Old 23rd April 2020, 21:27   #1  |  Link
goldensun87
Seeking Lag - Causes And How To Avoid/Prevent It
So, this is something that confuses me. Shadowplay recordings that I make have a bitrate of 50 Mbps, but still seek fast and smoothly. But, for some reason I cannot figure out, H.264 videos I encode with MEGUI and mux into an MP4 container, have an annoying lag when I use forward or backward seeking. I know that MKV container has little to no lag, but is there any encoding and/or player settings I should tweak, to get rid of the seeking lag with MP4 container?
My CPU is AMD Ryzen 5 3600, my GPU is NVIDIA Geforce GTX 970, and I have 16GB RAM.
Smartphone repairs. PC Virus Removals. Data Recovery. Hard Drive Repairs. Gaming PC Upgrades. Custom PC Builds.
https://electronics-emended.business.site/
goldensun87 is offline   Reply With Quote
Old 24th April 2020, 06:07   #2  |  Link
Reduce --keyint value maybe?
Old 24th April 2020, 20:30   #3  |  Link
goldensun87
Where do I find that? MPC-HC or MEGUI?
Old 24th April 2020, 20:35   #4  |  Link
videoh
Useful n00b
MEGUI:
x264 config/Show Advanced Settings/Frame-Type/GOP Size
Make a smaller GOP.
Old 24th April 2020, 22:45   #5  |  Link
goldensun87
Originally Posted by videoh View Post
MEGUI:
Make a smaller GOP.
Default minimum is 25, and default maximum is 250. What would be optimum lower settings?
Old 24th April 2020, 23:28   #6  |  Link
videoh
Useful n00b
I would go for minimum and maximum 25 and closed GOPs. Sure, it will be a bigger file but with multiterabyte drives these days...
I'm sure others will chime in to tell me I'm wrong.
Anyway, it's just a hypothesis right now that the problem is GOP size. Try the above and see if it affects things. If not, we can look at other possibilities.
Old 24th April 2020, 23:58   #7  |  Link
goldensun87
Yes, reducing the GOP values improved the seeking performance. First time I tried 13 and 130, but there was still a little lag, so now I am trying 6 and 60.
Thank you for the suggestion .
Old 25th April 2020, 00:06   #8  |  Link
videoh
Useful n00b
You're welcome but it may not be the only issue. And Atak_Snajpera suggested it first.
Old 25th April 2020, 00:22   #9  |  Link
goldensun87
He did, but I needed to know how to change the settings in the UI. That command will be useful if I have to use ffmpeg for anything though.
Edit: I have settled on the values 3 and 30.
Old 25th April 2020, 14:26   #10  |  Link
hubblec4
Matroska find' ich toll
For 20 years as I encoded video's, I used 2-5. The reason was not for seeking, but it is a good side effect.
And the files were not much bigger than anybody could think.
Old 25th April 2020, 15:24   #11  |  Link
Keep in mind that very low value may introduce that annoying frame pulsing effect (key-frame injection) in static scenes. Besides 2-5 range looks ridiculously low! You are basically injecting key-frame every 5 frames. Even blu-ray movies use larger value (24=1s)
Old 26th April 2020, 23:30   #12  |  Link
goldensun87
Videos which I had encoded without setting the keyint, they have a minimum of 60 GOP and maximum of 600 GOP. Makes me want to replay and re-record some of my video game playthroughs. Also, since I do not use keyframe seeking, the smaller GOP does not affect me at all, right?
Old 27th April 2020, 02:17   #13  |  Link
videoh
Useful n00b
All seeks have to begin decoding at a key frame, so not sure what you're saying there in your last sentence.
Old 3rd May 2020, 01:49   #14  |  Link
goldensun87
I was talking about MPC-HC's different seeking speeds. It has small, medium, and large jumps, all of which can be adjusted, and it has keyframe jumps. MPC-HC's default settings has a keybind for the keyframe seeks (Shift+Arrow I think). I disable those two keybinds, and only use the small, medium, and large jumps. So, does changing the GOP values also change the length of the keyframe seeks?
megui, mpc-hc, vlc
