Old 1st September 2020, 11:18   #1  |  Link
RainbowThief
X264 Blu-ray encoding on a Mac?
Is there a user guide for this? I can't seem to find any information.
RainbowThief is offline   Reply With Quote
Old 2nd September 2020, 21:37   #2  |  Link
benwaggoner
The top sticky has a lot of information on this https://forum.doom9.org/showthread.php?t=154533
Is there something Mac-specific you want to know?
Ben Waggoner
My Compression Book
Old 2nd September 2020, 22:22   #3  |  Link
Richard1485
Download x264 from videohelp.com, and use any guide you like. The options are the same regardless of platform.
Old 6th September 2020, 11:59   #4  |  Link
RainbowThief
Basically, how to install x264 on a Mac. A beginner's guide would be helpful.
I have experimented with Compressor and Media Encoder, but some areas of film (grain etc) sometimes cause problems.
The encodes need to be compliant with DoStudio.
Old 6th September 2020, 17:46   #5  |  Link
Richard1485
You don't need to install it. It's a binary. Run it in the terminal. I don't know anything about DoStudio, but if it's any good, it'll accept BD-compliant files, so use the guide to which I linked in my last post.
Old 6th September 2020, 19:03   #6  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
Just use Handbrake
Old 6th September 2020, 20:38   #7  |  Link
mp3dom
DoStudio is discontinued and, above all, it doesn't made all the checks for bd compliancy. It is possible to mux a 23.98 SD video which is not compliant, and mux SD subtitles on an HD source...
You need to be sure to use the right settings of x264 because there's high chance it will accept the file even if it's not compliant.
mp3dom is offline   Reply With Quote
Old 10th September 2020, 09:56   #8  |  Link
RainbowThief
Originally Posted by froggy1 View Post
Just use Handbrake
Does Handbrake produce Blu-ray compliant encodes? Would like more info on this please.
Old 10th September 2020, 16:07   #9  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Not by itself. You got to tell Handbrake.
You may want to check the commandline and compare to
blu-ray, mac, x264
