Old 2nd December 2013, 05:00   #18501  |  Link
Originally Posted by HWK View Post
New version of tsmuxer handle it differently. Especially if it is True-HD track and since Brave does have True-HD, it might help in this case, that is why suggested try that and see how it goes.
Handles differently how? Does it keep the multiple parts separate? The OP was doing a full backup.
Old 2nd December 2013, 05:02   #18502  |  Link
HWK
HWK's Avatar
From version 2.1.8
version 2.1.8(b)
- Fixed join files problem with True-HD track
- introduce MAC build
Which leads me to believe earlier version may have problem with this track.
Old 2nd December 2013, 05:04   #18503  |  Link
Oh, I see.
I'm hoping to use v2.4.1 for the next release. But I'll have to do a lot of testing to make sure there aren't any surprises. If required I may keep two versions and it will be used only for 3D backups.
Old 2nd December 2013, 08:14   #18504  |  Link
Shylock
Thanks for your awnsers
After looking more closely to the disc structure, Mediainfo reports that the french audio track is an E-AC3 track.
If I try to load any m2ts from this disc to tsmuxer using gui, it fails to recognize the french audio track and therefore dont process it.
Strangely, through BDRB, it's demuxed and remuxed by the same tsmuxer.
Is it possible that the bug is a tsmuxer issue and NOT a BDRB one.
In that case, I may post this issue in the right place.
Edit:
Tryed to process full backup again but keeping only english audio track: Backup plays fine to the end this time, so I guess the problem resides in tsmuxer dealing with E-AC3 french audio track
Shylock is offline   Reply With Quote
Old 2nd December 2013, 11:58   #18505  |  Link
HWK
HWK's Avatar
Which Tsmuxer you used for this purpose.
Old 2nd December 2013, 12:20   #18506  |  Link
Shylock
I tryed the "old" version..the one included within BDRB.
with the new beta 2.4.1, It's reading every track.
As BDRB doesn't use the new one, that's why I report the bug.
BTW, can we use the new TsMuxer beta with BDRB?
Old 2nd December 2013, 12:23   #18507  |  Link
HWK
HWK's Avatar
Ok, that is good. In this case I just recommend use new version instead of old one. Jdobbs is planning to support it, might as well use it.
Just a reminder old meta file generated by BD-RB may not work with new version of tsmuxer. So replacing tsmuxer under tools folder is not enough if this happens.
Old 2nd December 2013, 13:41   #18508  |  Link
Shylock
Tryed replacing tsmuxer.exe in the "tools" directory for the latest beta one.
Process went all through...but the resulting blu-ray is unplayable.
Thanks anyway
Old 2nd December 2013, 17:33   #18509  |  Link
HWK
HWK's Avatar
Thanks anyway
Unplayable, error message or anything which you saw on screen. Just saying it doesn't play does not mean much and it certainly doesn't help any of us. I have done dozen of mux and never had issue in playback. However meta file generated by BD-RB may cause problem with new version.
Need to do more checks on this matter.
Old 2nd December 2013, 17:58   #18510  |  Link
Shylock
OK, that's what happen:
First title plays (Disney logo and language/angle selection) selecting whatever angle/language -> black screen
possible to select "title menu" on remote -> menu screen
Selecting "play"-> black screen and no more action possible.
Selecting whatever chapter point: same issue as "play"
Old 2nd December 2013, 20:37   #18511  |  Link
HWK
HWK's Avatar
This is off course from movie Brave, but is there any special case for example disc being 3D or region of disc or country. I would like to try it and see what happens.
In the meantime can you try movie only.
Old 2nd December 2013, 21:02   #18512  |  Link
Shylock
Yes, It's from the same disc: "Brave" Region B, 2D french release.
BTW, I own also the Region A, Canadian bilingual release, which is different (other langage tracks and menu). I tried this disc also this afternoon and get the very same result in both case (old and new tsmuxer). Note that both french canadian and french tracks are E-AC3 encoded on each disc.
I'll try movie only backup with the 2 tsmuxer and see what will happen.
Old 2nd December 2013, 21:10   #18513  |  Link
HWK
HWK's Avatar
Are you gone use BD-RB to do movie only backup? If so I can do remux and and see if it works, if success then I will try to rebuild with BD-RB as well.
Old 2nd December 2013, 21:39   #18514  |  Link
Shylock
Yes, I'll try BDRB for movie only. My computer is processing now. To speed up the process, I've set a BD50 target, it will skip reencoding procedure.
EDIT:
When using "old" tsmuxer in BDRB: process done flawessly. Resulting Blu-ray start to play OK on TMT6, but chapter navigation is jerky and I was unable to go to the end of the movie-> TMT6 ends crashing
When using "latest" tsmuxer in BDRB: Process seems to go fine except it somehow hangs when rebuilding. Went to to the end anyway after a while reporting no errors, but the resulting Blu-ray crashes immediately TMT6 and I see that the m2ts is only 8gb instead of 25gb. When playing the m2ts manually with MPC-HC, it shows no video but only audio...
The 2 logs and .inf files are absolutely identical.
[12/02/13] BD Rebuilder v0.45.05 (beta)
[21:04:31] Source:  BRAVE_00801
  - Input BD size: 24,72 GB
  - Approximate total content: [01:34:12.229]
  - Target BD size: 46,26 GB
  - Windows Version: 6.1 [7601]
  - MOVIE-ONLY mode enabled
  - Quality: Highest (Very Slow), Two Pass
[21:04:33] PHASE ONE, Encoding
 - [21:04:33] Processing: VID_00952 (1 of 9)
 - [21:04:33] Extracting A/V streams [VID_00952]
 - [21:29:23] Reencoding video [VID_00952]
 - [21:29:23] Keeping original video (no reencode)
 - [21:29:23] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
   - Track 4354 (eng): Keeping original audio
   - Track 4355 (fra): Keeping original audio
   - Track 4356 (fra): Keeping original audio
   - Track 4358 (eng): Keeping original audio
 - [21:29:23] Processing: VID_00960 (2 of 9)
 - [21:29:23] Extracting A/V streams [VID_00960]
 - [21:29:32] Reencoding video [VID_00960]
 - [21:29:32] Keeping original video (no reencode)
 - [21:29:32] Processing: VID_00954 (3 of 9)
 - [21:29:32] Extracting A/V streams [VID_00954]
 - [21:30:06] Reencoding video [VID_00954]
 - [21:30:06] Keeping original video (no reencode)
 - [21:30:06] Processing: VID_00961 (4 of 9)
 - [21:30:06] Extracting A/V streams [VID_00961]
 - [21:30:21] Reencoding video [VID_00961]
 - [21:30:21] Keeping original video (no reencode)
 - [21:30:21] Processing: VID_00956 (5 of 9)
 - [21:30:21] Extracting A/V streams [VID_00956]
 - [21:42:28] Reencoding video [VID_00956]
 - [21:42:28] Keeping original video (no reencode)
 - [21:42:28] Processing: VID_00962 (6 of 9)
 - [21:42:28] Extracting A/V streams [VID_00962]
 - [21:42:59] Reencoding video [VID_00962]
 - [21:42:59] Keeping original video (no reencode)
 - [21:42:59] Processing: VID_00958 (7 of 9)
 - [21:42:59] Extracting A/V streams [VID_00958]
 - [21:43:47] Reencoding video [VID_00958]
 - [21:43:48] Keeping original video (no reencode)
 - [21:43:48] Processing: VID_00968 (8 of 9)
 - [21:43:48] Extracting A/V streams [VID_00968]
 - [21:43:57] Reencoding video [VID_00968]
 - [21:43:57] Keeping original video (no reencode)
 - [21:43:57] Processing: VID_00959 (9 of 9)
 - [21:43:57] Extracting A/V streams [VID_00959]
 - [21:44:10] Reencoding video [VID_00959]
 - [21:44:10] Keeping original video (no reencode)
[21:44:10]PHASE ONE complete
[21:44:10]PHASE TWO - Rebuild Started
 - [21:44:10] Rebuilding BD file Structure
[21:59:17] - Encode and Rebuild complete
[21:59:17] JOB: BRAVE finished.
[22:04:53] Source:  BRAVE_00801
[22:04:54] PHASE ONE, Encoding
 - [22:04:54] Processing: VID_00952 (1 of 9)
 - [22:04:54] Extracting A/V streams [VID_00952]
 - [22:19:14] Reencoding video [VID_00952]
 - [22:19:14] Keeping original video (no reencode)
 - [22:19:14] Processing audio tracks
 - [22:19:14] Processing: VID_00960 (2 of 9)
 - [22:19:14] Extracting A/V streams [VID_00960]
 - [22:19:23] Reencoding video [VID_00960]
 - [22:19:23] Keeping original video (no reencode)
 - [22:19:23] Processing: VID_00954 (3 of 9)
 - [22:19:23] Extracting A/V streams [VID_00954]
 - [22:19:55] Reencoding video [VID_00954]
 - [22:19:55] Keeping original video (no reencode)
 - [22:19:55] Processing: VID_00961 (4 of 9)
 - [22:19:55] Extracting A/V streams [VID_00961]
 - [22:20:09] Reencoding video [VID_00961]
 - [22:20:09] Keeping original video (no reencode)
 - [22:20:09] Processing: VID_00956 (5 of 9)
 - [22:20:09] Extracting A/V streams [VID_00956]
 - [22:32:13] Reencoding video [VID_00956]
 - [22:32:13] Keeping original video (no reencode)
 - [22:32:13] Processing: VID_00962 (6 of 9)
 - [22:32:13] Extracting A/V streams [VID_00962]
 - [22:32:43] Reencoding video [VID_00962]
 - [22:32:43] Keeping original video (no reencode)
 - [22:32:43] Processing: VID_00958 (7 of 9)
 - [22:32:43] Extracting A/V streams [VID_00958]
 - [22:33:32] Reencoding video [VID_00958]
 - [22:33:32] Keeping original video (no reencode)
 - [22:33:32] Processing: VID_00968 (8 of 9)
 - [22:33:32] Extracting A/V streams [VID_00968]
 - [22:33:42] Reencoding video [VID_00968]
 - [22:33:42] Keeping original video (no reencode)
 - [22:33:42] Processing: VID_00959 (9 of 9)
 - [22:33:42] Extracting A/V streams [VID_00959]
 - [22:33:54] Reencoding video [VID_00959]
 - [22:33:54] Keeping original video (no reencode)
[22:33:54]PHASE ONE complete
[22:33:54]PHASE TWO - Rebuild Started
 - [22:33:54] Rebuilding BD file Structure
[22:41:36] - Encode and Rebuild complete
[22:41:36] JOB: BRAVE finished.
[Status]
LABEL=BRAVE
VERSION=v0.45.05 (beta)
SOURCE_SIZE=26546915328
SOURCE_VIDEO_SIZE=26546915328
TARGET_SIZE=49666850816
REDUCTION=1.87090854821895
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;fra;fre;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=-1
INSTANCES=3
DGDECNV=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=9
REBUILD_COMPLETE=1
[00952]
USE_ORIGINAL=1
AUDIO=1111101
PGS=11111111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=461967014
NSIZE=0
FLINK=-1
MLINK=0
[00960]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=237184985
AUDIO=1111101
NSIZE=0
FLINK=-1
MLINK=0
[00954]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1575681215
AUDIO=1111101
NSIZE=0
FLINK=-1
MLINK=0
[00961]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=586720752
AUDIO=1111101
NSIZE=0
FLINK=-1
MLINK=0
[00956]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=42014859041
AUDIO=1111101
NSIZE=0
FLINK=-1
MLINK=0
NSTART=27000000
NEND=282200273
[00962]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1491722742
AUDIO=1111101
NSIZE=0
FLINK=-1
MLINK=0
[00958]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2554445735
AUDIO=1111101
NSIZE=0
FLINK=-1
MLINK=0
[00968]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=290337227
AUDIO=1111101
NSIZE=0
FLINK=-1
MLINK=0
[00959]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=453932105
AUDIO=1111101
NSIZE=0
FLINK=0
MLINK=0
Old 3rd December 2013, 00:05   #18515  |  Link
HWK
HWK's Avatar
Most likely it is meta file generated by BD-RB for tsmuxer which is causing problem, after all I remember reading old meta file has problem with new version of tsmuxer.
I ran some test as well and I have things to share, If I use old tsmuxer and then my outcome is similar to yours, playback is not playable. What works for me is use new version and create iso with muxer by reading mpls file and then use this iso to feed it to BD-RB. In first step eliminate seamless branching with new muxer and then use BD-RB on that as if it was same title with one large file for movie.
Doing this will keep movie only though.
Old 3rd December 2013, 07:37   #18516  |  Link
Shylock
OK, thanks HWK
I will try your workaround.
In conclusion, I think it's definitely not a BD-RB bug but more likely a tsmuxer issue when dealing with E-AC3 audio and seamless branching titles. The 2 only discs not working for me are "Brave" and "Monsters University". they share those 2 criterias.
As my purpose is to get a full backup with menus, I'll just wait for jdobbs to update his wonderfull piece of software with the new tsmuxer and give another shot to these titles.
BTW, many thanks jdobbs for your software, adding a $30 contribution. I hope it will help developping. I long to see full 3D backup working.
Old 4th December 2013, 00:17   #18517  |  Link
wakko709
[12/03/13] BD Rebuilder v0.45.05 (beta)
[14:26:13] Source: 00000078_TERMINATOR
- Input BD size: 23.03 GB
- Approximate total content: [02:42:34.035]
- Target BD size: 22.95 GB
[14:26:16] PHASE ONE, Encoding
- [14:26:16] Processing: VID_00002 (1 of 7)
- [14:26:16] Extracting A/V streams [VID_00002]
- [14:26:28] Reencoding video [VID_00002]
- [14:26:28] Keeping original video (no reencode)
- [14:26:28] Processing audio tracks
- [14:26:28] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00002.meta
- Can't open file: E:\WORKFILES\VID_00002.AVS.264
[14:26:31] - Failed to build structure, aborted
- FFDSHOW: [4504], Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.45.0.5, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
wakko709 is offline   Reply With Quote
Old 4th December 2013, 00:52   #18518  |  Link
HWK
HWK's Avatar
It seems BD-RB failed because it can't find this file. Double check it still exist in it's location.
Old 4th December 2013, 18:15   #18519  |  Link
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
That's two reports, both from you, where this has happened. Can you describe you setup so I can see if there is anything unique about it?
Old 4th December 2013, 19:37   #18520  |  Link
RobertM
Looking at this more closely, Wakko's reports are different than what I experienced in the past. In my case it happened after the processing of the individual components was finished, and BD-RB was trying to rebuild the BD file structure. Wakko's problems happen during the processing of the individual components, and on components where the original video was kept intact, without re-encoding. This does not seem to be the same problem that was reported before, although the error message looks similar.
