27th December 2017, 18:50 | #461 | Link | |
I looked at MeGUI and the other GUI for eac3to. But HdBrStreamExtractor is best for my needs. Without much effort HdBrStreamExtractor shows me the streams of the respective file, which I can easily select and extract in the format I want. MeGUI and co. can do just that and many other things. But I do not need that. These GUI's have far too many options for what I need. I'm fine if HdBrStreamExtractor would handle the file names meaningfully. "Select Input Folder" is with HdBrStreamExtractor e.g. not possible. |
21st November 2018, 16:17 | #464 | Link |
Surcode DTS Encoder doesn't seem to be installed
I use this tool regualrly now to extract audio tracks from my Blu-Ray disks without having to re-rip entire movies. Great stuff! Thanks!
I just tried to extract an AC-3 stream to DTS since there is an option to do that in the file format options for each stream. It extracted multipel WAV files as it was working which I presume were going to be somehow "muxed" into a DTS file. At the end of the extraction process it buzzed at me, all the WAV files disappeared and the error above was displayed at the end of the log: "Surcode DTS Encoder doesn't seem to be installed" Was this something that was supposed to be included in the program package somehow? When I Googled this program it shows me a commercial package for this encoder that is $200. Do you actually need that to create DTS files or is there an open-source version or.... ...am I even doing this the best way? I thought that DTS was better quality than AC3. Is that accurate? Thanks! Last edited by KaraokeAmerica; 21st November 2018 at 16:26. |
21st November 2018, 17:57 | #467 | Link |
If you're processing a Blu-ray disc, there is usually never a reason to convert any audio streams - with one exception, some hardware player that can't deal with DTS or something like that.
But short of that, with HD audio just keep the DTS core, or the AC3 substreams from TrueHD, or just the plain DTS/AC3 streams. Converting any lossy codec to another lossy codec is always going to recuce the quality.
21st November 2018, 19:35 | #468 | Link | |
The physical Blu-Ray says it has AC3 streams on it. I extracted that without issue as AC3. I have noticed though that the file sizes between these formats are obvious. |
22nd November 2018, 00:01 | #469 | Link | ||
Not problem, we can explain you some tips, for instance...
At same bitrate the AAC is better than AC3 and much better than DTS. The DTS is the worse. Of course a DTS at 1536 Kb/s is better than a AC3 640 Kb/s but a AC3 640 Kb/s is better than a DTS 768 Kb/s Quote:
Also DTS is less compatible for players than AC3.
eac3to, hdbrstreamextractor |
