Old 4th July 2013, 20:59   #17561  |  Link
AmigaFuture
AmigaFuture's Avatar
They're hidden features. I am guessing, JDobbs doesn't want them showing in the main GUI because of that....at least, perhaps not until it's more ready for final release? I'm cool with it because I know their directory paths. I have wondered..but again, beta...
Old 4th July 2013, 22:05   #17562  |  Link
gonca
@DeVeDe
Do you mean the "Source Path", "Working Path", and "Stream" in the window you see when you first launch BD_RB.
Old 4th July 2013, 22:33   #17563  |  Link
HWK
HWK's Avatar
I assume we're talking about movie-only mode. It doesn't pick the biggest. It chooses the one most likely to be the feature. It probably picked the middle one because the time was close -- and it assumed the longer episode was the "extended version". There is no indicator on a disc that says "I'm a series disc" -- so all discs are assumed to be a feature, possible extended versions, and extras. In "Quick-Play" mode, it will also not include a title that is a combination of several other titles (because it encode more than once and double the size of the disc).
Jdobbs, I was thinking of adding a code which allow user to select which title to backup from series, rather than choosing the largest one. For example if multiple titles appear with similar length display all of them and let user decide.
Old 4th July 2013, 22:45   #17564  |  Link
But then I'd have people complaining that it doesn't select the feature automatically.
BD-RB doesn't select the largest title. It goes through a series of logical steps to try and determine which playlist is the feature -- and selects that one.
Old 4th July 2013, 23:31   #17565  |  Link
Chuckwagon
I thought this was what the "Other Movie-Only Playlist" option was for, to select a playlist other than what BD-RB chooses by default. It's what I've been using to back up each individual episode on series discs.
Chuckwagon is offline   Reply With Quote
Old 4th July 2013, 23:48   #17566  |  Link
gonca
@Chuckwagon
That's how I do it as well.
Old 5th July 2013, 00:20   #17567  |  Link
HWK
HWK's Avatar
oh, in that case may be hidden option.
Old 5th July 2013, 02:38   #17568  |  Link
Yes, that's for when it doesn't pick the right one. It's right 99% of the time, but nobody's perfect. It's also the way you choose each episode individually on a series disc.
Old 5th July 2013, 04:00   #17569  |  Link
RobertM
Whenever I find an example where the wrong playlist is selected by default I just pick the the right one manually. But would it help you to improve your algorithm by knowing which titles don't work as expected and which is the correct playlist for that disc? I have a suspicion that reporting all such cases would just end up being a lot of noise for you to sift through, but perhaps there would be some useful data in there. Just thought I would ask
Old 5th July 2013, 09:47   #17570  |  Link
nandrews
Trying to reduce a BlueRay copy to BD25 I am getting the following
[07/05/13] BD Rebuilder v0.44.14 (beta)
[08:56:12] Source: STORY_OF_INDIA_D1
- Input BD size: 42.96 GB
- Approximate total content: [02:58:59.440]
- Target BD size: 22.95 GB
- Windows Version: 6.0 [6002]
[08:56:13] PHASE ONE, Encoding
- [08:56:13] Processing: VID_00003 (1 of 3)
- [08:56:13] Extracting A/V streams [VID_00003]
- [09:13:54] Reencoding video [VID_00003]
- Rate/Length: 25.000fps, 88,550 frames
- Bitrate: 16,477 Kbs
- [09:13:54] Reencoding: VID_00003, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.44.14 (beta)
- HAALI Splitter: 1.11.96.14, Ok
- FFDSHOW: 4422, Ok
- FFDSHOW VC-1 set incorrectly: [0]
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
[09:13:59] - Failed video encode, aborted
Is the failure likely due to - FFDSHOW VC-1 set incorrectly: [0]? If so how could I correct that?
Nigel
nandrews is offline   Reply With Quote
Old 5th July 2013, 10:03   #17571  |  Link
Ch3vr0n
you can do that by following the instructions in the very first post. You managed to set mpeg2 and avc properly so just do it for VC1 too
Old 5th July 2013, 11:29   #17572  |  Link
nandrews
Many thanks for that and your quick response
I have corrected the VC1 but still it fails
[10:24:20] Source: STORY_OF_INDIA_D1
[10:24:21] PHASE ONE, Encoding
- [10:24:21] Processing: VID_00003 (1 of 3)
- [10:24:21] Extracting A/V streams [VID_00003]
- [10:42:12] Reencoding video [VID_00003]
- [10:42:12] Reencoding: VID_00003, Pass 1 of 1
- FFDSHOW: 4422, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
[10:42:16] - Failed video encode, aborted
Is there anything else I can do?
This is using a copy of the BD produced by AnyDVD
I have also tried DVDFAB on it, both the copy and the original BD and that fails too.
Thanks again
Nigel
Old 5th July 2013, 16:08   #17573  |  Link
lauguru
hello
there is any command, not to convert the main mt2s?
the extras are in mpeg2 and if converted to mpeg4 with h264, the bd would enter into a BD25
I just want to convert the extras
FORCE_NOENCODE=n
as applied to a particular file?
thanks
lauguru is offline   Reply With Quote
Old 5th July 2013, 17:55   #17574  |  Link
HWK
HWK's Avatar
Originally Posted by lauguru View Post
hello
FORCE_NOENCODE=n
thanks
FORCE_NOENCODE=n doesn't apply to file. So it wouldn't work.
Old 5th July 2013, 18:27   #17575  |  Link
hello
FORCE_NOENCODE=n
thanks
If you wanted to force no encode you'd use:
FORCE_NOENCODE=1
But, no, there is currently no way to encode only the extras and leave the feature intact.
Old 5th July 2013, 18:54   #17576  |  Link
lauguru
FORCE_NOENCODE=1
would not be bad, add that function, as many include extra blurays and convert mpeg2 to mpeg4, the main movie would remain intact
Old 5th July 2013, 19:34   #17577  |  Link
Malevolo
i have the following issue with the latest version of bdrebuilder,
i try to process pinocchio into 25gb and here's what i got:
[12:53:00] Source: PINOCCHIO_FULLBLURAY
- Input BD size: 31,82 GB
- Approximate total content: [02:02:02.898]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
[12:53:00] PHASE ONE, Encoding
- [12:53:00] Processing: VID_00001 (1 of 18)
- [12:53:00] Extracting A/V streams [VID_00001]
- [12:57:40] Reencoding video [VID_00001]
- [12:57:40] Reencoding secondary video [TRK_02]
- Rate/Length: 23,976fps, 126.216 frames
- Bitrate: 22.323 Kbs
- [12:59:33] Reencoding: VID_00001, Pass 1 of 1
- [13:23:09] Video Encode complete
- [13:23:09] Processing audio tracks
- Track 4356 (eng): Keeping original audio
- Track 4358 (spa): Keeping original audio
- [13:23:09] Multiplexing M2TS
- Error in attempt to multiplex: MUX_00001.meta
- Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed.
[13:24:16] - Failed to build structure, aborted
i run bdrebuilder on windows 8 x64, i already installed haali, avisynth, fddshow and also win7 tweack codec....
what could possible goes wrong?
Can somebody help me??
thank you....
Malevolo is offline   Reply With Quote
Old 5th July 2013, 19:59   #17578  |  Link
HWK
HWK's Avatar
Originally Posted by Malevolo View Post
thank you....
Possibly a bad rip. What program you used to rip?
Old 5th July 2013, 21:14   #17579  |  Link
Definitely a bad rip. That's the only way you could get a PES packet that large. Since the video reencoded, I'd say it's probably one of the audio streams.
Old 5th July 2013, 22:44   #17580  |  Link
RoyGBiv-inRI
- FFDSHOW: 4422, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
Thanks again
Nigel
I had this problem. Everything was working fine until I installed a program that added some codecs of its own (which I was afraid it might even though in the installation step I told it not to add any additional codecs). Removing that program, and then removing and re installing FFDSHOW solved the problem.
SMK
RoyGBiv-inRI is offline   Reply With Quote
