Old 5th March 2007, 15:40   #21  |  Link
clsid
There have been some fixes in libfaad2, so that should at least be updated. Celtic_Druid's build also uses latest libfaad2. As for the other libs, if they introduce new bugs, then I am sure we will discover them.
MPC-HC 2.2.1
clsid is offline
Old 5th March 2007, 16:20   #22  |  Link
_xxl
ffdshow user
_xxl's Avatar
mpc
New MPC 611 build 03.05.2007.*updated*
basemuxer-ssf-removal.patch
basevideofilter.patch
dts.patch
dtsac3patch.patch
dvobsub.patch
faad2.25.patch or faad2.26.patch
libmad.patch
libpng.patch
mpc_ffdshow20061015.patch
mpc_ffdshow20061222.patch
mpeg2decfilter_dsutil_interlaced_fix.patch
mpeg2decfilter_progressive_frames_fix.patch
mpegsplitterfile.patch
mpegsplitterfile2.patch
radgtsplitter-removal.patch
vp62-removal.patch
vsfilter_clipbug-patch-take3.patch
vsfilter_fax_fay-svn611v2.patch
_xxl is offline
Old 5th March 2007, 16:36   #23  |  Link
Peuj
Peuj's Avatar
Peuj is offline
Old 5th March 2007, 16:45   #24  |  Link
fastplayer
Latest MPC UPXed
UPXed version (--best parameter) of drevil_xxl's MPC build (see here). For those situations where every byte counts
Download
Last edited by fastplayer; 25th March 2007 at 13:25. Reason: Updated to latest patched build.
fastplayer is offline
Old 5th March 2007, 19:07   #25  |  Link
Inventive Software
Turkey Machine
Location: Lowestoft, UK (but visit lots of places with bribes [beer])
@moderator: Can MPC discussion be split to another thread?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 5th March 2007, 23:01   #26  |  Link
HeadBangeR77
HeadBangeR77's Avatar
I second that, however I think these last two pages could be joined with the main MPC's thread in the Software forum, which will revive it for sure (it's up to mods to decide)
@ drevil
Thank you for the next release!
"Only two things are infinite: the universe and human stupidity, and I'm not sure about the former."
HeadBangeR77 is offline
Old 6th March 2007, 00:53   #27  |  Link
Mangix
Audiophile
this new release uses FAAD 2.6, right?
Mangix is offline
Old 6th March 2007, 01:12   #28  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Media Player Classic v6.4.9.0 rev611 2007-03-05:
mplayerc.2007-03-05.drevil_xxl.7z
mirrored
LoRd_MuldeR is offline
Old 15th March 2007, 00:52   #29  |  Link
MatMaul
hello !
MPC:
download
Patches:
download
I have a problem with this MPC build.
when I want to play an ac3 file, it doesn't play : ligos MPEG splitter is charged as filter (??) and ffdshow (which is my ac3 decoder) isn't charged.
With last celtic_druid build, no problem, ffdshow is charged and the file is playing fine.
MatMaul is offline
Old 15th March 2007, 07:07   #30  |  Link
_xxl
ffdshow user
_xxl's Avatar
I''ll compile soon a new build.
_xxl is offline
Old 16th March 2007, 14:19   #31  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Split from ffdshow tryouts.
Hey, this is the same way drevil kickstarted the tryouts project.
foxyshadis is offline
Old 19th March 2007, 11:09   #32  |  Link
B.F.
B.F.'s Avatar
How about a light version?
Only with codecs needed for DVD playing.
B.F. is offline
Old 19th March 2007, 13:11   #33  |  Link
thuan
I second that as I rarely use the other filters included in MPC.
thuan is offline
Old 19th March 2007, 16:23   #34  |  Link
clsid
Why cripple it? Don't expect it to become a much smaller file.
MPC-HC 2.2.1
clsid is offline
Old 20th March 2007, 00:30   #35  |  Link
thuan
Simply because I never use the other filters included in MPC beside those used for DVD decoding.
thuan is offline
Old 20th March 2007, 02:55   #36  |  Link
B.F.
B.F.'s Avatar
Maybe.
But still it will be smaller, and I don't have to disable that filters manually.
B.F. is offline
Old 20th March 2007, 08:53   #37  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Originally Posted by B.F. View Post
Maybe.
Make sure you call that build "DVD Player Classic", though...
Of course, once you store your settings in an ini file you don't even have to reconfigure everything everywhere - just reuse the ini file...
now playing: [artist] - [track] ([album])
Leak is offline
Old 20th March 2007, 09:03   #38  |  Link
B.F.
B.F.'s Avatar
MPC is almost useless without external codecs like ffdshow.
It's not a all in one player like mplayer based players.
B.F. is offline
Old 21st March 2007, 09:46   #39  |  Link
thuan
I don't like the ini options because it's slower. With registry options you can back up your settings too. Just go to HKCU\Software\Gabest and back up the whole thing. As B.F. said MPC is useless without external codec not like mplayer or kmplayer and most of the included is useless for me anyway beside those used for DVD decoding. I don't care about the binary size but I just see those filters as "eyesore".
thuan is offline
Old 21st March 2007, 10:06   #40  |  Link
Leak
Leak's Avatar
Could you explain that one further? I really doubt reading the registry is noticeably faster than reading a miniscule file from disc...
Leak is offline
dxva, h264, home cinema, media player classic, mpc-hc
