20th February 2017, 08:59 | #25642 | Link |
I think I got confirmation on something I've always wanted to ask: can the user-set settings of LAV filters (outside of BD-RB) interfere with a a backup? I completed a backup (I've deleted it) of a Blu-Ray with 1080i/25fps content and everything played in slow motion in the backup. This also happens with "Preview this item" in BD-RB.
In the LAV Video Configuration, I have Software Deinterlacing/YADIF enabled. If I disable it, the Preview plays fine in BD-RB with this Blu-Ray and I assume a new backup will also work fine. Can BD-RB ignore the LAV user-settings or do the LAV Filters always need to be set in a specific way?
Win 10 Pro x64 Last edited by Weirdo; 20th February 2017 at 09:02. |
20th February 2017, 11:12 | #25646 | Link |
Just created another backup and indeed it works perfectly with YADIF disabled in the LAV settings. The problem is obviously with the interlaced videos. Also note that when YADIF is enabled on the 25p/30p setting, the problem also doesn't appear. My original setting was 50p/60p, and that's what causes trouble.
Win 10 Pro x64 |
20th February 2017, 15:38 | #25649 | Link | |
I'd need an example and your settings to test it. Last edited by jdobbs; 20th February 2017 at 15:41. |
20th February 2017, 16:00 | #25650 | Link |
---------------------- [02-20-17] BD Rebuilder v0.50.23 [10:25:44] Source: - Input BD size: 20.40 GB - Approximate total content: [03:29:08.428] - Target BD size: 4.36 GB - Windows Version: 6.2 [9200] - Resize: 1080p to 720p enabled - Quality: Better (Faster), CRF - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640 [10:25:58] PHASE ONE, Encoding - [10:25:58] Processing: VID_00002 (1 of 26) - [10:25:58] Extracting A/V streams [VID_00002] - [10:26:23] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25.000fps, 10,941 frames - Convert: 1280x720, 50.000fps, 21,882 frames - [10:26:23] Encoding using constant rate factor. - [10:33:27] Video Encode complete - [10:33:27] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:33:27] Multiplexing M2TS - [10:33:33] Blanking: VID_00011 (2 of 26) - [10:33:33] Blanking: VID_00012 (3 of 26) - [10:33:33] Blanking: VID_00013 (4 of 26) - [10:33:33] Processing: VID_00019 (5 of 26) - [10:33:33] Extracting A/V streams [VID_00019] - [10:33:39] Reencoding video [VID_00019] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,051 frames - [10:33:39] Encoding using constant rate factor. - [10:34:31] Video Encode complete - [10:34:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - [10:34:31] Multiplexing M2TS - [10:34:35] Processing: VID_00021 (6 of 26) - [10:34:35] Extracting A/V streams [VID_00021] - [10:34:39] Reencoding video [VID_00021] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 240 frames - [10:34:39] Encoding using constant rate factor. - [10:34:44] Video Encode complete - [10:34:44] Processing audio tracks - [10:34:44] Multiplexing M2TS - [10:34:48] Blanking: VID_00072 (7 of 26) - [10:34:48] Blanking: VID_00079 (8 of 26) - [10:34:48] Blanking: VID_00080 (9 of 26) - [10:34:48] Processing: VID_00087 (10 of 26) - [10:34:48] Extracting A/V streams [VID_00087] - [10:36:13] Reencoding video [VID_00087] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25.000fps, 48,678 frames - Convert: 1280x720, 50.000fps, 97,356 frames - [10:36:13] Encoding using constant rate factor. - [11:07:51] Video Encode complete - [11:07:51] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:07:51] Multiplexing M2TS - [11:08:05] Blanking: VID_00098 (11 of 26) - [11:08:05] Processing: VID_00099 (12 of 26) - [11:08:05] Extracting A/V streams [VID_00099] - [11:08:50] Reencoding video [VID_00099] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 27,414 frames - Convert: 1280x720, 24.000fps, 27,414 frames - [11:08:50] Encoding using constant rate factor. - [11:20:49] Video Encode complete - [11:20:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:20:49] Multiplexing M2TS - [11:20:57] Processing: VID_00100 (13 of 26) - [11:20:57] Extracting A/V streams [VID_00100] - [11:21:08] Reencoding video [VID_00100] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 4,617 frames - Convert: 1280x720, 24.000fps, 4,617 frames - [11:21:08] Encoding using constant rate factor. - [11:24:11] Video Encode complete - [11:24:11] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:24:11] Multiplexing M2TS - [11:24:16] Processing: VID_00101 (14 of 26) - [11:24:16] Extracting A/V streams [VID_00101] - [11:24:28] Reencoding video [VID_00101] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 5,178 frames - Convert: 1280x720, 24.000fps, 5,178 frames - [11:24:28] Encoding using constant rate factor. - [11:27:26] Video Encode complete - [11:27:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:27:26] Multiplexing M2TS - [11:27:30] Processing: VID_00102 (15 of 26) - [11:27:30] Extracting A/V streams [VID_00102] - [11:27:39] Reencoding video [VID_00102] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 3,061 frames - Convert: 1280x720, 24.000fps, 3,061 frames - [11:27:39] Encoding using constant rate factor. - [11:29:18] Video Encode complete - [11:29:18] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:29:18] Multiplexing M2TS - [11:29:22] Processing: VID_00103 (16 of 26) - [11:29:22] Extracting A/V streams [VID_00103] - [11:29:36] Reencoding video [VID_00103] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 6,792 frames - Convert: 1280x720, 24.000fps, 6,792 frames - [11:29:36] Encoding using constant rate factor. - [11:33:34] Video Encode complete - [11:33:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:33:34] Multiplexing M2TS - [11:33:39] Processing: VID_00104 (17 of 26) - [11:33:39] Extracting A/V streams [VID_00104] - [11:33:51] Reencoding video [VID_00104] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 5,287 frames - Convert: 1280x720, 24.000fps, 5,287 frames - [11:33:51] Encoding using constant rate factor. - [11:36:53] Video Encode complete - [11:36:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:36:53] Multiplexing M2TS - [11:36:57] Processing: VID_00105 (18 of 26) - [11:36:57] Extracting A/V streams [VID_00105] - [11:37:10] Reencoding video [VID_00105] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 5,715 frames - Convert: 1280x720, 24.000fps, 5,715 frames - [11:37:10] Encoding using constant rate factor. - [11:40:11] Video Encode complete - [11:40:11] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:40:11] Multiplexing M2TS - [11:40:16] Processing: VID_00106 (19 of 26) - [11:40:16] Extracting A/V streams [VID_00106] - [11:40:28] Reencoding video [VID_00106] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 4,825 frames - Convert: 1280x720, 24.000fps, 4,825 frames - [11:40:28] Encoding using constant rate factor. - [11:43:26] Video Encode complete - [11:43:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:43:26] Multiplexing M2TS - [11:43:31] Processing: VID_00107 (20 of 26) - [11:43:31] Extracting A/V streams [VID_00107] - [11:43:42] Reencoding video [VID_00107] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 4,727 frames - Convert: 1280x720, 24.000fps, 4,727 frames - [11:43:42] Encoding using constant rate factor. - [11:46:10] Video Encode complete - [11:46:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:46:10] Multiplexing M2TS - [11:46:15] Processing: VID_00108 (21 of 26) - [11:46:15] Extracting A/V streams [VID_00108] - [11:46:24] Reencoding video [VID_00108] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 3,738 frames - Convert: 1280x720, 24.000fps, 3,738 frames - [11:46:24] Encoding using constant rate factor. - [11:48:37] Video Encode complete - [11:48:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:48:37] Multiplexing M2TS - [11:48:41] Processing: VID_00109 (22 of 26) - [11:48:41] Extracting A/V streams [VID_00109] - [11:48:54] Reencoding video [VID_00109] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 4,936 frames - Convert: 1280x720, 24.000fps, 4,936 frames - [11:48:54] Encoding using constant rate factor. - [11:51:51] Video Encode complete - [11:51:51] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:51:51] Multiplexing M2TS - [11:51:55] Processing: VID_00110 (23 of 26) - [11:51:55] Extracting A/V streams [VID_00110] - [11:52:07] Reencoding video [VID_00110] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 4,640 frames - Convert: 1280x720, 24.000fps, 4,640 frames - [11:52:07] Encoding using constant rate factor. - [11:54:59] Video Encode complete - [11:54:59] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:54:59] Multiplexing M2TS - [11:55:04] Processing: VID_00111 (24 of 26) - [11:55:04] Extracting A/V streams [VID_00111] - [11:55:13] Reencoding video [VID_00111] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 3,340 frames - Convert: 1280x720, 24.000fps, 3,340 frames - [11:55:13] Encoding using constant rate factor. - [11:57:16] Video Encode complete - [11:57:16] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:57:16] Multiplexing M2TS - [11:57:21] Processing: VID_00112 (25 of 26) - [11:57:21] Extracting A/V streams [VID_00112] - [11:57:31] Reencoding video [VID_00112] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 3,988 frames - Convert: 1280x720, 24.000fps, 3,988 frames - [11:57:31] Encoding using constant rate factor. - [11:59:37] Video Encode complete - [11:59:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:59:37] Multiplexing M2TS - [11:59:41] Processing: VID_00113 (26 of 26) - [11:59:41] Extracting A/V streams [VID_00113] - [11:59:55] Reencoding video [VID_00113] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24.000fps, 6,479 frames - Convert: 1280x720, 24.000fps, 6,479 frames - [11:59:55] Encoding using constant rate factor. - [12:03:34] Video Encode complete - [12:03:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:03:34] Multiplexing M2TS [12:03:39]PHASE ONE complete [12:03:39]PHASE TWO - Rebuild Started - [12:03:39] Rebuilding BD file Structure [12:03:41] - Encode and Rebuild complete - WORKFILES folder removed. [12:03:41] JOB: finished. [02-20-17] Checking System Settings - BD-Rebuilder v0.50.23 - Windows Version: 6.2 [9200] - Working Path Free Space: 50.76GB - AVISYNTH Version: 2.6.0.5, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [02-20-17] Systems Settings Check complete
Win 10 Pro x64 |
20th February 2017, 16:03 | #25651 | Link |
Can you post your settings (the contents of the BDREBUILDER.INI file)?
Note this in your log, it's probably the root of the problem: - Resize: 1080p to 720p enabled - Convert: 1280x720, 50.000fps, 21,882 frames Last edited by jdobbs; 20th February 2017 at 16:06. |
20th February 2017, 16:10 | #25652 | Link | |
[Options] ENABLE_TEST=1 VERSION=0.50.0.23 FORCE_ENCODE=1 FIXED_CRF=19 ENCODER=0 MODE=0 ENCODE_QUALITY=1 ONEPASS_ENCODING=1 AUTO_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=1 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 WIDE_PERCENT=100 WIDE_OFFSET=1 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=7000 MINIMIZE_TO_TRAY=1 TARGET_SIZE=4469 PGSTOSRT=0 ENABLE_BLANKING=1 PRIORITY_CLASS=1 MOVIEONLY_TYPE=11 ALTCRF=19 ALT_TARGET=1024 ALT_CRF_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 [Paths] SOURCE_PATH= WORKING_PATH=
Win 10 Pro x64 |
20th February 2017, 17:39 | #25653 | Link |
1920x2160i output from 1080i source
I've not posted before, but recently experiencing some issues, all 1080i source related (both 23.97 & 29.97fps content). This started happening with v0.50.19, which prompted a switch to v0.50.23 but with same results. The output video is 1920x2160i, fps is unchanged, but audio is then out of sync with video (audio plays faster, I think). I'm using all suggested ffdshow settings. Any help or suggestions would be greatly appreciated. Thanks.
My BD-RB settings are as follows: VERSION=0.50.0.23 ENCODER=0 MODE=0 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=4 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 SHUTDOWN_SLEEP=1 CUSTOM_TARGET_SIZE=4574 TARGET_SIZE=26550 AUTO_BURN=0 |
20th February 2017, 18:54 | #25654 | Link | |
# The options below show up in the Alternate Output Dialog # Settings: # caption=Text to show on alternate selection list # vEncoder=Video encoder, 0=x264 (default), 1=x265, 2=HC Encoder (MPEG-2) # Note: A cType of 3 or 4 (see below) forces MPEG-2 via HCEncoder # vBitrate=Bitrate to use for two-pass video encoding, * = variable (DVD only) # aBitrate=Bitrate to use for audio encoding, * = automatic (constant quality encode, not allowed for iPod & iPad) # aType=Output Audio Type, 0=AC3, 1=AAC (Note: Audio bitrate less than 384Kbs implies stereo downmix) # 2=[Intact audio -- MKV & MP4 only] # vFormat=Video Format: 0=320x240/180, 1= 480x360/270, 2= 640x480/360, 3= 1024x768/576, # 4= 1280x720, 5= 1920x1080, 6= 720x480/576, 7= No Resizing, 8=Intact # vKeyint=Video GOP size (interval): Default=24, "Auto" = 10x framerate (MKV & MP4 only) # cType= Container/limits type, 0=iPod (mp4), 1=MKV, 2=iPad (mp4), 3=DVD-5, 4=DVD-9, 5=MP4 6=iPad 2+ (MP4) [00001] caption=DVD-5, 720x480/576, AC3 Audio vBitrate=* aBitrate=* aType=0 vFormat=6 cType=3 [00002] caption=DVD-9, 720x480/576, AC3 Audio vBitrate=* aBitrate=* aType=0 vFormat=6 cType=4 [00003] caption=iPod MP4, 640x480/360, 128Kbs AAC vBitrate=583 aBitrate=128 aType=1 vFormat=2 cType=0 [00004] caption=iPod MP4, 480x360/270, 112Kbs AAC vBitrate=421 aBitrate=112 aType=1 vFormat=1 cType=0 [00005] caption=iPod MP4, 320x240/180, 64Kbs AAC vBitrate=281 aBitrate=96 aType=1 vFormat=0 cType=0 [00006] caption=MKV Container, 720x480/576, 128Kbs AC3 vBitrate=872 aBitrate=128 aType=0 vFormat=6 cType=1 [00007] caption=MKV Container, 1280x720, 192Kbs AC3 vBitrate=1230 aBitrate=192 aType=0 vFormat=4 cType=1 [00008] caption=MKV Container, 1280x720, 448Kbs DD5.1 vBitrate=1230 aBitrate=448 aType=0 vFormat=4 cType=1 [00009] caption=MKV Container, 1920x1080, 192Kbs AC3 vBitrate=1941 aBitrate=192 aType=0 vFormat=5 cType=1 [00010] caption=MKV Container, 1920x1080, 640Kbs DD5.1 vBitrate=1941 aBitrate=640 aType=0 vFormat=5 cType=1 [00011] caption=MKV Container, 1920x1080, Intact Audio vBitrate=3000 aBitrate=0 aType=2 vFormat=5 cType=1 [00012] caption=iPad MP4 HD, 1280x720, 128Kbs AAC vBitrate=1500 aBitrate=128 aType=1 vFormat=4 cType=2 [00013] caption=iPad MP4 HD, 1024x768/576, 128Kbs AAC vBitrate=1009 aBitrate=128 aType=1 vFormat=3 cType=2 [00014] caption=iPad MP4 SD, 640x480/360, 128Kbs AAC vBitrate=583 aBitrate=128 aType=1 vFormat=2 cType=2 [00015] caption=iPad MP4 SD, 480x360/270, 112Kbs AAC vBitrate=421 aBitrate=112 aType=1 vFormat=1 cType=2 [00016] caption=iPad MP4 SD, 720x480/576, 128Kbs AAC vBitrate=872 aBitrate=128 aType=1 vFormat=6 cType=2 [00017] caption=MKV Container, 1920x1080, Auto-AAC vBitrate=3000 aBitrate=* aType=1 vFormat=5 cType=1 [00018] caption=MKV Container, 1280x720, Auto-AAC vBitrate=2000 aBitrate=* aType=1 vFormat=4 cType=1 [00019] caption=MP4 Container, 1920x1080, AutoGOP, Auto-AAC vBitrate=3000 aBitrate=* aType=1 vFormat=5 vKeyint=Auto cType=5 [00020] caption=MP4 Container, 1280x720, AutoGOP, Auto-AAC vBitrate=2000 aBitrate=* aType=1 vFormat=4 vKeyint=Auto cType=5 [00021] caption=MP4 Container, NO_RESIZE, AutoGOP, Auto-AAC vBitrate=2000 aBitrate=* aType=1 vFormat=7 vKeyint=Auto cType=5 [00022] caption=MKV Container, NO_RESIZE, AutoGOP, Auto-AAC vBitrate=2000 aBitrate=* aType=1 vFormat=7 vKeyint=Auto cType=1 [00023] caption=iPad 2+/iPhone 4s+, 1920x1080, 160Kbs AAC vBitrate=3000 aBitrate=160 aType=1 vFormat=5 cType=6 [00024] caption=iPad 2+/iPhone 4s+, 1280x720, 128Kbs AAC vBitrate=2000 aBitrate=128 aType=1 vFormat=4 cType=6 [00025] caption=iPad 2+/iPhone 4s+, 720x480/576, 128Kbs AAC vBitrate=872 aBitrate=128 aType=1 vFormat=6 cType=6 [00026] caption=MP4, Intact Video, AutoGOP, Auto-AAC vBitrate=2000 aBitrate=* aType=1 vFormat=8 vKeyint=Auto cType=5 [00027] caption=MKV, Intact Video, AutoGOP, Auto-AAC vBitrate=2000 aBitrate=* aType=1 vFormat=8 vKeyint=Auto cType=1 [00028] caption=MKV, Intact Video, Intact Audio aType=2 vFormat=8 cType=1 [00029] caption=MP4, Intact Video, Intact Audio aType=2 vFormat=8 cType=5 [00030] caption=MKV Container, 720x480/576, Intact Audio vBitrate=872 aType=2 vFormat=6 cType=1 [00031] caption=MP4 Container, Full-SBS (3D), Intact Audio vBitrate=4000 aType=2 vFormat=7 cType=5 [00032] caption=MKV Container, Full-SBS (3D), Intact Audio vBitrate=4000 aType=2 vFormat=7 cType=1 [00033] caption=MKV Container, HEVC 1920x1080, Auto-AAC vEncoder=1 vBitrate=2000 vKeyint=Auto aBitrate=* aType=1 vFormat=5 cType=1 [00034] caption=MKV Container, HEVC 1280x720, Auto-AAC vEncoder=1 vBitrate=1300 vKeyint=Auto aBitrate=* aType=1 vFormat=4 cType=1 [00035] caption=MKV Container, HEVC Full-SBS 3D,Auto-AAC vEncoder=1 vBitrate=2000 vKeyint=Auto aType=1 aBitrate=* vFormat=7 cType=1 [00036] caption=MKV Container, HEVC Half-SBS 3D, Intact Audio vEncoder=1 vBitrate=2000 vKeyint=Auto aType=2 vFormat=5 cType=1 [00037] caption=MKV Container, NO_RESIZE, AutoGOP, Auto-AC3 vBitrate=2000 aBitrate=* aType=0 vFormat=7 vKeyint=Auto cType=1 [00038] caption=MP4 Container, NO_RESIZE, AutoGOP, Auto-AC3 vBitrate=2000 aBitrate=* aType=0 vFormat=7 vKeyint=Auto cType=5 [00039] caption=MKV Container, HEVC 1920x1080, 448Kbs DD5.1 vEncoder=1 vBitrate=2000 vKeyint=Auto aBitrate=448 aType=0 vFormat=5 cType=1 INSPECT --> [02/20/17] Checking System Settings - BD-Rebuilder v0.50.23 - Windows Version: 6.2 [9200] - Working Path Free Space: 3*242,76GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [02/20/17] Systems Settings Check complete On the other hand it takes me by default not the video bonn of the film, it takes me a long version! Last edited by jdobbs; 20th February 2017 at 23:33. |
20th February 2017, 19:02 | #25655 | Link | |
2. Audio plays faster? I don't see how that is even possible -- it is never adjusted. Last edited by jdobbs; 20th February 2017 at 19:08. |
20th February 2017, 20:55 | #25656 | Link | |
2. By audio playing faster, I mean relative to the video image, after BD-RB processing. The audio becomes out of sync with video very quickly when starting from the beginning. I just noticed there is the "IVTC with 3:2 pulldown" option in setup menu, which I've not tried before, should I try it to see what the output looks like? Thanks. |
20th February 2017, 22:12 | #25657 | Link | |
Are you using a Blu-Ray disc as your source, or are you importing first? |
20th February 2017, 22:28 | #25658 | Link | |
So, I misspoke in my earlier post. The BD-RB processed video playback is faster than the audio, not the other way around. Sorry. And, thinking about it more, the IVTC with 3:2 pulldown option won't help since I'm not looking to convert into a "film". Apologize for the brain fart. Thanks. |
20th February 2017, 23:33 | #25659 | Link | |
21st February 2017, 00:05 | #25660 | Link |
Ok, here are 2 logs: (1) used BD-RB on just the main movie, (2) used BD-RB on blu-ray disk image:
---------------------- [02/05/17] BD Rebuilder v0.50.23 [21:56:10] Source: SUPER_HUMMINGBIRDS_PCM - Input BD size: 13.04 GB - Approximate total content: [00:52:59.209] - Target BD size: 4.58 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), Two Pass - SHUTDOWN at completion enabled - Decoding/Frame serving: FRIMSource - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [21:56:10] PHASE ONE, Encoding - [21:56:10] Processing: VID_00000 (1 of 1) - [21:56:10] Extracting A/V streams [VID_00000] - [21:58:30] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 95,281 frames - Bitrate: 10,749 Kbs - [21:58:30] Reencoding: VID_00000, Pass 1 of 2 - [22:29:47] Reencoding: VID_00000, Pass 2 of 2 - [23:43:09] Video Encode complete - [23:43:09] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [23:43:26] Multiplexing M2TS [23:44:11]PHASE ONE complete [23:44:11]PHASE TWO - Rebuild Started - [23:44:11] Rebuilding BD file Structure [23:44:11] - Encode and Rebuild complete - Computer SLEEP initiated. [06:11:41] JOB: SUPER_HUMMINGBIRDS_DTS-CORE finished. ---------------------- [02/06/17] BD Rebuilder v0.50.23 [06:30:12] Source: SUPER_HUMMINGBIRDS - Input BD size: 14.18 GB - Approximate total content: [00:54:09.421] - Target BD size: 4.53 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), Two Pass - SHUTDOWN at completion enabled - Decoding/Frame serving: FRIMSource - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [06:30:12] PHASE ONE, Encoding - [06:30:12] Processing: VID_00000 (1 of 5) - [06:30:12] Extracting A/V streams [VID_00000] - [06:30:20] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 1,382 frames - Bitrate: 10,762 Kbs - [06:30:20] Reencoding: VID_00000, Pass 1 of 2 - [06:30:52] Reencoding: VID_00000, Pass 2 of 2 - [06:32:07] Video Encode complete - [06:32:07] Processing audio tracks - Track 4352 (und): Keeping original audio - [06:32:07] Multiplexing M2TS - [06:32:12] Processing: VID_00001 (2 of 5) - [06:32:12] Extracting A/V streams [VID_00001] - [06:32:15] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 217 frames - Bitrate: 632 Kbs - [06:32:15] Reencoding: VID_00001, Pass 1 of 2 - [06:32:17] Reencoding: VID_00001, Pass 2 of 2 - [06:32:19] Video Encode complete - [06:32:19] Processing audio tracks - [06:32:19] Multiplexing M2TS - [06:32:23] Processing: VID_00002 (3 of 5) - [06:32:23] Extracting A/V streams [VID_00002] - [06:32:27] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 225 frames - Bitrate: 7,998 Kbs - [06:32:27] Reencoding: VID_00002, Pass 1 of 2 - [06:32:32] Reencoding: VID_00002, Pass 2 of 2 - [06:32:42] Video Encode complete - [06:32:42] Processing audio tracks - Track 4352 (und): Reencoding audio to AC3... - [06:32:42] Multiplexing M2TS - [06:32:46] Processing: VID_00003 (4 of 5) - [06:32:46] Extracting A/V streams [VID_00003] - [06:32:50] Reencoding video [VID_00003] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 225 frames - Bitrate: 9,086 Kbs - [06:32:50] Reencoding: VID_00003, Pass 1 of 2 - [06:32:55] Reencoding: VID_00003, Pass 2 of 2 - [06:33:05] Video Encode complete - [06:33:05] Processing audio tracks - Track 4352 (und): Reencoding audio to AC3... - [06:33:06] Multiplexing M2TS - [06:33:09] Processing: VID_00004 (5 of 5) - [06:33:09] Extracting A/V streams [VID_00004] - [06:35:31] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 95,282 frames - Bitrate: 10,394 Kbs - [06:35:31] Reencoding: VID_00004, Pass 1 of 2 - [07:07:29] Reencoding: VID_00004, Pass 2 of 2 - [08:20:37] Video Encode complete - [08:20:37] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [08:20:56] Multiplexing M2TS [08:22:08]PHASE ONE complete [08:22:08]PHASE TWO - Rebuild Started - [08:22:08] Rebuilding BD file Structure [08:22:08] - Encode and Rebuild complete - Computer SLEEP initiated. [08:34:25] JOB: SUPER_HUMMINGBIRDS finished. Thanks very much for your help. |
