8th December 2011, 06:53 | #521 | Link |
LoRd_MuldeR, thanks for the exhaustive answer.
One more thing: I read that foreign characters are supported, did I do something wrong? »single flac to various mp3 » import cue sheet » write meta info to encoded files option, no m3u file generated. Used v4.04 Alpha-7. |
8th December 2011, 13:34 | #522 | Link |
Software Developer
Could you upload/attach the problematic CUE file please as-is?
LameXP handles Unicode characters properly, as long as the input is in the proper UTF-8 format. I suspect that this is not the case here Currently LameXP will assume that the input is UTF-8, iff a BOM is found. Otherwise it will interpret the input with your local 8-Bit Codepage - whatever that may be. I know this this isn't very reliable, but storing text files with some local 8-Bit Codepage is extremely error-prone anyway, because for the app reading the file later, it will be impossible to know the correct Codepage. Assuming that the "local" Codepage is the right one, is just a wild guess. But probably the best we can do. Using Unicode with proper UTF-8 encoding is the right way to store text files that contain "foreign" (Non-ASCII) characters! And a BOM should be prepended to indicate that this is UTF-8. Still the BOM is optional. Assuming that all text without a BOM is not UTF-8, is another wild guess. But again I don't know a better way... (BTW: As for the console, you won't see proper Unicode output there anyway, unless you change font to "Lucidia Console") [Small Update] I hacked together a quick workaround that may work for your case: http://www.mediafire.com/file/pqfj5o....Build-803.exe If LameXP assumes that the input is not UTF-8, it will now test whether decoding the input with the "local 8-Bit" Codepage results in any '�' (U+FFFD) characters. In that particular case we can assume that the "local 8-Bit" Codepage is not the suitable one and thus we will fall back to the "Latin-1" Codepage. There is absolutely no guarantee that the Latin-1 Codepage will work any better than the local one. It's just another try (and will succeed with Western European encodings).
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 8th December 2011 at 15:19. |
8th December 2011, 15:58 | #524 | Link |
Software Developer
As I had assumed, your CUE file is not Unicode/UTF-8, but plain Latin-1
On an English or German version of Windows (actually many more), the Latin-1 Codepage is configured as the "local" Codepage by default. That's why, on such systems, decoding the file with the "local" Codepage gives the desired result. And one might assume that this is always the case. But it's not! Other localized versions of Windows have a different Codepage configured by default, giving potentially very different output Solution: Open the CUE file in Notepad++, change the Encoding to the suitable one (here Latin-1) and then convert to UTF-8 (Unicode), with BOM.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 8th December 2011 at 16:00. |
9th December 2011, 01:41 | #525 | Link | |
Software Developer
LameXP v4.04 Alpha-7.1:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th December 2011 at 19:43. |
9th December 2011, 12:34 | #526 | Link |
I wanted to ask if you are going to implement an option for audio alignment. I had a .wav, encoded with LameXP to AAC, decoded to WAV back again, and compared both WAV in Audacity, and the second one had around 36ms positive delay. I didn't know this so everything I have done til now might be wrong
I was also looking for a list to know which encoders/decoders you use for each format. I gathered some links of interest. Questions about H.264 sync http://forum.doom9.org/showthread.php?t=156163 NeroAacEnc and delay added during encoding http://forum.doom9.org/showthread.php?t=144346 audio delay with mp4box http://forum.doom9.org/showthread.php?t=145435 Possible bug in nero encoder? http://forum.doom9.org/showthread.php?p=1420989 Audio Sync for MP3 and AAC files in AVISynth http://forum.doom9.org/showthread.php?p=1426169 |
9th December 2011, 14:26 | #527 | Link |
Software Developer
The extra delay is a common "problem" with (lossy) audio compression formats.
One reason for this is that these formats usually work with fixed-size (in samples) "frames", which they will transform into the frequency domain. But, because of the properties of the transform, overlapped transforms must be used and a so-called "window" function must be applied on the samples first. And for that reason, some extra samples before and after each frame are required. But before the very first frame, starting at the very first sample, there are none! That's why the encoder will prepend some "silent" samples in front of the very first input sample. And also append some after the last input sample. In the MP3 format, there is no "official" way to indicate how many extra samples were added, in order to have the decoder remove them. LAME has it's own way. (Whether an individual MP3 decoder will respect LAME's extra info header, that's a different question ^^) See also: * http://cas.web.cern.ch/cas/Denmark-2...%20CAS2010.pdf * http://lame.sourceforge.net/tech-FAQ.txt
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th December 2011 at 17:10. |
9th December 2011, 15:44 | #528 | Link |
So good, so it is just as padding in video processing. Now I understood better but the question is, will you add an option for this?
And the next question, where can I see all the modules used for each format in LameXP in order to know the possible settings, flaws, pros, cons, etc whynots. |
9th December 2011, 16:38 | #529 | Link | ||
Software Developer
If an audio encoder prepends samples to the source, it does this for good reason. It's a consequence of how audio compression works (seep previous post). There is no simple option to turn it off It is possible to cut off the padded samples later, after decoding. But only if the decoder can know how many samples had been added by the encoder. And this is a decoder feature, which is out of scope for LameXP. Unless, of course, we are talking about the decoding of the sources (original files) that you feed into LameXP for conversion. Actually I'm not quite sure whether the individual decoders used in LameXP, e.g. mpg123 for MP3 files or FAAD for AAC files, do remove padding, if possible. (At least for MP3 files encoded by LAME it is possible to accurately remove the padded samples at playback/decoding-time) Quote:
Anyway, all code of LameXP can be found at its Git repository: https://github.com/lordmulder/LameXP
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th December 2011 at 17:19. |
9th December 2011, 18:16 | #530 | Link |
Option to fix it. In post-processing for example, just an idea.
You don't know how the input was encoded, but you know how you are going to decode it (to wav) and encode it again. So there's room to make things nice in LameXP scope. I'm not sure, I just got to know about this bug (I consider it a bug) but I think the delay is a constant value so with a few tests you can get to know. But it's up to you to decide if this is LameXP scope, right now I think I can't use it anymore for my videos audio. Now it's only useful for music audio, and individual tracks of course, if you encode a session composed of tracks LameXP won't be suited either... Fortunately I now know about it, and can use workarounds, many people will still encode delayed audio without knowing aka doing the wrong thing. In video processing we also add some padding for some filters to comply the mod 16 requirement, or just to protect borders. But the padding is always cropped back after filtering. I think you call them Tools. https://github.com/lordmulder/LameXP...ster/res/tools You have some kind of a list more towards suppported formats rather than used tools for input/output formats http://gitorious.org/lamexp/lamexp/b...AQ.html#line39 That can make the cut if I were to test for delay issues and flag options. |
9th December 2011, 19:49 | #531 | Link | ||
Software Developer
And to make that clear: Any MP3 encoder (e.g. LAME) will cause an "encoder delay", though the delay may differ between different encoders. Also the front-end (e.g. LameXP) has no influence on that. The problem with MP3 in particular is that there is no "official" way to indicate the amount of padding that had been added by the encoder, so the decoder can't remove it! AFAIK in the design of Vorbis this has been handled much better, i.e. the "encoder delay" is stored in the stream in a standardized way and thus it will be removed properly by the decoder. I don't know what the situation with AAC is, but I guess it is more or less the same as with MP3... Some more info: http://en.wikipedia.org/wiki/Gapless_playback Quote:
Decode input -> Apply filters (if any) -> Encode output The "encoder delay" is added in the very last step, so it is impossible to implement any workaround, obviously. Except having LAME add it's header to the MP3 file - which it does by itself. Actually I just made a quick test and, indeed, the 'mpg123' decoder will respect the LAME header. Thus, if a LAME header is present, the padding samples are removed If you encode a Wave file to MP3 with LameXP (and thus with LAME) and then decode that MP3 file to Wave again with LameXP (and thus with mpg123), the sample count remains unchanged! You can try yourself with: Code:
lame.exe -V2 uncompressed.wav compressed.mp3 mpg123.exe -v -w decompressed.wav compressed.mp3 That's as much as we can do (If some other decoder will be used to decode the MP3 files produced by LameXP/LAME and that decoder ignores the LAME header, then we cannot do anything about that)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th December 2011 at 14:48. |
10th December 2011, 19:42 | #532 | Link | |
Software Developer
LameXP v4.04 Alpha-8:
http://sourceforge.net/projects/lame...29/2011-12-10/ Quote:
This has been fixed. Also, when importing a Cue Sheet that is not UTF-8 with a proper BOM, LameXP will now allow the user to choose the desired 8-Bit Codepage. For everybody who doesn't know what that means: You can simply keep "(System Default)" and click 'OK' when the Codepage dialog pops up
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th December 2011 at 20:08. |
10th December 2011, 23:15 | #534 | Link |
Software Developer
Thank you. Fixed
https://github.com/lordmulder/LameXP...92e5bd1#diff-9 BTW, I added some info about the "encoder delay" to the F.A.Q document: http://lamexp.git.sourceforge.net/gi...=HEAD#c6d9dfed
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 11th December 2011 at 14:06. |
11th December 2011, 19:41 | #535 | Link | |
In addition UTF-8 can be autodetected quite reliably, if you can parse it correctly as UTF-8 and you test text contains characters outside the ASCII range (>127) it almost certainly is UTF-8. |
11th December 2011, 20:04 | #536 | Link | ||
11th December 2011, 20:36 | #537 | Link | ||
0xEF,0xBB,0xBF is a valid combination to represent UTF-8 content. Quote:
11th December 2011, 20:43 | #538 | Link |
Software Developer
@Reimar:
Yes, the BOM symbol in UTF-8 does not serve to indicate the Byte Order (there is no Byte Order in single-byte sequences, yes) and it's optional. Still it's a valid character and often present. So if an UTF-8 BOM is found, we can assume that the text is UTF-8 indeed. The probability to find a UTF-8 BOM sequence just "by chance" is negligible. In the other case, when there is no UTF-8 BOM present, the text may still be valid UTF-8. But it maybe "some" local 8-Bit codepage just as well. It may not even be encoded in the Windows ANSI Codepage that happens to be configured on the individual computer. For all these reasons, if no UTF-8 BOM is found, LameXP will now pop up a small dialog, allowing the user to select the desired Codepage. @Dogway: I'm always thankful for bug-reports, including typos. But, as a matter of fact, I can only update the English and German translations. For all other languages I have to rely on other people to send my updated/corrected language files
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 11th December 2011 at 20:52. |
11th December 2011, 20:54 | #540 | Link |
Software Developer
Ideally I should. Practically I think that is "nice to have" but over the top
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
