Old 2nd January 2021, 15:04   #7921  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by Greenhorn View Post
The table is out-of-date/wrong. Limit-refs 3 is only used on "Slow" these days. Everything else uses 3 (slower, medium and lower) or none (veryslow/placebo.)
@kurogane: it's just saying that a setting used by the preset is incompatible with pmode. It should probably be setting it to "1" instead of disabling it entirely, but you can use both features and the slow preset all together just by setting --preset slow --limit-refs 1 --pmode.
--preset slower applies --limit-refs 1. I'm using it right now in my encodes and I don't have any separate --limit-refs call. The info section shows this:
x265 [info]: References / ref-limit cu / depth : 4 / off / on
Old 2nd January 2021, 18:55   #7922  |  Link
Greenhorn
Typo in my post. Woops.
Greenhorn is offline   Reply With Quote
Old 6th January 2021, 04:23   #7923  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
For those of you that use AVID Media Composer, from version 2020.12 it's possible to link and edit H.265 files. Considering that H.265 was released more than 8 years ago, it's about time, AVID! They should have done this long time ago!! What took them so long...?! -.- Still, habemus H.265 import support at last...
Old 6th January 2021, 23:37   #7924  |  Link
Barough
Barough's Avatar
x265 v3.4+36-5239276dd (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.2.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/Release_3.5
Old 7th January 2021, 10:15   #7925  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by FranceBB View Post
I guess we're gonna have to wait 'till someone will upload a sample, then...
In case anyone is still interested in files produced by Iphone 12, here it is:
They're indeed in Dolby Vision with the HLG profile, so BT2020nc HLG HDR 4:2:0 10bit planar in H.265.
Too bad for the VFR stuff which mobiles seem to love and everyone else in the world hates... (especially us, working in broadcast!)
I'm not in the edit room in which I have an HDR monitor and scope, so I can't tell you exactly how many nits there actually are, but Apple claims to reach 699 nits...
I think they're way too many for such a tiny sensor. From a very quick analysis, it looks like it's more or less 300 nits, which, for a mobile phone, looks quite alright.
For the records: this is from a colleague of mine who bought it, I actually went for a Google Pixel 5 in early November.
Old 8th January 2021, 03:48   #7926  |  Link
quietvoid
Updated my scenecut-aware-qp patch, now applies directly on Release 3.5 @ 5239276
Old 8th January 2021, 14:36   #7927  |  Link
Because the Yuuki mod appears to be well maintained, I tried to download and build this one alternatively in an interactive shell in MABS. Unfortunately, in contrast to the original x265 git, this modified fork apparently needs Ruby. A compatible version was found in the MSYS2 installation of MABS (2.7.0; minimum required is 1.8.0); but several include directories were missing, so cmake halted. I guess I could make it work if I knew where to include which shell variable exports?
Old 8th January 2021, 18:52   #7928  |  Link
MeteorRain
結城有紀
>tree /f D:\dev\x265-Yuuki-Asuna\include
D:\DEV\X265-YUUKI-ASUNA\INCLUDE
│  lsmash.h
├─avisynth
│  │  avisynth.h
│  │  avisynth_c.h
│  └─avs
│          alignment.h
│          capi.h
│          config.h
│          cpuid.h
│          minmax.h
│          posix.h
│          types.h
│          win.h
└─vapoursynth
        VapourSynth.h
        VSHelper.h
        VSScript.h
You'll need those to support avs/vpy/lsmash. ffmpeg input on msvc wasn't tested.
For msvc multi lib build you need to
-DLSMASH_SOURCE_DIR=../../x265-Yuuki-Asuna/include -DEXTRA_LINK_FLAGS="/LIBPATH:../../../x265-Yuuki-Asuna/lib-msvc /LIBPATH:.."
something like that.
For gcc you just compile and make install dependencies into system directories. That includes ffmpeg, avisynth (header only), vapoursynth(header only), lsmash.
Ruby script was to compose version number, so it's not absolute necessary and can be replaced by you own code to produce your own version number. I use Ruby because I'm a Ruby developer.
It may not be easy to use yuuki mod in mabs due to extra libraries being linked.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 9th January 2021, 01:48   #7929  |  Link
One hurdle after another ... the first one looked rather low to me, as a layman:
-- Could NOT find Ruby (missing: Ruby_INCLUDE_DIR Ruby_LIBRARY Ruby_CONFIG_INCLUDE_DIR) (found suitable version "2.7.2", minimum required is "1.8.0")
If that is all cmake complains about, I guess it can be solved. Then we will see further from there.
Old 10th January 2021, 18:52   #7930  |  Link
MeteorRain
結城有紀
Says found suitable version, so I guess it's just fine? I have the mingw-w64-x86_64-ruby package installed from pacman, and it works.
Projects
Old 10th January 2021, 22:18   #7931  |  Link
Well, the Ruby package as such is installed, but it misses configured environment variables. Therefore cmake halts.
Old 11th January 2021, 07:42   #7932  |  Link
MeteorRain
結城有紀
That's weird. I'm getting a similar error but cmake did generate all the project files without any problem.
-- Found Nasm 2.15.05 to build assembly primitives
-- Could NOT find Ruby (missing: Ruby_LIBRARY) (found suitable version "2.7.1", minimum required is "1.8.0")
-- x265 version 3.4+13-g729a838d3+38
Projects
Old 11th January 2021, 09:59   #7933  |  Link
So maybe the reason is somewhere else, like the cmake command line may need more explicit parameters than the vanilla x265 multilib configuration.
-- Found nasm: E:/MABS/msys64/mingw64/bin/nasm.exe (found version "2.15.05")
CMake Deprecation Warning at dynamicHDR10/CMakeLists.txt:13 (cmake_minimum_required):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
-- Found Git: E:/MABS/msys64/usr/bin/git.exe (found version "2.30.0")
-- x265 Release Version
-- The ASM_NASM compiler identification is NASM
-- Found assembler: E:/MABS/msys64/mingw64/bin/nasm.exe
-- Looking for strtok_r
-- Looking for strtok_r - found
CMake Error at CMakeLists.txt:637 (list):
  list GET given empty list
CMake Error at CMakeLists.txt:638 (list):
-- Configuring incomplete, errors occurred!
See also "E:/MABS/x265-Yuuki-Asuna-Yuuki/build/msys64_hdr10_ml/12bit/CMakeFiles/CMakeOutput.log".
See also "E:/MABS/x265-Yuuki-Asuna-Yuuki/build/msys64_hdr10_ml/12bit/CMakeFiles/CMakeError.log".
make: *** No targets specified and no makefile found.  Stop.
cp: cannot stat 'libx265.a': No such file or directory
make: *** No rule to make target 'clean-generated'.  Stop.
Shall we discuss this elsewhere? A new thread here? An issue in your github repo?
Old 11th January 2021, 18:23   #7934  |  Link
MeteorRain
結城有紀
Please open an issue ticket.
EDIT:
Actually, I think you are on the wrong branch. Please switch to Asuna branch to test. Yuuki branch is not ready yet because 3.5 is not ready yet. As soon as 3.5 is tagged I'm going to revise the version generation code, which should solve the issue you are seeing.
Projects
Old 12th January 2021, 10:04   #7935  |  Link
The Asuna branch passed.
PS: OK, adding a few parameters of the modification may break the attempt, e.g. L-SMASH headers need to be found if I want to enable MP4 output...
Seems I could create a build with AVS and VPY input and MKV output, yet without LAVF input and without MP4 output. And with unknown version. To be tested...
Works with AviSynth input and MKV output.
Old 12th January 2021, 18:56   #7936  |  Link
MeteorRain
結城有紀
FYI: MKV output is not supported and is provided as best effort because one of my friends actively uses it. I was thinking maybe I should add a warning message saying it's unsupported.
If possible, please try to integrate l-smash using the flags above (post #7944).
Projects
Old 12th January 2021, 21:01   #7937  |  Link
Your repo does not provide an include directory, so I tried to configure the cmake flags to use the liblsmash git directory which is retrieved by MABS when building all its projects, up to ffmpeg:
-DENABLE_LSMASH=ON -DLSMASH_SOURCE_DIR=/build/liblsmash-git/
Configuring finished, make started ... all these NASM warnings are a PITA ... hmm, no. Obviously I have no clue how to point to the lsmash.h file so that it is found:
In file included from F:/MABS/x265-Yuuki-Asuna-Asuna/source/output/output.cpp:44:
F:/MABS/x265-Yuuki-Asuna-Asuna/source/output/mp4.h:8:10: fatal error: lsmash.h: No such file or directory
    8 | #include <lsmash.h>
compilation terminated.
Maybe due to:
CMake Warning:
  Manually-specified variables were not used by the project:
    LSMASH_SOURCE_DIR
Trying again with additional -DSPECIFY_LSMASH_SOURCE_DIR=ON
Next hurdle: I guess MABS used liblsmash somewhere but did not make and install it separately, so it is not a registered package.
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -llsmash
Ran make install-lib and trying again without explicitly specifying lsmash directory...
Meh. Did not help. Without explicit source dir it doesn't find the header, with it it can't link the library. "It's complicated"...
Old 13th January 2021, 05:52   #7938  |  Link
MeteorRain
結城有紀
Ooooh you are using GCC.
>make install-lib
install -d /mingw64/include
install -m 644 ./lsmash.h /mingw64/include
install -d /mingw64/lib/pkgconfig
install -m 644 liblsmash.pc /mingw64/lib/pkgconfig
install -m 644 liblsmash.a /mingw64/lib
You should be able to find those 3 files in the corresponding directories, and GCC should automatically find them. Can you confirm they are there?
Try this and see if pkg-config gets you the command line.
pkg-config --libs liblsmash
Projects
Old 13th January 2021, 08:42   #7939  |  Link
Yes, the media-autobuild suite is based on MSYS2, MinGW, and usually GCC (could use clang if configured). And I even run the interactive shell instead of patching the automated build scripts. So I mostly profit from MABS keeping MSYS2/MinGW and GCC and all projects linked into ffmpeg up-to-date, before sometimes also experimenting interactively.
Using ./configure without extra parameters, it gets installed into /usr/local ... I guess I should add a parameter to change the prefix, because MABS uses /local64 (or /local32) as target directories.
OK, MABS requires e.g. ./configure --prefix="/local64" to install the header and library where the packages are expected. Compilation seems to be successful.
Old 13th January 2021, 19:27   #7940  |  Link
Last missing puzzle piece: Linking issues with libav libraries ... but ffmpeg had been built before and has been found by the compiler. So the reason must be in a different magnitude.
[ 96%] Linking CXX executable x265.exe
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x11): undefined reference to `avcodec_free_context'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1a): undefined reference to `avformat_close_input'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x19d): undefined reference to `av_init_packet'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1c0): undefined reference to `avcodec_receive_frame'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1d8): undefined reference to `av_read_frame'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x1f4): undefined reference to `av_packet_unref'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x204): undefined reference to `av_init_packet'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x226): undefined reference to `avcodec_send_packet'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x23d): undefined reference to `avcodec_receive_frame'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x2a4): undefined reference to `av_packet_unref'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x2b8): undefined reference to `av_packet_unref'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4aa): undefined reference to `avcodec_find_decoder'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4ba): undefined reference to `avcodec_alloc_context3'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4d3): undefined reference to `avcodec_parameters_to_context'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x4e7): undefined reference to `avcodec_open2'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x5ad): undefined reference to `av_packet_unref'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x60c): undefined reference to `av_frame_alloc'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x62e): undefined reference to `avformat_open_input'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x64b): undefined reference to `avformat_find_stream_info'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x6c9): undefined reference to `avcodec_find_decoder'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x6d8): undefined reference to `avcodec_alloc_context3'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x6f4): undefined reference to `avcodec_parameters_to_context'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x707): undefined reference to `avcodec_open2'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x72c): undefined reference to `av_dict_set'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x73f): undefined reference to `avcodec_open2'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x761): undefined reference to `av_dict_free'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x82b): undefined reference to `av_pix_fmt_desc_get'
F:/MABS/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/10.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: CMakeFiles/cli.dir/objects.a(lavf.cpp.obj):lavf.cpp:(.text+0x2c): undefined reference to `av_frame_free'
collect2.exe: error: ld returned 1 exit status
