Old 10th June 2018, 07:24   #5201  |  Link
manolito
manolito's Avatar
Originally Posted by Sp00kyFox View Post
not any. I'm using a DVB-T2 receiver with PVR feature. it is the Comag SL30T2.
Only few folks here in Germany use USB tuners to capture DVB-T2 directly to the computer. Due to the HEVC format in 1080p @ 50fps this requires a very powerful machine.
For receivers with PVR the users are entirely at the mercy of the manufacturer (or the chipset manufacturer). My XORO HRT 720 seems to have the same chipset as your Comag. The latest firmware update was from June 2017, and it does not look like there will be any more updates in the future. But so far I never had such ugly glitches as you had in my captured files, not even on days when the air is full of low flying choppers (when some foreign high security politician is visiting Angie...)
Cheers
manolito
manolito is offline
Old 10th June 2018, 11:04   #5202  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
MKVToolNix v24.0.0 released
Hey.
time for MKVToolNix v24.0.0, a release that's on the smaller side regarding the number of changes: nothing major, a number of smaller bugs squashed, a couple of enhancements.
AV1 support hasn't changed as the bitstream format still hasn't been finalized.
To my users on Debian and Ubuntu: just a friendly reminder that the layout of my APT repositories was changed in April. If you haven't done so, you'll have to update your `sources.list` entry accordingly. Read more about that in this blog post.
Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG and the source code.
The Windows and macOS binaries are available already. The Linux binaries are still being built and will be available of the course of the next couple of hours.
Here are the NEWS since the previous release:
# Version 24.0.0 "Beyond The Pale" 2018-06-10
## New features and enhancements
* mkvmerge: MP4 reader: improved the detection of edit lists consisting of two identical entries, each spanning the file's duration as given in the movie header atom. The second entry is ignored in such cases. See #2306.
* mkvmerge: JSON identification: the "display unit" video track property is now reported as `display_unit`. The JSON schema has been bumped to v11 for this change.
* mkvmerge, mkvextract: AVC/h.264: empty NALUs will now be removed.
* mkvextract: VobSub extraction: empty SPU packets will now be dropped during extraction as other tools such as MP4Box cannot handle them correctly. Implements #2293.
## Bug fixes
* mkvmerge: E-AC-3 parser: fixed determining the number of channels for streams that contain an AC-3 core with dependent E-AC-3 frames. Fixes #2283.
* mkvmerge: Matroska reader: fixed mkvmerge buffering the whole file if a video track is multiplexed that consists of only one or a few frames. Fixes #2304.
* mkvmerge: the "display unit" video track property will now be kept if it is set in the source file. Fixes #2317.
* MKVToolNix GUI: multiplexer: when scanning playlists, all playlists were offered for selection regardless of the value of the "minimum playlist duration" setting. Fixes #2299.
* MKVToolNix GUI: multiplexer: deriving track languages from file names: the regular sub-expressions for ISO 639-1 codes could match on empty strings, too, causing matches in wrong places and hence no language being recognized in certain situations. Fixes #2298.
* MKVToolNix GUI: header editor: fixed a crash when saving the file fails (e.g. because it isn't writable). Fixes #2319.
* MKVToolNix GUI: header editor: the editor was wrongfully claiming that mandatory elements with default values cannot be removed in the "status" text. Fixes #2320.
* MKVToolNix GUI: preferences: on macOS & Linux the setting "enable copying tracks by their type" wasn't restored on program start. Fixes #2297.
## Other changes
* Niels Lohmann's JSON library: the bundled version has been updated from v1.1.0 (git revision 54d3cab) to v3.1.1 (git revision g183390c1).
* pugixml library: the bundled version has been updated from v1.8 to v1.9 (git revision e584ea3).
Have fun
Latest MKVToolNix is v83.0
Mosu is offline
Old 10th June 2018, 11:27   #5203  |  Link
hubblec4
Matroska find' ich toll
Many thanks for this upgrade and your work.
hubblec4 is offline
Old 13th June 2018, 15:45   #5204  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Regression report:
recent versions of MKVtoolnix are unable to mux MLP files correctly.
Version 5.8.0 of MKVmerge did the job well and produced a 28.3 MB .mka from a 26.8 .MLP, whereas MKVmerge 24.0.0 generates a 22.4 MB .mka from the same source.
Sample files: http://www.mediafire.com/file/dpwrgu...Sample.7z/file
Midzuki is offline
Old 13th June 2018, 16:34   #5205  |  Link
mkver
In Midzuki's case 7.6 was the last version that worked; the behaviour changed in 7.7.
mkver is offline
Old 13th June 2018, 16:45   #5206  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally Posted by Midzuki View Post
Regression report:
Out of interest... Why don't you re-encode your .mlp contained files to flac?
SeeMoreDigital is offline
Old 13th June 2018, 16:54   #5207  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Thanks for the report. But please open an issue on Gitlab. Otherwise chances are I'll forget about it again.
Mosu is offline
Old 13th June 2018, 17:03   #5208  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Done. And many thanks for answering
Midzuki is offline
Old 14th June 2018, 07:20   #5209  |  Link
v0lt
@Mosu
In old versions of "mkvinfo.exe" the "--gui" key worked. Now it does not work , can I return it?
v0lt is offline
Old 14th June 2018, 07:25   #5210  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
mkvinfo's GUI has been removed and replaced by the "info" tool in MKVToolNix GUI. You can start that directly via "mkvtoolnix-gui --info yourfile.mkv".
mkvinfo's GUI won't be coming back.
Mosu is offline
Old 15th June 2018, 23:10   #5211  |  Link
arrgh
reading/muxing avc/ssif mpls
Yes, for the sake of completeness — but if I'm entirely honest, then that feature probably has the lowest priority of all the things that I still want to implement. Mostly because I have zero interest in 3D myself.
Hi Mosu
did this feature to mux MVC-mkv move up in the priority list somewhat...?
arrgh is offline
Old 16th June 2018, 04:05   #5212  |  Link
mike23
How can I find out with mkvtoolnix what the average video bitrate of a *.mkv video is?
Sometimes tools like MediaInfo do not show this info.
See as sample snapshot here:
http://easycaptures.com/2581037801
But I could imagine that this is possible with mkvtooolnix
mike23 is offline
Old 16th June 2018, 09:05   #5213  |  Link
mkver
Some muxers like mkvmerge (or MakeMKV) add statistcs tags by default that enable MediaInfo to show the average bitrate of the tracks in the file to the user. If these tracks aren't there, MediaInfo simply doesn't know the numbers.
You can use mkvpropedit (a part of MKVToolNix) to add the track statistics tags to your file: mkvpropedit --add-track-statistics-tags <file>
mkver is offline
Old 16th June 2018, 09:42   #5214  |  Link
mike23
Thank you for the suggestion.
I executed the command (on an existing *.mkv file) just as above and yes the output looks good:
The file is being analyzed.
The file is read in order to create track statistics.
Progress: 100%
The changes are written to the file.
Done.
But when I drag the *.mkv file afterwards onto MediaInfo again then the average bitrate is still NOT shown.
Whats wrong?
BTW: Can I somehow execute the --add-track-statistics-tags operation in the GUI version of mkvpropedit as well?
I found no corresponding checkbox or menu
And finally I wonder if there is a GUI which let me do this without changing the *.mkv file. In other words which analyze the mkv and show me all infos about the used codecs. Unfortunately
mkvtoolnix-gui.exe does not offer this function
mike23 is offline
Old 16th June 2018, 10:46   #5215  |  Link
mkver
You are right. My version of MediaInfo (18.03.1) shows it only in the following way:
Video
Format                                   : AVC
Format profile                           : High@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 4 s 160 ms
Bit rate                                 : 8 409 kb/s
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Frame rate                               : 50.000 FPS
Bits/(Pixel*Frame)                       : 0.182
Stream size                              : 4.17 MiB (95%)
Statistics Tags Issue                    : mkvpropedit v24.0.0 ('Beyond The Pale') 64-bit 2018-06-16 09:28:36 / Lavf58.13.100
FromStats_BitRate                        : 11464630
FromStats_Duration                       : 00:00:03.120000000
FromStats_FrameCount                     : 150
FromStats_StreamSize                     : 4471206
Audio
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 2
Codec ID                                 : A_MPEG/L2
Codec ID/Hint                            : MP2
Duration                                 : 4 s 166 ms
Bit rate                                 : 256 kb/s
Sampling rate                            : 48.0 kHz
Delay relative to video                  : -1 s 46 ms
Stream size                              : 130 KiB (3%)
Language                                 : German
FromStats_BitRate                        : 257542
FromStats_Duration                       : 00:00:03.984000000
FromStats_FrameCount                     : 167
FromStats_StreamSize                     : 128256
It seems that MediaInfo doesn't display the track statistics tags in the usual way if the tags don't seem to have been created during muxing. This even applies to the case when there is a "date" element in the header so that one can check whether the tags are up to date (ffmpeg/Lavf doesn't write the date element). I'll report this to the MediaInfo developers.
mkver is offline
Old 16th June 2018, 11:01   #5216  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
No, it didn't.
Mosu is offline
Old 17th June 2018, 04:52   #5217  |  Link
v0lt
It's a pity.
Can I run mkvtoolnix-gui.exe with English translation? I need something like the "--ui-language en" key, which was in mkvinfo.exe.
v0lt is offline
Old 18th June 2018, 16:40   #5218  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
That doesn't work at the moment, though I'm not sure why. It certainly was my intention to have that working. I'll look into it.
Mosu is offline
Old 24th June 2018, 11:09   #5219  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Not a bug report at all, just a *request-for-comments*.
mpv was unable to deal with Matroska files that contain MLP streams. I reported the flaw, and today that flaw has been fixed. I downloaded the latest Windows build of mpv from SourceForge and put it to the test. Now mpv.exe shows the following warning message:
=> mpv PaBailar-580.mka
Playing: PaBailar-580.mka
 (+) Audio --aid=1 --alang=spa (*) (mlp 2ch 44100Hz)
[mkv] This is a broken file! Packets with incorrect keyframe flag found. Enabling workaround.
AO: [wasapi] 48000Hz 5.1 6ch float
So my question is: ¿does that warning make any sense?
Midzuki is offline
Old 24th June 2018, 11:19   #5220  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Does that happen with TrueHD files produced by MKVToolNix as well?
Mosu is offline
