#14101 | Link | |
![]() Join Date: Oct 2001
I think the program has gotten to a point where it is stable (for the most part, as long as the helper apps don't get hosed by some other process) -- so I'm now looking at ways to improve speeds. Last edited by jdobbs; 30th January 2012 at 16:03. |
#14102 | Link | |
Or how about starting 4 instances but only giving 2 instances parts to process? Too much of a kludge? ![]() I suppose further means of improving speed would include moving to 64-bit apps and multithreading, like Avisynth-MT. Last edited by colinhunt; 30th January 2012 at 16:46. |
#14103 | Link |
multiprocessing LAVF would be cool to see happening. multiprocessing LAFV x264-64 would be even better. That would definitely give a major speed increase. 80% into the current build and ram usage per instance is holding steady arround 800MB each, total cpu usage at 100%, total ram use at 5.2GB
** edit: recoding for main m2ts complete: job time including splitting and rejoining multiparts 93minutes** i did notice some weird behavior. LAVF was disabled in the setup. yet x264-64 was launched and cpu usage was approx 100% for 1 pass encodes on the secondairy files. According to the release notes from September 5th, 2010 x264-64 should only be launched when LAVF is selected on a 64bit os. My OS is 64bit but lavf was not selected. Code:
[Status] LABEL=FRIENDS_WITH_BENEFITS VERSION=v0.40.01 (beta) SOURCE_SIZE=36453851971 SOURCE_VIDEO_SIZE=35969003520 TARGET_SIZE=24641536000 REDUCTION=.671597352858776 RESIZE_1080=0 AUDIO_TO_KEEP=dut;eng;nld;und; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=dut;eng;nld;und; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 MULTIPROCESS=3 QUICK=0 ENCODE_STEP=1.5 COMPLETED=6 ** edit 3: Iso burning completed at 17.53. Job started on 14.45. So 2hrs for an 125video encoding and 3 blanks" Total size output 23.364.096kb aka 22.2GB Now redoing same job with LAVF enabled. To check time diff Job Restarted at 18.00.00hrs Last edited by Ch3vr0n; 30th January 2012 at 18:01. |
#14104 | Link | |
#14105 | Link |
Thought I'd share this, I'm a not-so-settings-savvy-person.
I just fired up BDRB like I use to do. Usually I select ENCODE_QUALITY=4 and let it run over-nite. But for this test I lowered the quality. The new version 0.40.01 is a lot faster! ![]() Code:
----------------------- [11:49:38] BD Rebuilder v0.39.07 (beta) - Source: xxx_xxx_xxx_x - Input BD size: 43,16 GB - Approximate total content: [02:48:21.091] - Target BD size: 23,05 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [11:49:38] PHASE ONE, Encoding - [11:49:38] Processing: VID_00050 (1 of 1) - [11:49:38] Extracting A/V streams [VID_00050] - [11:56:03] Reencoding video [VID_00050] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 242*184 frames - Bitrate: 13*606 Kbs - [11:56:03] Reencoding: VID_00050, Pass 1 of 2 - [13:29:56] Reencoding: VID_00050, Pass 2 of 2 - [15:14:36] Video Encode complete - [15:14:37] Processing audio tracks - Track 4352 (xxx): Keeping original audio - [15:14:37] Multiplexing M2TS [15:20:30]PHASE ONE complete [15:20:30]PHASE TWO - Rebuild Started - [15:20:30] Rebuilding BD file Structure [15:29:24] - Encode and Rebuild complete [15:29:24]JOB: xxx_xxx_xxx_x finished. ----------------------- ----------------------- [15:38:40] BD Rebuilder v0.40.01 (beta) - Source: xxx_xxx_xxx_x - Input BD size: 43,16 GB - Approximate total content: [02:48:21.091] - Target BD size: 23,05 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:38:40] PHASE ONE, Encoding - [15:38:40] Processing: VID_00050 (1 of 1) - [15:38:40] Extracting A/V streams [VID_00050] - [15:45:13] Reencoding video [VID_00050] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 242*184 frames - Bitrate: 13*606 Kbs - [15:45:13] Reencoding: VID_00050, Pass 1 of 2 - [16:29:37] Reencoding: VID_00050, Pass 2 of 2 - [17:13:58] Video Encode complete - [17:13:59] Processing audio tracks - Track 4352 (xxx): Keeping original audio - [17:13:59] Multiplexing M2TS [17:20:06]PHASE ONE complete [17:20:06]PHASE TWO - Rebuild Started - [17:20:06] Rebuilding BD file Structure [17:29:10] - Encode and Rebuild complete [17:29:10] JOB: xxx_xxx_xxx_x finished. ----------------------- |
#14109 | Link |
Now that one of the three x264 instances finished its job and the process is running two instances only, FPS went from ~17 to ~18.5 (now actually 19.00, whee! ... less than 10% to go and fps is now 19.50.). And while total CPU usage is still at 100%, the PC is much more responsive to use than it was when 3 instances were running.
It will be interesting to see how many instances BD-RB will launch when I set multiprocess to automatic (i.e. 1). On my PC 4 instances is optimal for Pass 1 (as extrapolated from current data) but 2 instances works best for Pass 2. Last edited by colinhunt; 30th January 2012 at 20:08. |
#14110 | Link |
@Jdobbs:
2nd rebuild of Friends with Benefits completed, LAVF enabled Job 2: LAVF (multithread enabled, though according to you not used in LAVF situations) Job Start: 18.00hrs Job completion: 20.26hrs (including iso burning) Total duration: approx 2.5hrs Job 1: multithread enabled Job Start: 14.45 Job Completion: 17.53 (including iso burning) Total Duration: approx 3hrs 10 minutes Total timeLOSS with multi thread (including splitting & rejoining) 40 minutes unless my math is off I'd say that's a pretty significant timeloss for an experimental feature. Last edited by Ch3vr0n; 30th January 2012 at 20:38. |
#14111 | Link |
BD-RB just finished Pass 2 of a 290,138 frame main movie. Based on experience I can estimate previous versions of BD-RB would have taken approx. 400-450 minutes to process that Pass 2. This new version of BD-RB ran Pass 2 in 296 minutes with multiprocess enabled... and it would have been even faster if it had been running only 2 instances of x264 from the start instead of 3. Pass 1 took 100 minutes and I'm pretty certain earlier versions would have taken at least twice as long, perhaps more.
I'd say the total time saved is something like 3-4 hours. You know what that is? Awesome, that's what. |
#14112 | Link |
1 instance
- [15:33:42] Reencoding: VID_00000, Pass 1 of 2 - [15:58:33] Reencoding: VID_00000, Pass 2 of 2 - [17:18:10] Video Encode complete 3 instances ram max pass 1 ~ 4,05GB ram max pass 2 ~ 3,65GB - [13:44:10] Reencoding: VID_00000, Pass 1 of 2 - [14:03:00] Reencoding: VID_00000, Pass 2 of 2 - [15:22:17] Video Encode complete 4 instances ram max pass 1 ~ 5,06GB ram max pass 2 ~ 4,5GB - [10:40:58] Reencoding: VID_00000, Pass 1 of 2 - [10:59:39] Reencoding: VID_00000, Pass 2 of 2 - [12:19:40] Video Encode complete I believe that using two instances in my case would be a good balance between speed on the first pass and consumption of ram. |
#14113 | Link |
Running the same backup again on v0.39.07 to see what sort of FPS figures I get.
Source: AVC/480i (DEINT processing enabled) PASS 1 v0.39.07 - 179 fps v0.40.01 - 381 fps (3 instances) PASS2 v0.39.07 - 100 fps v0.40.01 - 117 fps (3 instances) from ~75% completion onwards: v0.39.07 - 92 fps v0.40.01 - 133 fps (2 instances) Source: AVC/1080p23.976 PASS 1 v0.39.07 - 30 fps (...and dropping) v0.40.01 - 63 fps (3 instances) PASS 2 at 10% completion: v0.39.07 - 13 fps (higher than expected!) v0.40.01 - 17 fps (3 instances) I user bd-rebuilder.log to compare how long it took for 0.39.07 and 0.40.01 to make two passes of the same main movie file using the exact same settings. v0.40.01: 6 hours 36 minutes v0.39.07: 7 hours 54 minutes Despite higher fps figures especially for Pass 1, the difference in total time is not quite as big as I originally estimated. I was expecting to see 11-12 fps for Pass 2 from v0.39.07 but the disc I picked for the test was "easier" to re-encode than I thought it would be. Last edited by colinhunt; 31st January 2012 at 10:01. |
#14114 | Link | |
#14117 | Link | |
#14120 | Link |
x264-64 and # x264 threads
I set multiprocess=3 but I'm only seeing one instance of x264 and it is 32-bit. What do I need to do to use multiple instances of 64-bit x264?
I'm seeing the desired increase in CPU usage but only modest memory usage increase. Intel i7 2600K - 8GB Windows 7 x64. Last edited by dfsooner; 30th January 2012 at 22:54. |
