Old 22nd May 2020, 10:32   #18541  |  Link
slalom
slalom's Avatar
You can add a file twice
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 25th May 2020, 12:27   #18542  |  Link
ReinerSchweinlin
Hy there,
Ripbot really has become a workhorse in my workflows and I canīt thank you enough for this wonderfull tool
I whipped up some old servers and cranked them up with a lot of CPUs to assist the encoding farm. So far so good. These servers now have a really nice "Sleep mode" with the ability for "wake on LAN". It takes around 15 sec. Until they are online.
Is there a way to tell Ripbot to initially "ping" a server to wake him up and then start the encoding? At the moment, Ripbot thinks itīs sleeping - the inital call does wake the server up, though, but not quick enough for ripbot top recognice it.
if I hit the button in the Encoding Client manually after a while, it picks the server up... Maybe simply ping all servers once before the initial "copy video stream to temp" process?
Thanx
Old 25th May 2020, 14:52   #18543  |  Link
Have you tried auto reconnect option?
or
Old 26th May 2020, 09:31   #18544  |  Link
Pino72
have been using RB for some time now. Apart from update problems when one PC was on a different version than the other PC for DE it worked really well.
I am mainly reencoding 4K UHD files to lower bit rates keeping all the pixel sizes etc. Only video processing no audio and subtitles etc.
Now since a while I have some really weird behaviours on certain UHd files when I am using DE, my main PC is doing fine all the time (8 Core 9900K), my second PC (4 Core 6700K) is doing strange stuff on certain but not all chunks.
The end result is a file that is playable but has some picture freezes in terms of decoding seems to have stopped for the whole chunk with a more or less black screen.
When I am letting my main PC process the chunk it does it correctly, my second PC does not. To compare it I let them decode the same chunk and am posting the .txt file here and hope to find a solution as to why this is happening and how I can avoid this. Both RB PC's are on the same version of Win 10 and same RB version with the latest updates.
Encoding started...
""\\AQUAPC-9900\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\AQUAPC-9900\RipBot264temp\job5\Chunks\1.avs" -strict -1 -f yuv4mpegpipe - | "\\AQUAPC-9900\Ripbot264temp\tools\x265\x265_x64.exe" --seek 0 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1)" --pass 1 --bitrate 25000 --stats "\\AQUAPC-9900\RipBot264temp\job5\Chunks\1.stats" --fps 24000/1001  --min-keyint 24 --keyint 240 --frames 1424 --sar 1:1 --profile main10 --output-depth 10  --ctu 64 --merange 57 --no-slow-firstpass --y4m --pools "+" --output NUL -"
y4m  [info]: 3840x1600 fps 24000/1001 i420p10 sar 1:1 unknown frame count
raw  [info]: output file: NUL
x265 [info]: HEVC encoder version 3.2+34-8e6db24c1517
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [warning]: Turning on repeat-headers for HDR compatibility
x265 [info]: Main 10 profile, Level-5 (Main tier)
x265 [info]: Thread pool created using 16 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 4 / wpp(25 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge         : dia / 57 / 2 / 1
x265 [info]: Keyframe min / max / scenecut / bias  : 24 / 240 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt        : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 0
x265 [info]: References / ref-limit  cu / depth  : 1 / off / on
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 2 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress            : ABR-25000 kbps / 0.60
x265 [info]: tools: rd=2 psy-rd=2.00 early-skip rskip signhide tmvp b-intra
x265 [info]: tools: fast-intra strong-intra-smoothing lslices=8 deblock sao
x265 [info]: tools: stats-write
x265 [info]: frame I:      8, Avg QP:9.25  kb/s: 45911.50
x265 [info]: frame P:    351, Avg QP:3.09  kb/s: 47679.73
x265 [info]: frame B:   1065, Avg QP:8.66  kb/s: 12120.18
x265 [info]: Weighted P-Frames: Y:19.4% UV:12.0%
x265 [info]: consecutive B-frames: 13.6% 4.7% 11.4% 11.7% 58.5%
encoded 1424 frames, 7.58 fps, 21075.05 kbps
Encoding started...
x265 [info]: Thread pool created using 8 threads
x265 [info]: frame threads / pool features       : 3 / wpp(25 rows)
x265 [info]: frame I:      6, Avg QP:13.97  kb/s: 654.90
x265 [info]: frame P:    465, Avg QP:4.52  kb/s: 36.56
x265 [info]: frame B:    953, Avg QP:10.59  kb/s: 28.62
x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0%
x265 [info]: consecutive B-frames: 30.8% 6.6% 27.0% 0.8% 34.8%
encoded 1424 frames, 20.61 fps, 33.85 kbps
As you can see on the second PC the kbps is very low, luckily I can see this on DE while it is doing the job and can prevent it.
Any idea why he does not weight the P-Frames here?
THanks for this great tool and hope to get it wokring for DE soon, help is very welcome.
Cheers
Pino72 is offline   Reply With Quote
Old 26th May 2020, 14:24   #18545  |  Link
On 6700k open "\\AQUAPC-9900\RipBot264temp\job5\Chunks\1.avs" in mpc-hc. What do you get ? Are you sure that both pcs have the same avisynth versions? Does regular mode (non-de) work on 6700k?
Old 27th May 2020, 15:51   #18546  |  Link
Pino72
Hi Atak,
thank you for your reply. Indeed playing back the .avs file on the 6700k PC is not working, just gives me a green screen. Playing back the same .avs file on the 9900k is working fine it shows the video. On the other side encoding the file is working locally on the 6700K just fine.
Any suggestions? Something wrong with temp folders etc?
I checked all Tools in the setting menu of RB and everything was on the same version number. Not sure if Avisynth is also listed there or if I should check somewhere else? On other files DE still works fine though but not on all, really strange. So its not related to this one specific movie.
Old 27th May 2020, 15:56   #18547  |  Link
Pino72
I copied over the whole Avisynth and Avisynth Plugin folder from the ripbot tools folder from the 9900k to the 6700k PC...no difference.
Old 27th May 2020, 18:33   #18548  |  Link
Do you have this issue only in 4k/UHD resolution? Do you use GPU decoding or CPU decoding on AQUAPC-9900?
Old 28th May 2020, 08:41   #18549  |  Link
Pino72
Yes only in 4K resolutions (so far at least, but not all 4K files), indeed I have everything on GPU decoding on the 9900K except for OTHER and everything on CPU on the 6700K. Using a GTX 1050 on the 9900K and a RTX 2060 on the 6700K.
I now switched everything on all PC's to CPU decoding and it seems to work now.
Old 28th May 2020, 11:56   #18550  |  Link
ReinerSchweinlin
Thanx - that might do the trick, didn`t think of it. Will try when back at the rig. Thank you !
Old 2nd June 2020, 00:03   #18551  |  Link
slow4mula2002
Thanks for the great app Atak been using it for years. I was wondering if it would be possible to add support for output of BDMV m2ts or ISO for backing up UHD bluray to BD-R 25/50gb. I usually just backup UHD to mkv but I've done a few test backups using makemkv and dvdfab 11 to BD-R that play in my standalone UHD bluray player. It seems ripbot264 already has most of this capability. Is this possible?
slow4mula2002 is offline   Reply With Quote
Old 2nd June 2020, 11:20   #18552  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Hi slow4mula2002,
You can choose AVCHD when creating a new job, that will create your .mt2s's in a Bluray compatible folders.
Or you could run the end result thru tsmuxer to create an .iso.
Live every day like it's your last, because one day, it will be !! (M$B)
Old 3rd June 2020, 18:51   #18553  |  Link
GazzaCOP
Been using RB for a handful of months and it's become my go-to encoding software with killer features for me being Tonemapping and DE, although I've encoded with Handbrake for years. So, I'm moving on now to encoding in a slightly advanced manner - namely using the following script to MDegrain3 certain of my encodes, principally older movies with plenty of grain.
LoadPlugin("C:\RipBot264\Tools\AviSynth plugins\mvtools\mvtools2.dll")
super=MSuper(video,pel=2)
bv1=MAnalyse(super,isb=true,delta=1,overlap=4)
fv1=MAnalyse(super,isb=false,delta=1,overlap=4)
bv2=MAnalyse(super,isb=true,delta=2,overlap=4)
fv2=MAnalyse(super,isb=false,delta=2,overlap=4)
bv3=MAnalyse(super,isb=true,delta=3,overlap=4)
fv3=MAnalyse(super,isb=false,delta=3,overlap=4)
video=MDegrain3(video,super,bv1,fv1,bv2,fv2,bv3,fv3,thSAD=800)
It all works beautifully but I'm having to copy and paste the script every time into the AVISynth '#denoise' section in the AVISynth video window which is a pain, especially if I forget. Is there a way to get my 'MDegrain3 custom script' into the DENOISE dropdown box next to the window so I can just select it rather than copy/paste each time? Or is there another method I could use? (I've set up a specific X265 profile to introduce --aq-mode 3 although naturally the X265 script doesn't influence the script passed to AVISynth).
Incidentally I find KNLmeansCL hopeless...either one or both my servers regularly stalls when I engage KNLmeansCL....no biggy, MDegrain is good for me.
GazzaCOP is offline   Reply With Quote
Old 3rd June 2020, 19:18   #18554  |  Link
1) in notepad paste
#denoise
2) save as mdegrain3.avs in /avisynth plugins/scripts/custom folder (im writing from my head)
3) select your custom script from combobox on last page.
Old 3rd June 2020, 19:58   #18555  |  Link
GazzaCOP
Of course, custom scripts, it works perfectly and so logical. Many thanks and a donation is on its way
Old 4th June 2020, 06:46   #18556  |  Link
slow4mula2002
Originally Posted by Pauly Dunne View Post
Hi slow4mula2002,
AVCHD output is only an option when you encode to x264. When encoding to hevc the only output available is mkv.
Old 4th June 2020, 07:48   #18557  |  Link
Pauly Dunne
Grumpy Old Man.
OK, fair point, but you didn't mention x265/HEVC !!!
You can still run the end result thru tsmuxer to generate either .m2ts or an .iso !!!
Yeah, I got that wrong, tsmuxer does NOT output to .iso...
Old 5th June 2020, 04:18   #18558  |  Link
slow4mula2002
Yeah I said UHD bluray idk why anyone would encode hevc from a UHD bluray to h264...makes no sense. There might be a way to re-encode UHD with HD audio to m2ts using free tools but I haven't been able to locate a method that would consistently work. DVDfab does the job I'm describing well but it's a bit pricey. I might just have to purchase if I decide this is something I'd like to do.
I understand AVCHD is a "standard" so atak was kind enough to include this in his app but there is no "standard" for backing up a UHD bluray to BD-R 25/50.
If I open a mkv with tsmuxer with a truehd audio track then it isn't recognized so that also does not work. All of my mkvs have the original HD audio.
Old 5th June 2020, 07:43   #18559  |  Link
Pauly Dunne
Grumpy Old Man.
Yeah, sorry 'bout that, you DID mention UHD several times, I guess I generally refer to them as 4K disks.
I haven't got any equipment that can play TrueHD, so I rip out the THD track, and convert it to DTS-HD 7.1, then you can remux it back in with either RB, or tsmuxer (for m2ts), or MKVToolNix (for mkv). All with "free" tools. !!!
I think you'll find that some of the very latest tsmuxer builds (nightly) will support TrueHD under certain conditions.
I have done many "conversion's" like this, works very well, just a little time consuming.
Not too sure why you'd then want to "burn" back onto an optical disk.
Each to their own, I guess.
Old 5th June 2020, 22:16   #18560  |  Link
slow4mula2002
I don't want to convert the main HD audio track. I've tried every tsmuxer build I can find and none seem to recognize the dolby true hd/atmos audio tracks. It seems like it would possible to add this capability to this GUI but if there isn't a big enough audience then it is what it is. The capability to encode back to HEVC/retain original audio track and output m2ts in bluray structure.
Why burn back to optical disk..well like I said I usually just output to mkv but possibly higher quality on a single layer bd-r (22.5gb) for what I would typically create a mkv or retain intact hevc/audio with a dual layer bd-r (45gb). Why did people ever backup bluray to AVCHD? Same reason here. It's nice to be able to take a UHD bluray backup and play it at a friends house in their UHD player. No usb drives or hard drives hoping their device supports the mkv.
