Old 7th November 2012, 13:35   #16081  |  Link
Originally Posted by lauguru View Post
yes, that I know, but I think it would be a good option for people who do not know. (A friend to another, I commented) but thanks for answering
That would be a major project. I don't see it happening any time soon.
Old 7th November 2012, 13:42   #16082  |  Link
lauguru
ok, it was just to comment, it would be possible. thanks
lauguru is offline   Reply With Quote
Old 9th November 2012, 06:31   #16083  |  Link
rippn
I just snagged v0.42.04 and I'm getting
- X264: Wrong version found
Any ideas? Thanks.
Edit: Nevermind, knew it was on my end since no one else had the problem. I usually just copy new versions on top of the old to retain settings, but some reason this was causing the error. Even going and getting the new x264 binaries didn't fix it. Anyway just deleted everything and started fresh resolved it.
rippn is offline   Reply With Quote
Old 9th November 2012, 17:13   #16084  |  Link
setarip_old
setarip_old's Avatar
@rippn
Hi!
Glad to hear you resolved your self-created problem;>}
If you read post #1 of this thread, you'll see that it clearly states that you MUST use the versions of supporting programs that are listed/linked to in that post.
I'm sure jdobbs will look forward to your beta testing contributions.
Once again, glad to hear you've resolved it...
Old 10th November 2012, 03:41   #16085  |  Link
AmigaFuture
AmigaFuture's Avatar
The Hunger Games
Hi. At 51 minutes into the movie I notice the jerky effect as the segments where changed. Segment changes before then looked and sounded smooth.
Config:
[Options]
VERSION=0.42.0.4
MULTIPROCESS=0
ENABLE_TEST=1
DTSX_ENABLE=0
FORCE_NOENCODE=0
DVD_IMPORT_THRESHOLD=1
SD_PROGRESSIVE=1
MODE=1
ENCODE_QUALITY=5
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=23500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=340
QUICK_EXTRAS=1
ENABLE_BLANKING=1
MOVIEONLY_TYPE=0
ALTCRF=20
ALT_TARGET=7900
ALTMETHOD=2
ALTAUTOCROP=0
[Paths]
SOURCE_PATH=J:\!BLU-RAY RIPS\THE_HUNGER_GAMES\
WORKING_PATH=E:\BLU-RAY\REBUILDER\
Old 10th November 2012, 14:25   #16086  |  Link
RobertM
I saw something like this a while ago on one of the Harry Potter movies. There was a slight stutter at the boundaries of the original m2ts files. The video hadn't been re-encoded since it could fit on a BD25. I used the ForceEncode option and found that the stutters went away after that. It seemed odd to me, at the time, but it worked.
I have no idea if that would affect what you are seeing. Just FYI.
Old 11th November 2012, 06:20   #16087  |  Link
AmigaFuture
RobertM: I hadn't considered that, yet. I noticing using MultiAVCHD to remove the Languages and SUPs on "The Hunger Games" and "Toy Story" movies that tsMuxeR is removing overlapping audio frames. I wonder if tsMuxeR is doing the same with BD-RB and that has something to do with it because the burned project results in the same with BD-RB. Thank You.
I tried it with re-encode forced..still same. I then had BD-RB reencode the AC3 also, still the same...with The Hunger Games.. Movie and Menus was used. Now I'm trying Full Backup with nothing blanked by my choosing.
Old 11th November 2012, 14:56   #16088  |  Link
If you are rebuilding all combined into a single unit (movie-only) -- yes you are removing the overlapping audio frames in BD-RB via TSMUXER. But, if you keeping the original (multi-part) format you are not removing them (nor should you).
I'm confident that isn't an issue -- but I'll go back and make sure, just to be safe. I want to make sure that the length of the audio access unit (frame size) of AC3 is properly considered when converting from DTS. But, frankly, if this truly were an issue -- I would expect to have seen hundreds of bug reports from people who are doing full backups of multi-part sources.
Old 11th November 2012, 19:35   #16089  |  Link
AmigaFuture
@jdobbs Thank You for the reply. I get your info, and noticed rebuilding to an MKV does produce a smooth movie. So tsMuxeR Is doing the same with BD-RB...that confirms what I thought. I'd love to know the differences between your hardware and mine so I could reproduce it with my 3 machines. Whatever it is will be notice soon enough. No worries here.
Old 13th November 2012, 12:08   #16090  |  Link
rippn
Just wanted to pass this info on.
Just upgraded to windows 8 and when trying to register the "MSCOMCTL.OCX" using the "REG_MSCOMCTL.BAT" running as administrator I kept getting the error "The module "MSCOMCTL.OCX" failed to load. Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files. The specified module could not be found."
Per the following linked site, Windows 8 UAC is causing problems for people trying to manually register OCX and DLL files. More info about this here.
That same site also created a tool "OCXregisterTool.exe" that can be downloaded here.
Just put "OCXregisterTool.exe" in the same folder you extracted BD Rebuilder in, run OCXregisterTool as administrator, and click "Register MSCOMCTL.OCX" and your all set.
Hope that helps.
Originally Posted by lukappaseidue View Post
so, last step, I "run as administrator BDRB..
no luck.... system crash again (need to push reset button)
Edit: Just wanted to confirm, running BD Rebuilder as administrator in windows 8 locks the system up entirely. Using the OCXregisterTool as mentioned above and running BD Rebuilder normally works great, no crash or lock up.
Old 13th November 2012, 15:10   #16091  |  Link
I'm sure Microsoft will at some point release a patch that corrects this and the other issues associated with Windows 8. That's probably about where I'll upgrade. This is a lesson learned from Windows 1.0, Windows 2.0, Windows 3.0, Windows NT, Windows 95, Windows 98, Windows XP, Windows Vista, and Windows 7.
The bottom line is that this is a Microsoft issue, not a BD-RB issue. Their utility (regsvr32.exe) is the one that has being replaced by the software you mention. What's wrong with that picture?
M$ never gets it right the first time.
Old 14th November 2012, 05:42   #16092  |  Link
maonstad
AnyDVD HD menu Imcompatible
I ran inspect and this is what I get:
- Windows Version: 5.1 [2600]
- HAALI Splitter: [1.11.96.14], Ok
- FFDSHOW: [4489], not recommended version
- AnyDVD Speed Menu: Incompatible
- BD Rebuilder v0.42.0.3, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Any concerns with The Speed Menu?
Also X264 crashes upon doing a stored directory of Prometheus (full backup to 25 gb).
But if I do only main movie, BD-RB works fine.
maonstad is offline   Reply With Quote
Old 14th November 2012, 07:34   #16093  |  Link
AmigaFuture
I think I found the challenge with "The Hunger Games"..I reripped with AnyDVD HD 7.1.0.0 yet I changed something I didn't check... Testing..
Old 14th November 2012, 12:13   #16094  |  Link
Ch3vr0n
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
You're using the wrong version of ffdshow. Change to the correct one.
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk
Old 14th November 2012, 14:56   #16095  |  Link
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
I haven't tested it in a while. But at one point there were issues with SPEEDMENU that makes it incompatible -- so I don't support bug reports for rips that use it.
Old 14th November 2012, 16:40   #16096  |  Link
maonstad
Thanks. I believe I did have the correct fdshow and the same error showed up. But at least I know that the speedmenu is incompatible and will rip movies without it.
Mark
Old 14th November 2012, 18:33   #16097  |  Link
omegaman7
omegaman7's Avatar
I wouldn't be so quick to judge FFDSHOW. For a time, I used Ripbot264. It requires constantly updated FFDSHOW versions. BDrebuilder had no troubles with the versions I ran. Of course if I had any problems, that would be the first place I'd look. Jdobbs has made troubleshooting a fair amount easier, with the inspect tool
Old 14th November 2012, 19:13   #16098  |  Link
Ch3vr0n
And let that tool now exactly report he's using the wrong version as i said early 4483 is not a supported bdrb ffdshow version
Old 14th November 2012, 23:15   #16099  |  Link
soneca
I also have used the latest versions of ffdshow without any problems, but if I have a problem, I have no right to complain.
But I also think recent versions should be tested from time to time so that the supported version does not become as obsolete.
Old 14th November 2012, 23:38   #16100  |  Link
omegaman7
omegaman7's Avatar
They release versions of FFDSHOW fairly often, last time I checked. That would make things very BUSY for Jdobbs LOL! Not a big deal for me to test myself. If there's an issue relating to FFDSHOW, simply rollback and see what happens I think some people are simply afraid to get their hands dirty LOL! Nah, they just wanna click click burn. Which I guess I can appreciate. I've been there. And for some people, these jobs do take a fair amount of time
