#25561 | Link | |||
#25562 | Link | |
![]() Join Date: Oct 2001
#25563 | Link | |
#25567 | Link |
@colinhunt
I just did several tests with 3D sources and output to ISO. It worked correctly every time. I'll look at it some more -- but it sure looks like it's working from here. [Edit] Never mind. I was able to repeat it. I traced it and I see how it happens now. I'll get a fix in for the next release. Last edited by jdobbs; 25th January 2017 at 20:55. |
#25571 | Link | |
![]() Yes, I actually do remember that... |
#25572 | Link |
BD Rebuilder v0.50.22
I have updated the first post of this thread with a link to the latest version of BD-RB (v0.50.22). Changes for this release:
- Added three more supported CODECs to the import capability (HFYU, LAGS, and ULY2). Automatic conversion to AVC will occur during import. - Made changes to the way VFR is handled on import. Now it is converted, during import, to CFR. Avoids annoying desync, and makes handling much cleaner. - Added new hidden option. IMPORT_VFR_FILM (see HIDDENOPTS.TXT) allows you to choose between importing VFR sources to FILM or VIDEO (23.976/29.97 fps) rates. - Added new hidden option. IMPORT_VFR_SCAN (see HIDDENOPTS.TXT). Sometime MediaInfo does not catch a VFR source. This option tells BD-RB to perform a complete scan of all frame timecodes in a source file to look for VFR. Especially useful when you can't get a file's audio to sync during import because VFR isn't detected. It can add a couple minutes to import time. - Corrected an issue in which importing to an existing import folder could result in previous PSEUDO settings remaining even if they no longer apply. - Fixed an issue that remained in v0.50.21 in which a 3D source feature that is flagged for the base view to be the right picture was not carrying over when outputting to a non-ALTERNATE movie-only structure. The result would be an apparent swapped left/right picture. - Updated the included version of mkvextract and mkvmerge to v9.7.1. - Other minor corrections and cosmetic fixes. |
#25574 | Link |
@jdobbs
BD-RB 0.50.22. Trying to import any of the newly added 3 lossless formats (thanks!) throws the error: Code:
[20:17:25] Importing: HFYU - [20:17:27] Importing video file: (1 of 1) - Preparing AVI for processing... - Collecting audio/video streams from source... - Converting VFR source to CFR format... [20:17:29]ERROR: Failed VFR conversion. Aborted I assume you still have my 3 testclips. Did you try with these? Do I have to force a full timecode scan? |
#25575 | Link | |
[Edit] DAMN!!! I had added a hidden option called IMPORT_VFR_FORCE for testing -- and I mistakenly defaulted it to ON. Damn. Damn. Damn. I'll fix it and post a new release in a little while. In the meantime you can set IMPORT_VFR_FORCE=0 in your INI file. Last edited by jdobbs; 27th January 2017 at 21:44. |
#25576 | Link | |
#25577 | Link |
BD Rebuilder v0.50.23
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.50.23). Changes for this release:
January 27th, 2016 - v0.50.23 - Added three more supported CODECs to the import capability (HFYU, LAGS, and ULY2). Automatic conversion to AVC will occur during import. - Made changes to the way VFR is handled on import. Now it is converted, during import, to CFR. Avoids annoying desync, and makes handling much cleaner. - Added new hidden option. IMPORT_VFR_FILM (see HIDDENOPTS.TXT) allows you to choose between importing VFR sources to FILM or VIDEO (23.976/29.97 fps) rates. - Added new hidden option. IMPORT_VFR_SCAN (see HIDDENOPTS.TXT). Sometime MediaInfo does not catch a VFR source. This option tells BD-RB to perform a complete scan of all frame timecodes in a source file to look for VFR. Especially useful when you can't get a file's audio to sync during import because VFR isn't detected. It can add a couple minutes to import time. - Corrected an issue in which importing to an existing import folder could result in previous PSEUDO settings remaining even if they no longer apply. - Fixed an issue that remained in v0.50.21 in which a 3D source feature that is flagged for the base view to be the right picture was not carrying over when outputting to a non-ALTERNATE movie-only structure. The result would be an apparent swapped left/right picture. - Corrected an error introduced in v0.50.22 that forced VFR to CFR conversion during import. - Updated the included version of mkvextract and mkvmerge to v9.7.1. - Other minor corrections and cosmetic fixes. |
#25580 | Link | |
[00:04:04] Importing: ULY2 - [00:04:06] Importing video file: (1 of 1) - Preparing AVI for processing... - Scanning for Variable Frame Rate... - Collecting audio/video streams from source... - Converting codec to compatible format... [00:04:09]ERROR: Failed codec conversion. Aborted. Sorry, the problem was here: A typo in the .INI. ![]() Never mind. Last edited by Sharc; 28th January 2017 at 09:45. Reason: Problem solved |
