31st January 2018, 21:53 | #14582 | Link |
Last 5 post moved to Create Dolby Atmos thread.
1st February 2018, 00:00 | #14583 | Link | ||
But I'd want to be 101% doubt free. Is DTS-HD MA decoding (for all channels and bit depths) *really* lossless? I've seen the tired "libDcaDec reported the warning "XLL output not lossless"." since the start of times for every single DTS-HD MA track I converted. Looking for old posts it all points to it indeed being lossless. And another thing. On the libDcaDec page it says Quote:
1st February 2018, 08:32 | #14584 | Link |
The state of libDcaDec as a separate project with separate source repository may be deprecated. But its development continues inside the ffmpeg project. So if eac3to reports to use libDcaDec, it does not explain explicitly that this may mean "libDcaDec as developed further as a part of ffmpeg".
25th February 2018, 20:14 | #14586 | Link | |
Special SeeD
Is there a way to remove DialogNorm on EAC3 7.1 tracks? I keep getting this error when trying:
26th February 2018, 00:55 | #14588 | Link |
Hello SquallMX!
eac3to don't support that E-AC3 tracks, bug already reported: http://bugs.madshi.net/view.php?id=450 Pending to fix.
27th February 2018, 21:23 | #14590 | Link | |
Special SeeD
Yes, is a workaround that works fine, unfortunately you lose the 7.1 data. |
27th February 2018, 21:26 | #14591 | Link |
It may still be possible not to try to bring the audio stream in sync by changing it, but by multiplexing it (demultiplexed without any changes) into the copy with the same delay.
1st March 2018, 14:55 | #14592 | Link |
To make a longer post brief, there seem to be issues with the Haali muxer eac3to uses for matroska muxing. Is there any chance that this could be replaced with support for more recent muxers using libebml/libmatroska?
Alternatively, could users at least get a warning when using mkv output, so we know to expect problems? |
1st March 2018, 18:12 | #14593 | Link |
does eac3to have difficulties with UHD BDs which have gaps due to multiple .m2ts files? I heard makemkv does handle them correctly.
1st March 2018, 18:34 | #14594 | Link |
I have never had any issues in that regard, eac3to has always worked well with UHD BDs for me. I point it to the playlists, like I do for regular blurays.
madVR options explained |
1st March 2018, 20:29 | #14595 | Link |
refering to those UHD BDs with seamless branching titles
2nd March 2018, 15:31 | #14596 | Link |
Matroska find' ich toll
Hi madshi
Only eac3to is able to remove dialog normalization(DN) from streams(ac3). I have many mkv files muxed from VOB files with ac3 streams which include the DN. Feature request: Is it possible that eac3to remove the DN from the ac3 streams without demuxing-remuxing? |
6th March 2018, 13:21 | #14597 | Link |
Acid fr0g
I am not using eac3to anymore as the ac3 encoding output is really outdate and somehow problematic. My work path now is demux audio tracks and feed them to FFMpeg. Is there any plan to use it as encoding/decoding library or is it a long way to go?
@turment on Telegram |
eac3to |
