Old 18th February 2016, 18:24   #1  |  Link
mushahidh
Is there a way to prioritize video frames?
Hi experts,
As we see different videos in our daily life , the obvious fact is that not every frame contains equal amount of important information. I am trying to apply a protection to video frames based on their importance in video.For that i need to prioritize a frame based on criteria(which i don't know yet). What i want to know is there any quantitative measure that can calculate frame importance or priority in video streams?
mushahidh is offline   Reply With Quote
Old 18th February 2016, 22:02   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
If with "prioritize" you mean that you want to give certain frames a higher quality (more bits) as compared to the rest, then --qpfile is what you are looking for:
https://en.wikibooks.org/wiki/MeGUI/...ettings#qpfile
And, if you want to do this on a per-macroblock basis instead of a per-frame basis, we are talking about ROI (region of interest) encoding. This is only possible via API, not via CLI.
How to decide which frames (or regions) you want to "prioritize", that's a totally different question and can only be answered with more context...
Old 19th February 2016, 10:18   #3  |  Link
mushahidh
Thanks for your answer. I want to add more on it. Say for instance in foreman sequence. Initially, there isn't much movement between the frames. So loss of one frame when there isn't much difference between the lost frame and previous frame won't make much difference. But in case of sudden change between the frames and previous frame in much more different from coming frame than lost of one frame cause much more problem. So i want to prioritize video frames based on the data inside it with respect to previous frame.
Hope you understand.
Old 19th February 2016, 10:53   #4  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Would this be like for security videos?
Motion tracking, per se?
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline   Reply With Quote
Old 19th February 2016, 11:50   #5  |  Link
mushahidh
Not actually. Again to be more clear. For example I have IPPP structure and GOP contains 30 frames. And as we know first I frame is much more important than P frames so i will give more priority to first I frame. Then for remaining P frames initial P frames are more important than last P frames. So on what basis can i define a threshold so that i can say initial 25% percent P frames are much important that last 25% of frames?
Old 19th February 2016, 17:58   #6  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
So, number of frames referenced is a metric you are looking for.
I believe mbtree is basically this, except on per macroblock basis.
Old 19th February 2016, 19:22   #7  |  Link
mushahidh
Yeah thanks for giving me right direction. But after having some go through of this paper i start believing that it won't be so much easy if i am using encoder other than x264.
Old 19th February 2016, 19:55   #8  |  Link
LoRd_MuldeR
Software Developer
This is called "rate control" and "frame type decision". Every (halfway decent) video encoder does this by default
You only need a --qpfile option (or ROI encoding), if you want to overwrite the encoder's rate control and/or frame type decisions, in some specific places.
See also:
* http://git.videolan.org/?p=x264.git;...atecontrol.txt (a bit outdated, but still gives the idea)
* https://web.archive.org/web/20120910...cx/archives/98
Old 21st February 2016, 15:16   #9  |  Link
kuchikirukia
I think someone needs some b-frames.
kuchikirukia is offline   Reply With Quote
frames, h.264, perceived resolution
