7th June 2017, 15:42 | #21882 | Link | |
Support request - #20
http://cdn.theoplayer.com/video/star...15)/index.m3u8 For this HLS-remote file i have got blank black box after autoreplay him by any of my media players. Any feedback would be appreciated. |
7th June 2017, 15:55 | #21883 | Link | |
Support request - #21
Can you do reconnect for MMS://-streams to be able playback him without any changes in URL? I have the same trouble and with RTSP://-streams! This stream didn't start at all if i try to play him as: rtsp://rtsp-v3-spbtv.msk.spbtv.com/s...3_1/30_110.sdp But if I change the URL it can start to play! What order of the connections?: 1) RTSPh (didn't start to play) 2) RTSPu (sometimes playback) 3) RTSPt (always playback) rtspt://rtsp-v3-spbtv.msk.spbtv.com/...3_1/30_110.sdp 4) RTSPm (didn't start to play) Can you do reconnect for RTSP://-streams to be able playback him without any changes in URL? Any feedback would be appreciated. |
7th June 2017, 17:52 | #21884 | Link |
I do not plan to spend much time on streaming problems, if any at all, sorry. Like I said, a dedicated streaming filter would be more appropriate. I do not know if any exist, but that doesn't change what I focus LAV on.
10th June 2017, 19:17 | #21887 | Link |
So, for some incomprehensible reason using the hw deinterlacer is tied to using HW accelerated decoding, which I don't want to use because it's slower than software decoding.
But can I at least work around it? I only want to use deinterlacing for my DVB program. Can I somehow get lav to use different settings for this (cuvid+deinterlacing) program than any other? Maybe some other trick? Last edited by mzso; 10th June 2017 at 19:24. |
10th June 2017, 20:42 | #21889 | Link | |
you have to up and download it from the GPU and EVR/madVR use the same deinterlnacer in the end anyway so it is just a waste to do it this way. |
10th June 2017, 21:02 | #21890 | Link | |
I don't know about EVR, but madVR's deinterlacer performs pretty sadly. But I don't want to use either. I want LAV's HW deinterlacer, which looks far superior to madVR's and to LAV's SW deinterlacer. |
10th June 2017, 22:06 | #21891 | Link |
they are the same deinterlancer.
only DXVA native is connecting directly to the GPU after decoding and there are serious limitations too for this. for hardware deinterlancing you have to do the same process. issues with deinterlancing could be driver related too. |
10th June 2017, 22:12 | #21892 | Link |
madVR option "force video mode" uses the GPU's hardware deinterlacer and should provide the results you want.
11th June 2017, 23:23 | #21896 | Link | |
Almost unbelievable that such small files (28 KB, 35 KB!) should do the trick. The one I found (libaacs.dll + libbdplus.dll), but didn't test yet, where distributed together with MPV and where each over 1.2 MB. I can't test it right now, but I assume it works for you ? What players are supported ? MPV, MPC-HC , MPC-BE, PotPlayer, VLC ,.. ? Last edited by Pat357; 11th June 2017 at 23:34. |
12th June 2017, 18:07 | #21897 | Link |
With Google, you will find e.g.
https://forum.kodi.tv/showthread.php?tid=189402 but this should not be discussed in detail here in this thread, because this here is all about LAV. If you find the time, just test it. |
12th June 2017, 22:43 | #21898 | Link |
Hello nevcairiel,
Could you add a way to enable/disable/configure acompressor in LAV Audio? https://ffmpeg.org/ffmpeg-filters.html#acompressor Last edited by sauma144; 12th June 2017 at 23:09. |
12th June 2017, 23:27 | #21899 | Link | |
