#31101 | Link | |
![]() Join Date: Oct 2001
I'll look at it -- but right now it's just confusing. You're better using BD-RB on a BD M2TS anyway. That way things like chapters etc. are kept (from the BD's MPLS file). [Edit] Even weirder. By default it uses the name of the input file (in my case 00512.m2ts) in creating the output file name. So it tries to create "00512.mkv". If I change the output name so it includes an alpha character (like "A00512.mkv" or "00512A.mkv" it works fine. Then if I change the name to "00000.mkv" (also all numeric) -- it works. I have to be missing something??? Last edited by jdobbs; 9th January 2022 at 13:57. |
#31102 | Link |
Sure, don't waste your time on it, I just thought I give it a try, since most movies are contained in one m2ts
![]() How do you set m2ts as output? I can only choose between mkv, mp4 and mov ![]() And I just wanted to ask about the commandline execution, but then I saw the nvlastcmd.txt in the workfolder ![]() Edit: running the command in cmd runs fine and gives a proper mkv output Last edited by cartman0208; 9th January 2022 at 14:07. |
#31103 | Link | |
![]() I just looked, and the reason I get the "permission denied" is because the NVENCC process is actually running. So apparently I've gotten a signal that the process failed within NVENCCRE -- when it actually didn't. Trying to run the process again on the same output file name is the issue -- not the numeric name. I set the target to M2TS manually by using the command line in "NVLASTCMD.TXT" (I put that there mainly for debugging). Last edited by jdobbs; 9th January 2022 at 14:07. |
#31104 | Link |
Yeah, noticed that also... my GPU memory was about 90% used and I wanted to know why because I couldn't see open programs. From Task manager I could see nvencc.exe still running in multiple instances, but no other activity, neither encode or decode. Killing those processes freed the memory.
#31105 | Link | |
#31106 | Link | |
-- Input : BDAV, 0x0, fps ![]() |
#31107 | Link | |
#31108 | Link | |
#31109 | Link | |
![]() Thanks for fixing it, jdobbs! |
#31110 | Link | |
#31112 | Link |
@jdobbs, I’ve fixed the large images as requested; hope this detailed report is OK now
--- Hi, I hope you are all doing well. I found out this great application for the first time and I've been trying to use to compress a Blu-Ray movie decrypted in my HDD (plain files). I've tried about 25 times; switching the settings around, and still have the same issue. The movie is “A Glitch in the Matrix"; around 35 GB uncompressed. It consists of the menu, main movie, trailer and a Zoom webinar Q&A extra. The most important problem happens with this last extra video. No matter how many settings I switched around, it ends up with the video sped up about 2x (perhaps even more) and the audio running normally. Here are a couple of facts: - I'm trying this on a fresh copy of Windows 10; with everything installed and configured following the readme file and the “Inspect” reports turns out everything OK (posted at the bottom) - If I try to preview the file by right clicking it within BD Rebuilder, it opens in Media Player Classic and it plays wrongly; exactly the same, with the video about twice as fast compared to the audio - If I open the extra file directly from within the source folder, through VLC, it plays perfectly fine - The file in question has two audio tracks that, seemingly, are exactly the same. It's not that one is 5.1 and the other Stereo (or something like that). This will be important later - In my quest to find software to compress Blu Rays, I've tried DVDFab and exactly the same issue resulted after the process finished; with the video extremely sped up. After switching around several settings there, I've found that if I left the two audio tracks for the extra and use software compression (disabling Intel QuickSync), the finished video ended up right! But I'll really love to use BD Rebuilder instead; that's why I'm trying so hard to make it work - If in DVDFab, I left only one audio track (no matter which one); even when disabling QuickSync and with the exact same settings as the previous point, the video again turned out to run extremely fast; while the audio plays normal. I have to left the two audio tracks in for it to render a fine, working video - In my current settings, I have selected the option to not convert DTS, leave HD audio as is, etc; trying to minimize recoding as much as possible. The same issue still persists. - Of course, I have tried the DirectshowSource, LAVF and FRIMSource serving settings; all producing the same results - The only weird thing I've noticed is that, the log for that extra file, shows an “EXIT CODE: -2”, but continues processing as if nothing happened. Of course, I've tried searching for this exit code here and couldn't find anything about it I don't know what issue exactly that damn extra video file has, that makes this fail over and over. I've been working on this for over a week; trying highest quality settings 2 pass (15+ hours), fast, auto, etc.; always the same result. The only thing that worked so far was DVDFab, if I configure it as described above. Some questions that I have in my head: - Why does that file has two seemingly audio tracks and why, if I only leave one in, DVDFab still produces a video 2x sped up? - (This probably related to not knowing how BD Rebuilder works fully) Why when switching on and off the audio tracks in extra, other audio tracks (in different files), switch on and off along with it? - Why the built in Media Player Classic preview also runs the source; untouched file at wrong speed, while VLC plays it fine? Does it have to do with some installed codecs? Remember, this is a fresh Windows 10 installation with nothing crazy going on and I've only ever used VLC for playing An unrelated problem, but that also drove me nuts for the first couple of days, was that the process aborted around 50% with an audio recoding error. I think it's because the track in the main movie is DTS-HD and I've read in some old post that BD Rebuilder might have some problems with that? But should it still be able to convert that audio file too (hence the “leave HD audio alone” option)? When I activated that, BD Rebuilder doesn't try to touch the audio and fully completes, but would be nice to know also why it's not working for conversion of HD audio and if there was anything I could to make it work too. Would you please help me to troubleshoot this in any way you can? Or letting me know how to run some “forensics” on that extra file, to post its data here (codecs; anything that may be useful to troubleshoot)? I'm posting all this information and anything I can think of at the end, for you to be able to see. Thanks in advance for any help you can provide on this matter; as it's truly driving me crazy trying to find out exactly where the problem lies! ![]() OUTPUT LOG [10/01/21] BD Rebuilder v0.61.22 [22:09:10] Source: A.GLITCH.IN.THE.MATRIX.2021.1080P.BLURAY.AVC.DTS-HD.MA.5.1-FGT - Input BD size: 33.05 GB - Approximate total content: [02:27:22.216] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Auto Quality: Very Good (Very Fast), 1-Pass VBR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:09:11] PHASE ONE, Encoding - [22:09:11] Processing: VID_00000 (1 of 5) - [22:09:11] Extracting A/V streams [VID_00000] - [22:23:23] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 156,204 frames - Bitrate: 21,721 Kbs - [22:23:23] Reencoding: VID_00000, Pass 1 of 1 - [00:41:30] Video Encode complete - [00:41:30] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:41:30] Multiplexing M2TS - [00:55:44] Processing: VID_00001 (2 of 5) - [00:55:44] Extracting A/V streams [VID_00001] - [00:55:50] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1280x720 - Rate/Length: 59.940fps, 15 frames - [00:55:50] Reencoding: VID_00001, Pass 1 of 1 - [00:55:51] Video Encode complete - [00:55:51] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [00:55:51] Multiplexing M2TS - [00:55:56] Processing: VID_00002 (3 of 5) - [00:55:56] Extracting A/V streams [VID_00002] - [00:56:10] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,905 frames - Bitrate: 13,820 Kbs - [00:56:10] Reencoding: VID_00002, Pass 1 of 1 - [00:58:10] Video Encode complete - [00:58:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:58:10] Multiplexing M2TS - [00:58:26] Processing: VID_00007 (4 of 5) - [00:58:26] Extracting A/V streams [VID_00007] - [00:58:31] Reencoding video [VID_00007] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 15 frames - Bitrate: 2,031 Kbs - [00:58:31] Reencoding: VID_00007, Pass 1 of 1 - [00:58:32] Video Encode complete - [00:58:32] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:58:32] Multiplexing M2TS - [00:58:36] Processing: VID_00010 (5 of 5) - [00:58:36] Extracting A/V streams [VID_00010] EXIT CODE: -2 - Extracting video streams [VID_00010] - Extracting audio/subtitle streams [VID_00010] - [01:00:42] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1280x720 - Rate/Length: 59.940fps, 126,178 frames - Bitrate: 2,075 Kbs - [01:00:42] Reencoding: VID_00010, Pass 1 of 1 - [01:14:03] Video Encode complete - [01:14:03] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [01:14:03] Multiplexing M2TS [01:14:43]PHASE ONE complete [01:14:43]PHASE TWO - Rebuild Started - [01:14:43] Rebuilding BD file Structure [01:14:51] - Encode and Rebuild complete - WORKFILES folder removed. [01:14:53] JOB: A.GLITCH.IN.THE.MATRIX.2021.1080P.BLURAY.AVC.DTS-HD.MA.5.1-FGT finished. INSPECT LOG [10/02/21] Checking System Settings - BD-Rebuilder v0.61.22 - Windows Version: 6.2 [9200] - Working Path Free Space: 1,331.18GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [10/02/21] Systems Settings Check complete LAST SETTINGS USED ![]() THE FILE IN QUESTION OF THE EXTRA IN BD REBUILDER ![]() THE ORIGINAL FILE CODEC INFO FROM VLC ![]() THE SPED UP FILE CODEC INFO FROM VLC ![]() MESSAGE THAT CAME OUT IN CAMTASIA WHILE IMPORTING THE SPED UP FILE TO CREATE THE SAMPLE (Does it mean anything that Camtasia detected the output as “High Frame Rate”?) ![]() ORIGINAL VIDEO SAMPLE https://youtu.be/1PCVyu4la00 SPED UP VIDEO SAMPLE https://youtu.be/QAoe__M8kOI |
#31113 | Link |
@MrVideo:
Nightly tsMuxer build from 2022-01-24-02-07-36 "Allow muxing of pure EAC3 in Blu-rays" See https://www.videohelp.com/software/tsMuxeR |
#31114 | Link |
I will test this. What caught my eye is the "pure" in your quote. To me that means EAC3 with an AC3 core.
Update: Works great in my Sony UBP-X800M2 bitstreamed to my Denon AVR-X8500H. One step closer to getting BDRB working with these E-AC3 files, with no extra workarounds by Jdobbs. Thanks for the tip about the release.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 25th January 2022 at 06:52. |
#31116 | Link | ||
Over in the tsMuxer thread, there was one guy who tested this with his Oppo player and the player crashed. Ouch! |
#31117 | Link |
So, I tried to create a BD with three programs containing DD+. As I suspected, BDRB recoded the E-AC3 to mono AC3. At that point I then created three BD folders with tsMuxer. I renamed the three structures, appropriately to 1, 2 and 3. Copied over the renamed clip, play and m2ts files. I then edited the three playlists and repointed them to their appropriate m2ts files.
After putting the disc into the BD player, I selected one of the titles and the player went into stop mode, whereby I got the player's home screen. No idea what I did wrong. As a side note, I did not let BDRB do the backup stage. I used the pseudo, temporary, BD folder that was created by BDRB. |
#31118 | Link | |
Replace tsmuxer and tsmuxer4k in the tools folder Load your "mp4" with e-ac3 audio into tsMuxeR (standalone) Create a BD folder IMPORT that BD structure into BD_RB |
#31120 | Link |
OK. The LED bulb finally lit. You didn't catch what I was doing wrong and I finally caught on when you said the import the tsMuxer BD folder. I remembered something else that was mentioned in the thread, and was what was needed to be done in order to import more than one BD and that was to put all of the BDs in the same directory.
Once I did that, all was great. Thanks for the help. It took some nudging, but I finally got there. This will be a lot easier when JDobb updates BDRB to do this. I know, wishful thinking, as it will help both of us and who know how many others. |
