15th July 2014, 16:20 | #20582 | Link |
The lego movie
@HWK, IVaN_000 and others
Ok, I'm confused. I got back from my trip last night -- and my Region A copy of "The Lego Movie" was waiting on my doorstep. I loaded it and... there's nothing unusual about it. The SSIF exists, and so do the two contributing M2TS files. The main playlist is 00098. The two M2TS files (00042.M2TS and 00065.M2TS) are sized appropriately (so combined they are equal to 00042.SSIF). What gives? Is there more than one version of the release? There is only one listed anywhere I look. I sure hope the reports are against the actual commercial discs and not something that has been modified... Last edited by jdobbs; 15th July 2014 at 16:25. |
15th July 2014, 16:27 | #20583 | Link | ||
There is no special version or setup. Last edited by jdobbs; 15th July 2014 at 16:29. |
15th July 2014, 19:59 | #20585 | Link | |
Also want to add I also import movies outside of US and Canada as well, not all movies I have are from these regions.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 15th July 2014 at 20:31. Reason: More Info |
15th July 2014, 20:55 | #20586 | Link | |
Like encode the PCM DTS in Pirates, to the DTS in the format used on say Die Hard 2 which works in the MKV? If not possible in BD-Rebuilder, is it possible to do outside? (hopefully an "easy" way?) |
15th July 2014, 21:09 | #20587 | Link | |
In other movies most likely audio was DTS-HD and it was downscale to DTS or contain dts and pcm track and during backup kept DTS. It is certainly possible but not easy outside of BD-RB but will require encode which is not free and last time I check it was 1,495 USD.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 15th July 2014 at 21:13. |
15th July 2014, 23:36 | #20588 | Link | |
16th July 2014, 00:21 | #20589 | Link | |
16th July 2014, 03:22 | #20590 | Link |
Intel have added some new feature in main SDK compare to one which was used to compile FRIM maybe worth a try.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 16th July 2014 at 03:27. |
16th July 2014, 10:19 | #20591 | Link |
hi jdobbs,
sorry for my english i use this fantastic program for a long time! Now is a lot that i didnt read the forum and i have one question, which is the difference in these options: alternative decoding options - Use X264's internal LAVF for frame serving - Use DGDecNC for frame serving - Use FRIMSource for frame serving i have a I7 920 socket 1366, mobo sabertooth, 6gb ram, 500gb ssd thanks ps: there is somewhere a complete guide of this programa and for all the options (also the one in the ini file)? |
16th July 2014, 15:41 | #20592 | Link | |
If none of them are checked (the default), the frames will be sent via DirectShowSource(). This uses a standard Windows interface that, via AVISYNTH, decodes the video and presents it to the encoder. - Use X264's internal LAVF for frame serving X264 has an internal decoder called LAVF. When selected this tells BD-RB to, whenever possible, use LAVF. The disadvantage is that, since AVISYNTH is not used, no filters or other special features can be used. - Use DGDecNV for frame serving DGDecNV is an AVISYNTH decoding filter written by Neuron2. It requires a compatible Nvidia video card. Since it uses the video card for some of its functions it can be faster than other methods. It also has the advantage of frame-accurate seeking, which makes multiprocessing more efficient. DGDecNV is not free, it can be purchase for $15 from Neuron2.net. This is the one I use on my video computer. - Use FRIMSource for frame serving FRIMSource is an freeware AVISYNTH decoding filter written by videofan3d. It uses the Intel SDK, and is meant primarily for those users who have an intel-based video card that support Quick-Sync -- although it will work without it. If the video card exists and is enabled it can speed up decoding speeds significantly. A guide is on my to-do list, and has been for a long time. I've just never gotten around to it. |
16th July 2014, 15:43 | #20593 | Link | |
I have the DVD's of the movies too, their DTS is fine when converted to MKV, so I'll try and pull that audio track out and merge it with the video BD Rebuilder created. I just have to match up that audio to this video since they are slightly off. |
17th July 2014, 19:12 | #20594 | Link | |
My config is: I7 920 socket 1366, mobo sabertooth, 6gb ram, 500gb ssd so i think i'll check DGDecNV for frame serving!! i Always used LAVF with good result, not so fast, but good. But i want the best, so i'll check DGDecNV for $15 i can do it! thanks again!!! |
17th July 2014, 19:51 | #20595 | Link | |
17th July 2014, 20:33 | #20596 | Link |
I don't thing JD was saying that DGDecNV yields a higher quality encode, but that it is better a breaking up the source file and, therefore, more efficient in allocating resources during the encoding process. In other words, you buy DGDecNV for faster encode speed, not for better video quality.
18th July 2014, 16:57 | #20600 | Link |
I'm not thrilled with their GPUs -- but I am very pleased with AMD's CPUs. You get a lot of performance for a lot less money than Intel. If money or price/performance ratio isn't important, then Intel is ok. Also, can you imagine what Intel would be charging for their CPUs if AMD didn't exist as a competitor?
