Old 14th January 2021, 19:48   #7941  |  Link
MeteorRain
結城有紀
I have no idea about that. Maybe check if the lib files are correctly found by gcc.
The error message looks like it didn't find the lib and thus missed the reference to its functions.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 14th January 2021, 20:32   #7942  |  Link
DJATOM
DJATOM's Avatar
Undefined reference usually means that symbol is not reachable. For example, there is no library with such names supplied to the linker. Check generated build files if all needed ffmpeg libs are actually provided for linking.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 14th January 2021, 21:59   #7943  |  Link
Which are these "build files"?
Old 15th January 2021, 00:18   #7944  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
If a C/C++ application depends on library 'XYZ', the you will need to do two things:
  • At compile-time, you need to ensure that the required header files (usually .h or .hpp) for library XYZ are present in one of the directories that the compiler scans for header files.
    Additional search directories for header files can be specified by adding the -I option to the CFLAGS.
  • At link-time, you need to ensure that library XYZ is actually linked to your binary. This is done by adding the -l option your LDFLAGS.
    Note that -l automatically adds the "lib..." prefix as well as the file extension. So, in order to link against libXYZ.a, you just need to write -lXYZ.
    Furthermore, you have to make sure that the library file (usually .a) is present in one of the directories that the linker scans for library files.
    Additional search directories for library files can be specified by adding the -L option to the LDLAGS.
Of course you will need to build library 'XYZ' before you build your "main" application, because otherwise the required library file libXYZ.a (the "build file") has not been created yet
Yes, "undefined reference" could mean that a required library was not linked at all. Could also mean that you are linking a "wrong" version of the library which doesn't match to the header files that were used.
(If you try to link against a library, but the linker couldn't find the requested library file, it would be a different error message)
Another "fun" thing needs to be considered: Libraries can be compiled as either a "static" library (.a) or a "shared" library (.dll). Specifically on Windows, the actual symbol names differ between the "static" and "shared" libraries! Usually the header files support both variants, via #ifdef's, but default often is the "shared" variant. So, a special #define needs to be set, at compile-time, if you intend to link against the "static" library. Could also be the other way around tough
Old 15th January 2021, 01:56   #7945  |  Link
DJATOM
DJATOM's Avatar
If you're using mingw (as I am), they are in the generated build folder. For example, CMakeFiles\cli.dir\linklibs.rsp. If you generated msvc project, it's somewhere in the linker options.
Me on GitHub
Old 15th January 2021, 08:55   #7946  |  Link
The only *.rsp files I see are objects1.rsp in 8bit/CMakeFiles/x265-shared.dir (I'm trying to make a multi-lib static build). It contains only obj files created by the basic x265 compilation.
With -DENABLE_AVISYNTH=ON in the cmake configuration, the x265.exe contains avs_ symbols; AviSynth+ headers are present in local includes.
With -DENABLE_VPYSYNTH=ON in the cmake configuration, the x265.exe contains vsscript_ symbols; libvapoursynth.a + vapoursynth[-script].pc are present in local libs[/pkgconfig].
With -DENABLE_LSMASH=ON in the cmake configuration, the x265.exe contains LSMASH_ symbols and even a version number (printed in the version console output); liblsmash{a|pc} are present in local libs[/pkgconfig].
With -DENABLE_ZIMG=ON in the cmake configuration, the x265.exe contains zimg5graph12_ symbols; libzimg.a + zimg.pc are present in local libs[/pkgconfig].
All that works without any other *.rsp files.
{libavcodec|libavdevice|libavfilter|libavformat|libavif|libavutil}.{a|pc} are present in local libs[/pkgconfig]. Apparently, with -DENABLE_LAVF=ON in the cmake configuration, cmake detects them (or would error out otherwise), so I assume ld can find them like all the other libraries (especially like lsmash and zlib). Headers and libraries should match because MABS compiled a whole ffmpeg the other day, before I tried to build x265_Asuna afterwards. Therefore I agree with:
The only doubt I have left: a "light" version of ffmpeg is also a part of other tools, like x264 and cyanrip; but I would like to trust in MABS not to install these system-wide and use them only in the related projects. But even if, it should only limit the selection of codecs, not make basic APIs (like e.g. avformat_close_input) completely unavailable... I guess.
PS: x265cli.cpp.obj and objects.a contain libav* version string format templates; lavf.cpp.obj and objects.a contain avformat_close_input. Does the command line need more extra parameters that ff libs can be linked correctly?
Old 15th January 2021, 14:58   #7947  |  Link
qyot27
qyot27's Avatar
https://github.com/msg7086/x265-Yuuk...Lists.txt#L770
and
https://cmake.org/cmake/help/latest/...EFIX_PATH.html, if necessary
Old 15th January 2021, 15:38   #7948  |  Link
@qyot27:
ENABLE_STATIC_LAVF should be enabled by default (if LAVF and CLI are enabled), if I read that first location correctly; I already found this option, still tried to enable it explicitly in the cmake command line parameters (-DENABLE_STATIC_LAVF=ON), but it did not help as such...
VapourSynth, LSMASH and ZIMG packages are found without CMAKE_PREFIX_PATH, and I believe libav libraries (via the "FF" package) are found too; just linking them fails for a different reason. As if they are found but not used, maybe...
Old 16th January 2021, 14:48   #7949  |  Link
PoeBear
What CLI option(s) should I be tweaking to help stop chroma bleed? It seems that no matter how low I go with CRF, my reds will still bleed out into neighboring areas
My options are roughly a mix of veryslow and placebo, with some other options thrown in. Here's one from a recent 1080p/HDR test:
avs2yuv.exe "Test.avs" - | "x265.exe" -D 10 --crf 14 --profile main10 --level-idc 5.1 --high-tier --preset placebo --input-depth 16 --cu-lossless --pmode --bframes 16 --qg-size 32 --frame-threads 4 --ref 6 --limit-refs 1 --merange 57 --no-amp --tskip --tskip-fast --limit-modes --no-open-gop --hrd --cbqpoffs -0 --crqpoffs -1 --no-cutree --deblock -2:-2 --psy-rd 2.50 --psy-rdoq 1.00 --qcomp .6 --aq-mode 2 --aq-strength 1.0 --ipratio 1.3 --pbratio 1.2 --vbv-bufsize 160000 --vbv-maxrate 160000 --aud --hdr10 --hdr10-opt --range limited --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50) --max-cll 602,187 --chromaloc 2 --repeat-headers --output "C:\Temp\Test.hevc" --frames 5000 --y4m -
I've tried a few numerous tweaks: amp, no-amp, pmode, no-pmode, pme, no-pme, hme instead of merange, dropping cbqpoffs/crqpoffs a bit further. All which really only affect very minor detail retention, likely due to such low CRF, but I still get color bleeds
I know my settings are a bit absurd, I'm getting around 1.2FPS on a 3900X with around 60% load, but my goal is transparency mostly, with a tiny hint of keeping speeds above 1FPS
Side question: Is there anyway to increase load usage with command line x265 without affecting PQ? Ie without using something like RipBot's distributed encoding
PoeBear is offline   Reply With Quote
Old 16th January 2021, 15:18   #7950  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Chroma bleeding is actually really weird, it shouldn't really happen and I think I know why it's happening to you!
Your input is an AVS Script from what I see, which handles 4:2:0 Type 1 but not 4:2:0 Type2!
So, the chroma location is wrong, hence the "bleeding".
Can you try with:
ffmpeg.exe -i "AVS Script.avs" -vf scale=out_color_matrix=bt2020nc:out_h_chr_pos=0:out_v_chr_pos=0 -pix_fmt yuv420p16le -strict -1 -an -f yuv4mpegpipe - | x265.exe --y4m - --dither
followed by the rest of your x265 command line? This should solve the chroma bleeding problem.
Old 22nd January 2021, 10:48   #7951  |  Link
Success! With the great support of Christopher Degawa, main supporter of the media-autobuild suite, I was able to tweak my workflow until I could build an x265 binary with Yuuki-Asuna mod (Asuna branch = based on v3.4-stable). It required some pkgconfig tuning and I found a way to use the "video decoders only" light ffmpeg build as already used by m-ab-s in its x264 binary (option 6); so it should contain support for AVS input, VPY input, LAVF input, MP4 output (L-SMASH), MKV output (Haali, obsolete), and ZIMG scaling.
x265 3.4-Asuna+54
x265 [info]: HEVC encoder version 3.4+-+54
x265 [info]: build info [Windows][GCC 10.2.0][64 bit] Asuna 8bit+10bit+12bit
x265 [info]: (lsmash 2.16.1)
x265 [info]: (libavformat 58.65.101)
x265 [info]: (libavcodec  58.117.101)
x265 [info]: (libavutil   56.63.101)
Old 22nd January 2021, 20:03   #7952  |  Link
benwaggoner
Chromaloc seems like a big misfire to me at this point, since so many encoders and decoders don't actually encode/decode differently based on the parameter. Other than for HDR Blu-Ray, which requires chromaloc 2, I recommend leaving it at the default for broader compatibility.
At 4K resolutions, getting it wrong is pretty hard to see, but the lower the frame size, the more screen area an error will take up.
Ben Waggoner
My Compression Book
Old 23rd January 2021, 13:10   #7953  |  Link
Update with correct version numbering
x265 3.4+13-g729a838d3+41 (Asuna)
x265 [info]: HEVC encoder version 3.4+13-g729a838d3+41
Old 23rd January 2021, 16:43   #7954  |  Link
Barough
Barough's Avatar
x265 v3.4+37-dd1101b6d (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.2.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/Release_3.5
Old 24th January 2021, 14:06   #7955  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
True, but the thing is that he was using chromaloc 2 in x265 but his input (the AVS Script output) wasn't, so it was just wrong. Either he specifies the normal 4:2:0 or he converts it to type2 and specifies chromaloc 2. That's what I meant
Old 25th January 2021, 10:43   #7956  |  Link
outhud
Very nice! Thank you.
outhud is offline   Reply With Quote
Old 25th January 2021, 14:31   #7957  |  Link
K.i.N.G
Has anyone done any re-tests recently to see if SAO has improved?
It's been a while since I've tested it and concluded not to use it (removed too much detail)
K.i.N.G is offline   Reply With Quote
Old 25th January 2021, 16:28   #7958  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
there hasn't been any work on SAO for a long time. So doubtful
Old 25th January 2021, 19:30   #7959  |  Link
benwaggoner
There was --limit-sao, which provided a pretty nice performance boost without material quality loss when SAO was limited to only I and P frames.
SAO can definitely be helpful at moderate-low bitrates. But the x265 implementation has fixed parameters for SAO. Adjusting them some based on bitrate or QP or content analysis could make it a more reliable net benefit even at high bitrates and high detail.
Ben Waggoner
My Compression Book
Old 26th January 2021, 21:43   #7960  |  Link
LoRd_MuldeR
Software Developer
Thanks! Any chance you can include 32-Bit binary as well, as you used to do?
