26th January 2018, 13:14 | #2923 | Link |
Professional Code Monkey
R43-RC2
r43: updated to zimg v2.7.2 a tuple is now only returned from get_output in python when alpha actually exist, this undoes the python syntax change in r41 fixed a possible hang on error in vspipe, regression introduced with the alpha support in r41
26th January 2018, 15:05 | #2924 | Link |
I'm Siri
I wanna remove useless samples in my training set, the ones that don't have enough high frequency components
lemme rephrase that, after I extracted the high frequency components from each frame, I wanna remove frames whose standard deviation is below a certain threshold, and record which frames were removed in a log file, then read the log file and remove the same frames in another sequence, how do I do that? |
26th January 2018, 16:20 | #2925 | Link | |
1st pass: mvf.PlaneStatistics shows the method of calculating the std. A Python list can be created outside the runtime function, then once the std of each frame inside the runtime function is calculated, the list is used to store the label. The std of the whole video can be calculated via vspipe or simply vsedit's benchmark. And then the list is stored in the disk. 2nd pass: core.std.DeleteFrames can be used to delete those frames after reading the list. Last edited by WolframRhodium; 26th January 2018 at 16:40. |
26th January 2018, 18:14 | #2926 | Link | |
26th January 2018, 18:31 | #2928 | Link | |
I'm Siri
I hate coding |
26th January 2018, 18:41 | #2930 | Link |
I'm Siri
u run a high pass filter (low pass filter + make dif) on ur clip and extract the high frequency components, it doesn't have to be extra accurate, I'm just removing useless image blocks from my super resolution neural net training set, image blocks without clear edges or fine details or textures are obviously garbage data to super resolution, they are doing nothing but wasting my training time, after u extracted the high frequencies, u calculate the standard deviation or the absolute or squared sum of the high frequencies to determine if a certain sample has enough amount of high frequencies for super resolution or not
26th January 2018, 21:28 | #2932 | Link |
If it is short, use the CODE bbCode block; if it is longer, use any pastebin service (many have syntax highlighting for programming languages).
I am sure Wikipedia once had a comparison chart of such services, but it seems to be gone. |
27th January 2018, 00:40 | #2933 | Link | |
filter_list = [] # list to store hi freq frame numbers for frame in clip.frames(): frame_std = frame.props['PlaneSTD'] frame_num = frame.props['FrameNum'] if frame_std > 0.0031: # std threshold if frame_num not in filter_list: filter_list.append(frame_num) |
27th January 2018, 01:39 | #2934 | Link | |
filter_list = [] def _PlaneStd(n, f, clip): frame_std = frame.props['PlaneSTD'] if frame_std > 0.0031: filter_list.append(str(n)) if n == clip.num_frames - 1: outFile = open('a.txt', 'w+') outFile.write('{}'.format("".join(filter_list))) return clip clip = core.std.FrameEval(clip functools.partial(_PlaneStd, clip=clip), prop_src=clip) Last edited by WolframRhodium; 27th January 2018 at 01:44. |
27th January 2018, 01:43 | #2935 | Link |
I'm not sure that script will always work properly. Frames can be (and commonly are) processed out of order. Just saying...
Since we're on the subject I'm planning to add support for writing frame properties to a file in vspipe. Unfortunately for you I didn't get around to implementing it yet. Also, using get_frame() in python is always slow, it basically forces single threading.
27th January 2018, 03:01 | #2936 | Link | |
29th January 2018, 20:43 | #2938 | Link |
R43 RC4
One final RC (for real this time) since many small nitpicky things were discovered. Code:
r43: updated to zimg v2.7.2 all vsscript functions are now internally guarded by a mutex to make them threadsafe changed boxblur defaults to hradius and vradius=1, this makes more sense than having it throw an error with default arguments added xyz as an alias for st428 in resize add vsscript_getvsapi2 function which takes the required vapoursynth api version into account a tuple is now only returned from get_output in python when alpha actually exist, this undoes the python syntax change in r41 fixed a possible hang on error in vspipe, regression introduced with the alpha support in r41
31st January 2018, 11:33 | #2939 | Link |
hi I just installed (on windows) vapor R42.1 with python but no matter how I do it I always get the error:
c:\Program Files (x86)\Python36-32>VSPipe.exe --info G:\test.vpy - Failed to initialize VapourSynth environment |
31st January 2018, 11:34 | #2940 | Link | |
