Old 6th March 2018, 18:19   #61  |  Link
l33tmeatwad
l33tmeatwad's Avatar
That patch appears to be working.
l33tmeatwad is offline   Reply With Quote
Old 6th March 2018, 20:40   #62  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Okay, I pushed it. Thanks for testing.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 6th March 2018, 20:58   #63  |  Link
l33tmeatwad
Thank you for fixing it, I've been trying to get that fixed since April of last year, lol...
Old 6th March 2018, 21:31   #64  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Fix is by Stephen R. Savage, I just pushed it.
Old 8th March 2018, 22:01   #65  |  Link
halls
Nice!
Thank you!
And now?
What can i do to fix my blue haze????
halls is offline   Reply With Quote
Old 8th March 2018, 22:02   #66  |  Link
Selur
Selur's Avatar
@halls: be patient and wait for l33tmeatwad to update the installer
Old 9th March 2018, 15:47   #67  |  Link
halls
Thank You Selur!
And thank you everyone who helps solve this problem!
Old 9th March 2018, 16:47   #68  |  Link
l33tmeatwad
Sorry for the delay, I have been busy and plan to include a lot more than just this fix in the next update. I will get it up as soon as I can.
Old 10th March 2018, 21:29   #69  |  Link
McCauley
Thank you - I appreciate your time going into this. I as well suffer from the blue screen problem like user "halls" does.
Looking forward to the update!
McCauley is offline   Reply With Quote
Old 12th March 2018, 08:51   #70  |  Link
Selur
Selur's Avatar
@l33tmeatwad: would be nice if you could also include some uninstaller (script/pkg/whatever) to the package.
Alternatively can someone recommend a tool which could be used to easily uninstall the package?
Old 12th March 2018, 20:29   #71  |  Link
l33tmeatwad
All of the VapourSynth files are all stored in /Library/Frameworks/Vapoursynth.framework, so deleting that will remove most of it. The stand alone applications are stored in the applications folder. The remaining parts of the install are the symbolic links created in /usr/local/lib and /usr/local/bin.
Old 13th March 2018, 01:22   #72  |  Link
l33tmeatwad
Installer has been updated. I included a lot of the requested plugins, but any that required extras or would not compile and would require extra time to figure out were not included for now.
Old 13th March 2018, 07:50   #73  |  Link
Selur
Selur's Avatar
Thanks!
Old 13th March 2018, 09:32   #74  |  Link
Selur
Selur's Avatar
Can't find ffmsindex anywhere, did I miss it or did you forget about it?
Cu Selur
Old 13th March 2018, 14:46   #75  |  Link
l33tmeatwad
Cu Selur
I'll get that fixed along with another file that was being put in the wrong location and get it updated in the next day or so.
Old 13th March 2018, 14:54   #76  |  Link
Selur
Selur's Avatar
Not here,...
macmini:Applications selur$ ls /Library/Frameworks/VapourSynth.framework/bin/
2to3			easy_install-3.6	pip3			python3-config		python3.6m		pyvenv-3.6
2to3-3.6		idle3			pip3.6			python3.6		python3.6m-config	vspipe
cython			idle3.6			python3			python3.6-config	pyvenv
reinstalled VapourSynth_R43_180312.pkg to make sure,...
Cu Selur
Old 14th March 2018, 02:14   #77  |  Link
l33tmeatwad
Just updated the installer with ffmsindex and fixed the issue where one file was written to \Library\Frameworks\VapourSynth.frameworks instead of \Library\Frameworks\VapourSynth.framework. If you installed the old package feel free to delete that extra folder.
Old 14th March 2018, 11:41   #78  |  Link
Selur
Selur's Avatar
Thanks!
Old 14th March 2018, 18:24   #79  |  Link
Selur
Selur's Avatar
ffmsindex is missing a library,..
this happens when I call ffmsindex inside a terminal:
dyld: Library not loaded: /Library/Frameworks/VapourSynth.framework/lib/libffms2.4.dylib
  Referenced from: /usr/local/bin/ffmsindex
  Reason: image not found
Abort trap: 6
Cu Selur
Old 14th March 2018, 18:39   #80  |  Link
l33tmeatwad
Abort trap: 6
Cu Selur
Yeah, I forgot to check on that after patching the plugin itself. I will update the installer tonight, but the fix if you don't want to re-download the new one is:
sudo ln -s /Library/Frameworks/VapourSynth.framework/lib/vapoursynth/libffms2.dylib /Library/Frameworks/VapourSynth.framework/lib/libffms2.4.dylib
I will be adding that to the installer script. Hopefully that is the LAST change for now.
