Old 17th May 2007, 00:58   #1  |  Link
Pelican9
Coder
Pelican9's Avatar
BDedit - BD structure edit
A tool to view and edit a BDMV structure.
Download the latest version
You can find all information on the 'official' website: Bdedit.pel.hu
Change log: BDedit.txt
Original post:
I've just started to develop a little tool to edit BD files (index.bdmv, *.clpi, *.mpls).
If you change the streams, you have to edit these files to fit in with them.
Pelican9 is offline   Reply With Quote
Old 17th May 2007, 01:24   #2  |  Link
guada2
Good job. Pelican9
index.bdmv ; MovieObject.bdmv ; PLAYLIST ; CLIPINF :OK
But is it necessary to have "AUXDATA" and "BACKUP" ?
Perhaps that i 've have forget them.
guada2 is offline   Reply With Quote
Old 17th May 2007, 09:02   #3  |  Link
Pelican9
Coder
Pelican9's Avatar
Originally Posted by guada2 View Post
Good job. Pelican9
I think the mandatory folders are: PLAYLIST, CLIPINF, STREAM, AUXDATA, META, BDJO, JAR, BACKUP (with subfolders PLAYLIST, CLIPINF, BDJO, JAR).
Is that correct?
Old 17th May 2007, 21:43   #4  |  Link
b_squared
Great job!!!
How hard would it be for this tool to actually generate a basic BD structure from nothing, just source files? I'm hoping to be able to combine this and the TsRemux tool being developed to get some basic Blu-ray authoring started.
b_squared is offline   Reply With Quote
Old 17th May 2007, 23:26   #5  |  Link
Pelican9
Coder
Pelican9's Avatar
Originally Posted by b_squared View Post
Great job!!!
TsRemux is the tool you want. :-)
BDedit v0.11 is available
Old 18th May 2007, 00:08   #6  |  Link
b_squared
Sure, but TsRemux will only give me the m2ts file. What if I want to create a Blu-ray disc of TS's I recorded from an OTA HDTV channel?
My goal is to make a Blu-ray of my recorded Lost episodes on a DVD9 disc that will play on my PS3.
Old 18th May 2007, 00:35   #7  |  Link
dmz01
Who says TsRemux won't do that for you in the not so distant future...
dmz01 is offline   Reply With Quote
Old 18th May 2007, 01:15   #8  |  Link
Pelican9
Coder
Pelican9's Avatar
As I said...
Old 18th May 2007, 11:40   #9  |  Link
Fahzuu
Download: BDedit v0.1
Hi Pelican!
Nice work, I like it.
Do you have any description of the fields, as some of them are not really self-explanatory?
What's "IN time/OUT time"?
Or "user op."?
Fahzuu is offline   Reply With Quote
Old 18th May 2007, 14:38   #10  |  Link
Pelican9
Coder
Pelican9's Avatar
I'll make a guide for it, but not now.
I want to make a working version first.
Anyway:
IN/OUT time: start/end time of the item.
user op.: User Operation (skip, fast forward, etc.)
Old 18th May 2007, 17:05   #11  |  Link
jagaskywalker
Would it be possible to add AVCHD support ? As far as I know the structure is very similar to BR (or maybe even equal, being a "subset" of the directories and files)
Thank you.
jagaskywalker is offline   Reply With Quote
Old 22nd May 2007, 23:39   #12  |  Link
Pelican9
Coder
Pelican9's Avatar
If you want to help, please try the 0.12b4 version which can modify the index.bdmv.
It has strange behaviour, the movie with the modified index.bdmv sometimes work sometimes doesn't work.
jaga...: Maybe later.
Edit:
Hmmm, It seems nobody wants to edit existing BD titles...
Doesn't matter, I will.
Old 23rd May 2007, 18:25   #13  |  Link
jagaskywalker
Would it be possible to update the tool to create the file/directory structure using as input some m2ts files ? (i.e. in addition to editing pre-existing structures)
Nothing funcy, just to be able to play the files (no menus or complex things)
THX
Old 23rd May 2007, 19:25   #14  |  Link
Pelican9
Coder
Pelican9's Avatar
THX
TsRemux is your app.
Old 24th May 2007, 06:00   #15  |  Link
bob0r
Pain and suffering
bob0r's Avatar
I will ask then:
How can i make any BLURAY play MOVIE only?
I have some problems understanding this program...
bob0r is offline   Reply With Quote
Old 24th May 2007, 08:06   #16  |  Link
borkaenjo
Great work Pelican.
Is it also possible to rename streams with this tool.
In example when you ad a subtitle stream or replace one.
Or when you delete or ad audio and subtitle streams?
And when are you starting to work on a program to edit
the menus of BD?
borkaenjo is offline   Reply With Quote
Old 24th May 2007, 10:38   #17  |  Link
Pelican9
Coder
Pelican9's Avatar
bob0r:
Don't give up, this program hasn't finished yet. I've just started to develop. You will be able to remove the unnecessary things.
borkaenjo:
I'm making this tool because I want to insert a new subtitle (and remove the unwanted streams) to/from an existing BD.
Old 24th May 2007, 12:19   #18  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Ah ok, its not possible yet, so what can this great program do now?
Edit to below:
Roger that.
Old 24th May 2007, 12:32   #19  |  Link
Pelican9
Coder
Pelican9's Avatar
Almost nothing.
You can read and edit the whole index.bdmv (to do: add and remove titles)
You can read and edit (partially) the MovieObject.bdmv (to do: show/edit the nav commands).
You can read the playlists and the clips (to do: edit).
Old 10th June 2007, 21:07   #20  |  Link
PHD_1976
BD chapters information
Pelican9,
Great job again, thanx a lot for this one!!!
May be by any chance you know how to get chapter information, i mean timing for each chapter from Blu-ray disc?
Maybe I've missed something studying your new tool.
Thanx in advance!
PHD_1976 is offline   Reply With Quote
bd menu, bdedit, blu-ray
