7th May 2010, 01:56 | #8121 | Link |
@DGenerateKane and 8ternity ........
I had the same issue with my copy of dances with wolves I also have tons of free space on my drive. Funny the movie finished fine when I just did the movie Only instead of the full disk backup. I meant for it to be just a test but forgot there was a blank disk in my burner. I was surprised when I got up in the am and it finished. You can see my post back on page 403 post #8044 |
7th May 2010, 02:57 | #8123 | Link |
Mmh don't know but there is some strange behaviors in some configurations during files rebuilding process. This is the case for me when I work in network, BDR freezes endlessly while trying to transfer files, and I don't know why!
7th May 2010, 04:25 | #8124 | Link | |
hi jdobbs, what it's mean ' target too small ' ? i set to BD9, and my hardisk is still have a lot of space
7th May 2010, 06:24 | #8125 | Link |
hello... a help
[00:07:47] BD Rebuilder v0.33.06 (beta)
- Source: ITS_COMPLICATED - Input BD size: 34,21 GB - Approximate total content: [02:23:19.007] - Target BD size: 23,44 GB - Windows Version: 5.1 [2600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [00:07:55] PHASE ONE, Encoding - [00:07:55] Extracting A/V streams [VID_00062] - [00:07:58] Reencoding: VID_00062 (1 of 4) - [00:07:58] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 1.632 frames - [00:07:58] Reencoding: VID_00062, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.06 (beta) - Windows Version: 5.1 [2600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [00:08:35] - Failed video encode, aborted |
7th May 2010, 08:04 | #8126 | Link |
Monsters vs. Aliens problem.
Sorry if this has been answered elsewhere (unable to find in search). Back up of Monsters vs. Aliens, when attempting to play on my Panasonic BD60, movie attempts to start, freezes, then returns to menu screen. Unable to choose individual scenes, also. However, top menu "extras" plays normally. Is it something I'm doing incorrectly in options on BD Rebuilder (never deviate from default settings)? Using latest version of "Rebuilder" as well as latest version of SlySoft. Have made 2 attempts with same results. Backing up onto 25G Optical Quantum media. Have backed up over 100 Blu-rays so far with these occasional hic cups (see posts elsewhere from me). End result usually is backups work onto full 50G media. Any help on this particular movie much appreciated. |
7th May 2010, 09:52 | #8127 | Link |
Just want to support 8ternity, DGenerateKane and bassnut, I also have the same issue and interestingly enough part of the BDRebuilder filename is the same as 8ternity's log but for a different film...
Film is Bourne Ultimatum, re ripped several times, same issue. 100+ other films all worked fine on same system setup. Workfiles hard disk always cleaned after rebuild has been completed. EDIT : Don't know if this helps your investigation JDobbs, but this was the last film in a batch mode each time I tried it. I will try it on it's own. It was also a full disk backup. EDIT : Can confirm when processed as a single film it worked fine. Must be an issue with batch backup. Code:
- Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,968 frames - [22:26:10] Reencoding: VID_00091, Pass 1 of 1 - [22:28:09] Video Encode complete - [22:28:09] Reencoding audio tracks (if req'd) - [22:28:09] Multiplexing M2TS - [22:28:20] Extracting A/V streams [VID_00009] - [22:48:22] Reencoding: VID_00009 (49 of 49) - [22:48:22] Reencoding secondary video [TRK_02] - [23:05:38] Reencoding secondary video [TRK_03] - [23:19:50] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 165,768 frames - Bitrate: 9,904 Kbs - [23:19:50] Reencoding: VID_00009, Pass 1 of 1 - [00:26:50] Video Encode complete - [00:26:50] Reencoding audio tracks (if req'd) - [00:26:50] Multiplexing M2TS - Error in attempt to multiplex: MUX_00009.meta - Can't open file: D:\WORKING\WORKFILES\00009.track_6656.DTS [00:26:51] - Failed to build structure, aborted ========================== [00:26:51] END - BATCH SEQUENCE ========================== Last edited by ShinoobieEVE; 7th May 2010 at 12:55. |
7th May 2010, 20:45 | #8128 | Link | |
8th May 2010, 05:08 | #8129 | Link |
This keeps happening with random flicks, with Red cliff I had to replace some trailers that wouldn't encode, now this:
[03:07:34] PROCESSING BATCH FILE [1] ----------------------- [03:07:35] BD Rebuilder v0.33.06 (beta) - Source: COUPLES_RETREAT - Input BD size: 43.35 GB - Approximate total content: [02:32:59.962] - Target BD size: 23.78 GB - Windows Version: 6.0 [6002] - SHUTDOWN at completion enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [03:07:35] PHASE ONE, Encoding - [03:07:35] Extracting A/V streams [VID_00010] - [03:08:19] Reencoding: VID_00010 (1 of 27) - [03:08:19] Reencoding secondary video [TRK_02] - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.06 (beta) - Windows Version: 6.0 [6002] - AVISYNTH Version: 2.5.7.0, Ok [03:08:57] - Failed video encode, aborted |
8th May 2010, 14:47 | #8130 | Link | |
Depending on those results, you could try it with PROCESS_SECONDARY=0 set in the ini file, since I believe the secondary audio for this movie is DTS Express, and it will not be available for the secondary video track anyway. The complete "Inspect" log may also help determine the issue. |
8th May 2010, 15:10 | #8131 | Link |
@jdobbs:
from the last issue i have submit in this post: http://forum.doom9.org/showpost.php?...postcount=8110 I have tested with version 3305 and the project has sucessfully done.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
8th May 2010, 22:58 | #8132 | Link | |
9th May 2010, 08:26 | #8134 | Link |
Former Kanenite
I've got a problem with Star Trek Season 2 Disc 6. About 29 minutes into the third episode on the disc and the audio switched to Spanish. I switched between the audio tracks and also found a french track, but up until this point the only track was english. I double checked my BD-RE settings and can confirm I have it set to only keep english. Is there a way to fix this?
I also have a question, do you use any of the settings in AnyDVD such as remove user prohibited operations or remove annoying adverts and trailers? I'm tempted to try them but I don't want to find out later it caused problems. |
9th May 2010, 10:07 | #8135 | Link |
Ok the issue of error....
"Cannot open file D:\WORKING\WORKFILES\XXXXX.track_6656.DTS" in batch mode is occuring on about 50% of the backups I am doing now. When the same rip is processed as a single backup, it works fine. Batch backup mode is definately experiencing issues. |
9th May 2010, 13:51 | #8136 | Link |
Hey Jdobbs,
First time i'm having a rather strange issue. I had BDRB do its magic on Batman begins: first im i had it accidentaly rescale down to 720p and the subs wouldnt work. So i redo the job. Now, it finished without a problem however and here comes the strange part. My player the Panasonic DMP-BD60 wouldnt accept it, or rather accept it only partially. The java would start and finish loading and when it gets to the part where it should start playing the movie, the screen stays black, however i CAN pull up the pop-up menu. In PowerDVD the ISO as the burnt disc play fine, in TMT3 the disc loads fine but it plays the sound from the Pip stream (if i select the pipstream while playing, it doesnt have audio) and VERY jittery both the backup & the original. The original also plays fine in PDVD 10 as does the backup. The Disc is VC-1 based, however my backup of The Dark Knight is also VC-1 based and that one starts up just fine in the player. Below the logfile for the begins recode. Inspect settings are fine. Code:
[16:45:53] BD Rebuilder v0.33.06 (beta) - Source: BATMAN_BEGINS - Input BD size: 37,29 GB - Approximate total content: [05:41:41.689] - Target BD size: 22,66 GB - Windows Version: 6.0 [6002] - Resize SD to HD 720p enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [16:45:53] PHASE ONE, Encoding - [16:45:53] Extracting A/V streams [VID_00016] - [16:46:03] Reencoding: VID_00016 (1 of 17) - [16:46:03] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 4.495 frames - Convert: 1280x720, 59,940fps, 8.990 frames - [16:46:03] Reencoding: VID_00016, Pass 1 of 1 - [16:47:14] Video Encode complete - [16:47:14] Reencoding audio tracks (if req'd) - [16:47:14] Multiplexing M2TS - [16:47:17] Extracting A/V streams [VID_00014] - [16:47:20] Reencoding: VID_00014 (2 of 17) - [16:47:20] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 7.920 frames - [16:47:20] Reencoding: VID_00014, Pass 1 of 1 - [16:49:42] Video Encode complete - [16:49:42] Reencoding audio tracks (if req'd) - [16:49:42] Multiplexing M2TS - [16:49:44] Extracting A/V streams [VID_00017] - [16:49:58] Reencoding: VID_00017 (3 of 17) - [16:49:58] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 9.375 frames - Convert: 1280x720, 59,940fps, 18.750 frames - [16:49:58] Reencoding: VID_00017, Pass 1 of 1 - [16:52:39] Video Encode complete - [16:52:39] Reencoding audio tracks (if req'd) - [16:52:39] Multiplexing M2TS - [16:52:43] Extracting A/V streams [VID_00023] - [16:53:07] Reencoding: VID_00023 (4 of 17) - [16:53:07] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 14.943 frames - Convert: 1280x720, 59,940fps, 29.886 frames - [16:53:07] Reencoding: VID_00023, Pass 1 of 1 - [16:57:40] Video Encode complete - [16:57:40] Reencoding audio tracks (if req'd) - [16:57:40] Multiplexing M2TS - [16:57:47] Extracting A/V streams [VID_00022] - [16:58:30] Reencoding: VID_00022 (5 of 17) - [16:58:30] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 23.040 frames - Convert: 1280x720, 59,940fps, 46.080 frames - [16:58:30] Reencoding: VID_00022, Pass 1 of 1 - [17:05:00] Video Encode complete - [17:05:00] Reencoding audio tracks (if req'd) - [17:05:00] Multiplexing M2TS - [17:05:13] Extracting A/V streams [VID_00021] - [17:05:50] Reencoding: VID_00021 (6 of 17) - [17:05:51] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 23.070 frames - Convert: 1280x720, 59,940fps, 46.140 frames - [17:05:51] Reencoding: VID_00021, Pass 1 of 1 - [17:12:42] Video Encode complete - [17:12:42] Reencoding audio tracks (if req'd) - [17:12:42] Multiplexing M2TS - [17:12:53] Extracting A/V streams [VID_00025] - [17:13:31] Reencoding: VID_00025 (7 of 17) - [17:13:31] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 23.430 frames - Convert: 1280x720, 59,940fps, 46.860 frames - [17:13:31] Reencoding: VID_00025, Pass 1 of 1 - [17:20:41] Video Encode complete - [17:20:41] Reencoding audio tracks (if req'd) - [17:20:41] Multiplexing M2TS - [17:20:54] Extracting A/V streams [VID_00024] - [17:21:34] Reencoding: VID_00024 (8 of 17) - [17:21:34] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 24.595 frames - Convert: 1280x720, 59,940fps, 49.190 frames - [17:21:34] Reencoding: VID_00024, Pass 1 of 1 - [17:28:43] Video Encode complete - [17:28:43] Reencoding audio tracks (if req'd) - [17:28:43] Multiplexing M2TS - [17:29:07] Extracting A/V streams [VID_00027] - [17:29:47] Reencoding: VID_00027 (9 of 17) - [17:29:47] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 25.595 frames - Convert: 1280x720, 59,940fps, 51.190 frames - [17:29:47] Reencoding: VID_00027, Pass 1 of 1 - [17:36:03] Video Encode complete - [17:36:03] Reencoding audio tracks (if req'd) - [17:36:03] Multiplexing M2TS - [17:36:18] Extracting A/V streams [VID_00026] - [17:37:02] Reencoding: VID_00026 (10 of 17) - [17:37:02] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 26.791 frames - Convert: 1280x720, 59,940fps, 53.582 frames - [17:37:02] Reencoding: VID_00026, Pass 1 of 1 - [17:43:24] Video Encode complete - [17:43:24] Reencoding audio tracks (if req'd) - [17:43:24] Multiplexing M2TS - [17:43:47] Extracting A/V streams [VID_00018] - [17:44:28] Reencoding: VID_00018 (11 of 17) - [17:44:28] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 25.680 frames - Convert: 1280x720, 59,940fps, 51.360 frames - [17:44:28] Reencoding: VID_00018, Pass 1 of 1 - [17:50:44] Video Encode complete - [17:50:44] Reencoding audio tracks (if req'd) - [17:50:44] Multiplexing M2TS - [17:50:59] Extracting A/V streams [VID_00015] - [17:51:18] Reencoding: VID_00015 (12 of 17) - [17:51:18] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29,970fps, 34.255 frames - [17:51:18] Reencoding: VID_00015, Pass 1 of 1 - [18:03:35] Video Encode complete - [18:03:35] Reencoding audio tracks (if req'd) - [18:03:35] Multiplexing M2TS - [18:04:09] Extracting A/V streams [VID_00121] - [18:04:30] Reencoding: VID_00121 (13 of 17) - [18:04:30] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 9.522 frames - [18:04:30] Reencoding: VID_00121, Pass 1 of 1 - [18:08:50] Video Encode complete - [18:08:50] Reencoding audio tracks (if req'd) - [18:08:50] Multiplexing M2TS - [18:08:59] Extracting A/V streams [VID_00117] - [18:09:19] Reencoding: VID_00117 (14 of 17) - [18:09:19] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29,970fps, 34.316 frames - [18:09:19] Reencoding: VID_00117, Pass 1 of 1 - [18:22:02] Video Encode complete - [18:22:02] Reencoding audio tracks (if req'd) - [18:22:02] Multiplexing M2TS - [18:22:27] Extracting A/V streams [VID_00116] - [18:22:49] Reencoding: VID_00116 (15 of 17) - [18:22:49] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29,970fps, 35.575 frames - [18:22:49] Reencoding: VID_00116, Pass 1 of 1 - [18:36:38] Video Encode complete - [18:36:38] Reencoding audio tracks (if req'd) - [18:36:38] Multiplexing M2TS - [18:37:03] Extracting A/V streams [VID_00119] - [18:37:34] Reencoding: VID_00119 (16 of 17) - [18:37:34] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29,970fps, 35.640 frames - [18:37:34] Reencoding: VID_00119, Pass 1 of 1 - [18:50:48] Video Encode complete - [18:50:48] Reencoding audio tracks (if req'd) - [18:50:48] Multiplexing M2TS - [18:51:04] Extracting A/V streams [VID_00000] - [18:56:17] Reencoding: VID_00000 (17 of 17) - [18:56:17] Reencoding secondary video [TRK_02] - [19:15:06] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 201.467 frames - Bitrate: 5.068 Kbs - [19:15:06] Reencoding: VID_00000, Pass 1 of 2 - [21:02:05] Reencoding: VID_00000, Pass 2 of 2 - [22:42:37] Video Encode complete - [22:42:37] Reencoding audio tracks (if req'd) - [22:42:37] Multiplexing M2TS [22:49:15]PHASE ONE complete [22:49:15]PHASE TWO - Rebuild Started - [22:49:15] Rebuilding BD file Structure [22:50:07] - Encode and Rebuild complete [22:50:07] Writing BD structure to ISO file - ImgBurn completed successfully - WORKFILES folder removed. [23:02:53]JOB: BATMAN_BEGINS finished. Code:
- Windows Version: 6.0 [6002] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.33.0.6, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Last edited by Ch3vr0n; 9th May 2010 at 16:11. |
9th May 2010, 15:44 | #8137 | Link |
Ch3vr0n :Mine play well on TMT3. However I didn't upscale SD to HD and I didn't keep HD audio. Check if you didn't blank any wanted audio tracks, if it's ok, you should retry in changing these 2 settings.
9th May 2010, 17:11 | #8139 | Link | |
Thanks By the way, the encode failed again: [17:55:02] BD Rebuilder v0.33.06 (beta) - Source: COUPLES_RETREAT - Input BD size: 43.35 GB - Approximate total content: [02:32:59.962] - Target BD size: 23.78 GB - Windows Version: 6.0 [6002] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [17:55:02] PHASE ONE, Encoding - [17:55:02] Extracting A/V streams [VID_00010] - [18:16:51] Reencoding: VID_00010 (1 of 27) - [18:16:51] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 163,528 frames - Bitrate: 21,256 Kbs - [18:16:51] Reencoding: VID_00010, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.06 (beta) - Windows Version: 6.0 [6002] - AVISYNTH Version: 2.5.7.0, Ok [18:17:35] - Failed video encode, aborted |
9th May 2010, 17:20 | #8140 | Link | ||
Greetings |
