) Delete folder \\Your-PC\RipBot264temp\Tools 2) Download v1.19.5 -> http://www.mediafire.com/file/prdp0g...t264v1.19.5.7z 3) Delete folder ffms in v.1.19.6 3) Copy ffms folder from v1.19.5 to v.1.19.6 Let me know if this works.
17th April 2017, 00:16 | #14839 | Link | |
But the the problem is fixed by copying the ffms folder. The problem did not show up. I'm going to run the same DE again and enable MDegrain2. BTW, just wanted to say thank you again for such an amazing program and for your so very much appreciated dedication to supporting and improving it. There is simply none better. I reverted the changes recently to when I added AviSynthMT (AvisynthPlus-r2455-MT) to system32 and syswow64. Does RipBot264 detect MT automatically or is there some change I need to make? I'm trying to speed up MDegrain. Normally I'll see 50-100fps depending on content, but only around 5fps when using MDegrain. I have a lot of unutilized cpu resources when using MDegrain. I was also going to make a new thread about degraining and possibly adding a couple of options to the settings, but I guess I'll post that here. Essentially I've found that when using HQDN3D, using using temporal settings at about half of what the Mono/Colour is I get good results. If I set temporal settings to the same as Mono/Colour I'll get artifacts. So settings would be something like 2/2/1/1 3/3/1/1 4/4/2/2 5/5/2/2 6/6/3/3, etc. Not sure if you can add something like a Temporal box option and just put in the amount of half along with rounding down if the number is not dividable by two. When you added MDegrain, it opened a lot of doors. I've spent far too much time looking at all the options I could do with MDegrain (fairly daunting I might add). But essentially, after so much research, it was really a simple change of thSAD=400. When I used HQDN3D for something like 6/6/3/3 or 8/8/4/4 I found a MDegrain thSAD=150-200 range gives me excellent results. MDegrain results are simply better then anything else I've tried. Can you give an option for the MDegrain to change the thSAD without having to edit the script? I also went through the options for MDegrain1-3 using my test clip. I think MDegrain2 is probably the best solution. MDegrain3 produced a smaller clip, but I'm not sure if I'm loosing too much information and I don't want any artifacts. Test Clip: 5 Minutes, Glengarry Glen Ross, fairly grainy. RAW: 715MB CQ18: 577MB CQ18 MDegrain1 THSAD=200: 290MB CQ18 MDegrain2 THSAD=200: 210MB CQ18 MDegrain2 THSAD=400: 176MB CQ18 MDegrain3 THSAD=200:174MB My settings, which might help others: #Denoise MDegrain1 Modified Loadplugin("C:\Temp\RipBot264v1.19.x\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4) fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4) video=MDegrain1(video,super,bv1,fv1,thSAD=300) #Denoise MDegrain2 Modified Loadplugin("C:\Temp\RipBot264v1.19.x\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4) bv2=MAnalyse(super,blksize=8,isb=true,delta=2,overlap=4) fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4) fv2=MAnalyse(super,blksize=8,isb=false,delta=2,overlap=4) video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=300) #Denoise MDegrain3 Modified Loadplugin("C:\Temp\RipBot264v1.19.x\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) bv1=MAnalyse(super,blksize=8,isb=true,delta=1,overlap=4) bv2=MAnalyse(super,blksize=8,isb=true,delta=2,overlap=4) bv3=MAnalyse(super,blksize=8,isb=true,delta=3,overlap=4) fv1=MAnalyse(super,blksize=8,isb=false,delta=1,overlap=4) fv2=MAnalyse(super,blksize=8,isb=false,delta=2,overlap=4) fv3=MAnalyse(super,blksize=8,isb=false,delta=3,overlap=4) video=MDegrain3(video,super,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=300) |
18th April 2017, 12:58 | #14840 | Link |
Hello, I launched RipBot today and it performed some updates on its own, now I can't see the margins anymore though, only a blank space saying "Panel 1" and "Panel 2"... how can I fix this?
Edit: I just tried to reinstall AviSynth, Haali Media Splitter and ffdshow but it made no difference. Edit 2: I tried with a couple of new files (they're always .vob files for me, generated by a DVD Recorder), but the problem is still there. I always use RipBot with .vob files and I never had this problem before, I could always see the video margins (very useful for cropping). Can you help me, Atak? Thank you. Last edited by steferrari; 18th April 2017 at 16:32. |
