Old 13th December 2012, 22:53   #1  |  Link
J.Lyman
Handbrake 0.9.8 encoding unreadable files from MKVs off BD
I am using MakeMKV to extract the main video title and it's corresponding audio track (DTS-HD, TrueHD, etc, whichever is the primary full channel audio track) and creating MKV files out of my Blu Ray discs I own. Afterwards I import them into Handbrake and encode them down to a more manageable size using the following:
bitrate: 12,500
audio: 1 passthru, 2 aac 6-channel discrete 640kbps
subs: none
container: mp4
The problem I'm running into is while I can test and confirm my settings to my liking by crunching say a 20 second clip from within the movie, encoding the whole movie results in a file that can't be read and tools like MediaInfo can't display any information about it. I did five movies that came out just fine this way, but when I started a second batch (and all subsequent batches), the files were useless.
Is there something I'm missing? What would you check first?
I apologize if this has been answered before. I didn't see a thread on this already and I wasn't sure if I was using the correct keywords to search.
Thanks in advance for your help.
-J
J.Lyman is offline   Reply With Quote
Old 14th December 2012, 06:23   #2  |  Link
vid.user
Did you select the MP4 'large file size'?
vid.user is offline   Reply With Quote
blu-ray, h264, handbrake
