13th May 2011, 20:29 | #2881 | Link |
Well, in MPC-HC you would see it in the filter list. (Right Click the player -> Filters). It may also be hiding as the last entry with the name of the file, you can find out by opening the property page from there.
13th May 2011, 20:45 | #2882 | Link |
New buildzies
http://files.1f0.de/lavf/LAVFilters-...8-gfd5a9b3.zip Highlights (only LAV Audio changes): - A first draft of automatic A/V syncing when it detects an actual offset between our calculated timestamp and the timestamps from the incoming data. I *hope* this doesn't break anything, but i only tested MPEG-TS and MKV, other containers may go wildly wrong. The code is also very conservative, it may require up to 5-6 seconds for it to catch on to the sync problem, but IMHO thats alot better then having it re-sync a working video and causing issues. - The ability to use the ArcSoft dtsdecoder directly through LAV Audio, just drop "dtsdecoderdll.dll" in the LAV Audio directory, and lean back for full DTS-HD enjoyment. On the LAV Audio status page, the ffmpeg decoder is called "dca", and the ArcSoft decoder is called "dts" (or postfixed with the profile), so you can see if its active. Please note: Do not ask where to get the ArcSoft decoder. If you own TMT, its in the TMT folder under Codecs. If you don't, you should buy it if you want to use their decoder. This is *NOT* the place to try to score it for free. I respect their work, and so should you.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th May 2011 at 20:48. |
13th May 2011, 20:48 | #2883 | Link | |
I agree with Nev's comments about buying TMT if you use this. That will support their future development and allows us to use a really well developed decoder. Seems like a fair exchange. This is truly awesome. Thanks, Nev!
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 13th May 2011 at 20:54. |
13th May 2011, 21:11 | #2885 | Link |
Is it specific to any TMT version? Because I've dropped the 1.1.0.0 and the 1.1.0.7 and neither work.
I've unregistered LAV and registered again and still only show dca on the format page.. Not dts there. Am I missing anything? Bat
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
13th May 2011, 21:23 | #2887 | Link |
Oh, sorry.
Yeah, that's it. It shows dca with using LAV and dts-hd ma when using Arcsoft. Bat
13th May 2011, 22:08 | #2890 | Link |
AVC playback it's broken in some m2ts files with MPC-HC's internal decoder = black screen and audio
Changing the decoder to another one or changing the splitter to LAV's "official Version 0.25" or to MPC-HC's internal it's solving the problem Sample
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 13th May 2011 at 22:12. |
13th May 2011, 22:10 | #2891 | Link |
Don't you know better then "some m2ts files"?
13th May 2011, 22:19 | #2893 | Link |
I am presently decoding DTS-HD Master using LAV Splitter + Audio decoder and bitstreaming to my Denon AVP successfully.
Am I to assume that this combination is not actually passing the full audio resolution and adding the Arcsoft decoder does? Would someone mind clarifying this for me. Thanks. |
13th May 2011, 22:21 | #2894 | Link | |
I switched to official 0.25, and that file never plays properly with MPC-HC decoder. Although i don't get a black screen, i get some corrupted image.
MPC-HC internal splitter gives me black screen. I think the decoder just doesnt like the file.. Quote:
If you bitstream, that is your receiver does the decoding (you ticked the HDMI bitstreaming checkboxes in LAV Audio config), then you do not need to do anything, you'll get the full quality.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th May 2011 at 22:28. |
13th May 2011, 22:30 | #2895 | Link | |
Nevcairiel-LAVFSplitter-0.25-39-gd1a6c61 & MPC-HC's (1.5.2.3104) AVC (DXVA) it's broken = audio + black screen I'm using VS2010SP1 and gcc461 for both (Lav & MPC) P.S. The file it's straight from blu-ray (Hi-Definition Reference Disc) EDIT NON-DXVA it's working with Nevcairiel-LAVFSplitter-0.25-39-gd1a6c61 too !
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 13th May 2011 at 22:37. |
13th May 2011, 22:36 | #2897 | Link | |
I'll test a bit. Non-DXVA is broken for me with both the MPC-HC splitter and LAV Splitter. DXVA is only broken with LAV Splitter. I did try official 0.25, and no change. Maybe some change in ffmpeg. Edit: Nope, no changes, it remains broken. I blame the MPC decoder, its really far from usable these days.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th May 2011 at 22:40. |
13th May 2011, 22:45 | #2898 | Link |
So i figured something out. Setting the MPC-HC decoder to 1 thread fixes software playback with LAV Splitter. I didn't think the MPC-HC decoder used any threads. o.O
MPC-HC Splitter: Software broken, DXVA working LAV Splitter: Software working, DXVA broken I still couldn't get 0.25 working.. this is weird. :P
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 13th May 2011 at 22:48. |
13th May 2011, 23:06 | #2900 | Link |
I fixed it for now, will need some proper fix later.
