Old 28th March 2016, 20:13   #23841  |  Link
Defcon0
Hello folks,
I gave the 3d support of bd rb a try, but no success The movie's been "Jurassic World 3D". After backing up to 25 GB the film was in 2D and the tv offered to display it in a 2D-to-3D-conversion
Am I doing something wrong? Is more info needed? Is this normal behavior?
Defcon0 is offline   Reply With Quote
Old 28th March 2016, 20:19   #23842  |  Link
Post your log and your settings. What player are you using? Some software players have issues with different types of 3D structures. The only real test is with a 3D standalone player connected to a 3D monitor.
Old 28th March 2016, 20:26   #23843  |  Link
Defcon0
At first I tried my standalone Sony BD Player (updated and approx. 2 years old) in combination with my standalone 3D-ready Philips TV (also approx. 2 years old). In PowerDVD I tried the 50 GB ISO file of the disc also with no success.
Settings attached.
File Type: zip BDREBUILDER.zip (579 Bytes, 21 views)
Old 28th March 2016, 22:06   #23844  |  Link
I use a 2 year old Sony player on my system as well.. and I've never had an issue with a single encode.
Old 28th March 2016, 23:28   #23845  |  Link
omegaman7
omegaman7's Avatar
I had no trouble with Jurassic World 3D.
Old 28th March 2016, 23:35   #23846  |  Link
Sharc
Settings attached.
Post the .log. You posted the .ini only.
Old 29th March 2016, 19:08   #23847  |  Link
bobross
Getting a tsmuxer.exe crash when I try and do a full 50GB backup
Windows 10 x64
[03/29/16] BD Rebuilder v0.50.14
[10:48:57] Source: THE_HATEFUL_EIGHT
- Input BD size: 43.84 GB
- Approximate total content: [03:05:08.222]
- Target BD size: 46.26 GB
- Windows Version: 6.2 [9200]
- Quality: Highest (Very Slow), ABR
[10:48:57] PHASE ONE, Encoding
- [10:48:57] Processing: VID_00000 (1 of 3)
- [10:48:57] Extracting A/V streams [VID_00000]
- Error in attempt to extract audio/subs.
- Network Optix tsMuxeR. Version 2.6.12. www.networkoptix.com
[10:49:03] - Failed to retrieve audio, aborted
bobross is offline   Reply With Quote
Old 29th March 2016, 19:54   #23848  |  Link
Sharc
@bobross
Is your source a Blu-Ray disc?
Old 29th March 2016, 20:21   #23849  |  Link
It sounds like the source is corrupted, or isn't decrypted properly.
Old 29th March 2016, 20:50   #23850  |  Link
bobross
@bobross
Yes it is the original BR
Old 29th March 2016, 20:51   #23851  |  Link
bobross
Ah, Hmm I thought I could back to an ISO with encryption intact?
Old 29th March 2016, 20:52   #23852  |  Link
omegaman7
omegaman7's Avatar
Yes, but ONLY anydvd can handle those files. You wouldn't be able to burn and play it on a standalone.
Old 29th March 2016, 20:59   #23853  |  Link
Ch3vr0n
Well he can burn it back to a BD50 just fine with things like ImgBurn, but you're right it wouldn't play. @bobross that's exactly what the protection is designed NOT to let you do, burn the encrypted content back to disc and play it. It wouldn't be much of a protection if it allowed you to do that. Mount the encrypted ISO back in AnyDVD, enable AnyDVD on the virtual drive and let it decrypt. Then BDRB will be able to process it. But if all you want to do is burn it back to a BD50, why use BDRB at all. Mount the disc in a virtual drive, start ImgBurn in build mode, point it to the virtual drive and hit burn. All done.
Old 29th March 2016, 21:22   #23854  |  Link
bobross
Yes I am ok with that, I'm just wondering why its crashing when I try and rip it with encryption.
Old 29th March 2016, 21:24   #23855  |  Link
bobross
That is the problem, the current version of AnyDVD does not support this disc yet so I want to rip it for decryption later. And the AnyDVD site is not accepting purchases right now the latest version is also for current license holders....
Old 29th March 2016, 21:32   #23856  |  Link
Ch3vr0n
Then you're posting in the wrong forum, you need to post over at the RedFox forums and most a logfile so they can add support. Purchasing is irrelevant to that unless you're using a trial. Logfile processing had been going on normally for a while now. Unless there's some other reason you're not doing that. No logfile, no fix.
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 29th March 2016, 21:45   #23857  |  Link
bobross
Hey sorry, think I'm being misunderstood. My initial post is why BD Rebuilder is crashing with this disc under the assumption the the copy protection does not matter, I'll keep it for now. Nothing to do with AnyDVD, other people just started bringing it up.
Old 29th March 2016, 21:49   #23858  |  Link
Ch3vr0n
Either way, if you want that disc supported you'll have to provide a logfile at the RedFox forums. No log, no fix.
Old 30th March 2016, 07:57   #23859  |  Link
meadrocks
Hateful Eight
I ripped it with RedFox 7.6.9.5 & didn't have any problem.
meadrocks is offline   Reply With Quote
Old 30th March 2016, 15:57   #23860  |  Link
Ch3vr0n
Then you may have a different version. Not every disc is the same.
Verstuurd vanaf mijn Nexus 5 met Tapatalk
