#7561 | Link | |
update: Ran the same encode on a Win XP Pro SP3 32-bit. Same result, unfortunately: Code:
[14:55:19] BD Rebuilder v0.33.02 (beta) - Source: BD_SAMURAICHAMPLOO_D1 - Input BD size: 4,64 GB - Approximate total content: [00:23:22.025] - Target BD size: 22,66 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:55:19] PHASE ONE, Encoding - [14:55:19] Extracting A/V streams [VID_00038] - [14:57:34] Reencoding: VID_00038 (1 of 1) - [14:57:34] Collecting video information - [14:57:34] Keeping original video (no reencode) - [14:57:34] Reencoding audio tracks (if req'd) - [15:09:49] Multiplexing M2TS [15:09:49]PHASE ONE complete [15:09:49]PHASE TWO - Rebuild Started - [15:09:49] Rebuilding stream 00038 [1 of 1] - [15:09:49] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [15:12:07] - Failed to REBUILD Code:
[Status] LABEL=BD_SAMURAICHAMPLOO_D1 VERSION=v0.33.02 (beta) SOURCE_SIZE=4978784256 SOURCE_VIDEO_SIZE=4978784256 TARGET_SIZE=24326963200 REDUCTION=4.88612519626317 RESIZE_1080=0 AUDIO_TO_KEEP=jpn; SUBS_TO_KEEP=all BACKUP_MODE=1 MOVIEONLY_TYPE=5 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=0 [00038] USE_ORIGINAL=1 AUDIO=01 PGS= M2TS_TARGET=24326963200 NSIZE=0 FLINK=-1 MLINK=0 Last edited by colinhunt; 4th April 2010 at 13:22. |
#7562 | Link | |
I've also done "The Wizard of Oz" in full backup with no issues on my Pioneer BDP-120 standalone. Last edited by steveg32; 4th April 2010 at 14:57. |
#7563 | Link |
Ran into a problem, been a long time since i had one, The Title Is Dr Parnasus Region B, i think the problem file(s) are AVC 1080i@25fps, audio is stereo ac3, there is a large one of these files (nearly 2 gig) later in the files list so doing a minimum file encode isnt an option, here is the Log:
[15:43:34] BD Rebuilder v0.33.02 (beta) - Source: DOCTOR_PARNASSUS - Input BD size: 42.09 GB - Approximate total content: [03:00:51.680] - Target BD size: 22.66 GB - Windows Version: 6.0 [6002] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [15:43:37] PHASE ONE, Encoding - [15:43:37] Extracting A/V streams [VID_00000] - [15:43:40] Reencoding: VID_00000 (1 of 16) - [15:43:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 725 frames - Bitrate: 9,327 Kbs - [15:43:40] Reencoding: VID_00000, Pass 1 of 1 - [15:44:33] Video Encode complete - [15:44:33] Reencoding audio tracks (if req'd) - [15:44:33] Multiplexing M2TS - [15:44:35] Extracting A/V streams [VID_00022] - Error in attempt to extract audio/subs. - Not enought buffer for parse video stream. Current frame num 0 [15:44:35] - Failed to retrieve audio, aborted Here is my ini: [Options] RESIZE=0 MODE=0 TARGET_SIZE=23200 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 QUICK_EXTRAS=1 FULL_AVCHD=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 [Paths] SOURCE_PATH=D:\DOCTOR PARNASUS BD\DOCTOR PARNASSUS\ WORKING_PATH=E:\DR P\ any help much appreciated. |
#7564 | Link |
Orphan
[19:08:04] BD Rebuilder v0.33.02 (beta) - Source: ORPHAN - Input BD size: 22,76 GB - Approximate total content: [02:02:55.993] - Target BD size: 7,72 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - RESIZE 1080p to 720p enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [19:08:05] PHASE ONE, Encoding - [19:08:05] Extracting A/V streams [VID_00001] - Error in attempt to extract audio/subs. - 30.5% complete [19:24:36] - Failed to retrieve audio, ------------------------------------------------------- [Options] MODE=1 ENCODE_QUALITY=2 AUTO_QUALITY=1 TARGET_SIZE=7910 QUICK_EXTRAS=0 AUTO_BURN=2 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=1 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 FULL_AVCHD=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=D:\ORPHAN.2009.720P.AC3.DVD9-REVEAL\ORPHAN\ WORKING_PATH=C:\USERS\XXXXXXXX\DESKTOP\XXXX\ http://img641.imageshack.us/img641/3766/errorstd.jpg Last edited by Reveal; 5th April 2010 at 10:50. Reason: PRINTSCREEN |
#7565 | Link |
Sherlock holmes
Hello I'm trying to reencode the Sherlock Holmes blu-ray (region A) to a BD25, first there's an audio that I cannot select, it says it's DTS-Express, Stereo; I believe that is for the picture in picture track, well I can't select it, and when I select backup anyway, I get this:
[12:15:03] PHASE ONE, Encoding - [12:15:03] Reencoding: VID_00181 (1 of 46) - [12:15:03] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,485 frames - [12:15:03] Reencoding: VID_00181, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3299) [12:15:13] - Failed video encode, aborted I tried before with an older 'revision' of FFDSHOW and didn't work either, but worked fine with another movie (NewMoon). Any ideas? |
#7566 | Link | |
![]() Join Date: Oct 2001
#7567 | Link | |
#7569 | Link |
OK... but I wasn't doing a BD5/9. I was trying to encode a single episode into a 1080p MKV using 0.33.2's new output mode. I'm sure a BD25 of Samurai Champloo would come out just fine... hang on, I did do a full backup of disc 1 to BD25 to see what the result looks like; I was a bit worried about the quality since cramming 270 minutes of 1080p (even if it's anime) onto BD25 didn't sound too good. I saw some weird artefacts in the backgrounds and bitrate dropped quite often below 10mbps. I wasn't happy with the quality.
#7570 | Link |
Hi, just an aesthetic bug but... I find that if I untic automatic quality settings and tic ultra high quality then when I restart bd-rb there is no option for ultra high quality anymore however the config file still shows it as a 4. I'm running win 7 x64.
#7571 | Link |
That was a mistake. "Ultra High Quality" was left over from long ago and shouldn't actually ever be visible. The value "QUALITY=4" was meant to only be available via hidden setting.
#7572 | Link | |
[16:38:45] BD Rebuilder v0.33.02 (beta) - Source: SHERLOCK_HOLMES - Input BD size: 35.76 GB - Approximate total content: [03:29:32.100] - Target BD size: 22.66 GB - Windows Version: 6.0 [6002] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [16:38:47] PHASE ONE, Encoding - [16:38:47] Reencoding: VID_00181 (1 of 46) - [16:38:47] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,485 frames - [16:38:47] Reencoding: VID_00181, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3299) [16:38:54] - Failed video encode, aborted even if it could reencode the pip track would have no sound right? thanks |
#7574 | Link | |
#7576 | Link | |
- Windows Version: 6.0 [6002] - AVISYNTH Version: 2.5.8.0, not recommended version - HAALI Splitter: Isn't recommended version - FFDSHOW: 3299, not recommended version - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set incorrectly: [5] - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.33.0.2, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok I guess I should update AVISYNTH, Haali splitter and FFDSHOW what's the recommended version? thanks so much ![]() |
#7578 | Link | |
![]() Good luck ![]() Last edited by Kakashi Sensei; 5th April 2010 at 02:12. |
#7579 | Link | |
I'll check and post results ![]() Update: It worked thanks! and excuse my newbism Last edited by beto21; 5th April 2010 at 02:16. Reason: added the 'update' |
#7580 | Link | |
Programmer (or just 教务长)
Dark Shikari suggested a fix, so I'll try to play with hddvdmux source later (tough thing to do, since the source is a complete mess). Dean |
