Old 26th March 2011, 08:20   #1  |  Link
mocham
Soft Subtitles with HandBrakeCLI? How?
I'm trying to figure out what is the difference between HandBrake GUI and HandBrakeCLI in respect to how they encode subtitles. If I use the GUI and don't choose forced, it makes the subtitles as a track in the resulting MP4. If I use CLI, the subtitle is always burned into the MP4. How can I do soft subs with CLI? I'm using 0.9.5.
Here is an example command that I use:
HandBrakeCLI -f mp4 -e x264 --crop -r -p -q 0.62 -a 1,1 -E faac,ac3 -6 dpl2,auto -R 48,Auto -B 160,auto -D 1.5,2.5 -d slower -s 1,2,3,4,5 -x ref=2:bframes=2:subme=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 -v -i input.iso -o output.mp4
mocham is offline   Reply With Quote
Old 26th March 2011, 19:16   #2  |  Link
JohnAStebbins
It's difficult to say exactly what is going wrong without more information. The log output would be useful.
The command line you have give is invalid and doesn't even work with 0.9.5. '-r' requires and arguement. '-p' doesn't exist at all. If I remove those and use the rest of your command line on a dvd iso, it works fine for me.
JohnAStebbins is offline   Reply With Quote
Old 27th March 2011, 09:07   #3  |  Link
mocham
Well thanks for responding because it made me investigate a bit further and I discovered that I was actually using 0.9.2 from my /usr/local/bin... With the proper 0.9.5 version in use and the following command everything is working as expected.
HandBrakeCLI -f mkv -e x264 --crop --strict-anamorphic -q 20 -a 1,1 -E faac,ac3 -6 dpl2,auto -R 48,auto -B 160,auto -D 2,2 -d slower -s 1,2,3,4,5 -x ref=2:bframes=2:subme=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0 -v -i input.iso -o output.mkv
cli, handbrake, subtitles
