19th September 2021, 18:45 | #30902 | Link |
Here's the mediainfo of the video section of Gemini Man' biggest m2ts
Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Code:
Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 |
19th September 2021, 19:02 | #30903 | Link |
Life's clearer in 4K UHD
My backed-up copy of Gemini Man looks like this: -
General ID : 1 (0x1) Complete name : \\SYNOLOGY_NAS\My HD Movies\UHD Movies\Gemini Man [2019] 117mins [59.940fps]\AVCHD\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 77.3 GiB Duration : 1 h 57 min Overall bit rate mode : Variable Overall bit rate : 94.5 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video #1 ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 5180 cd/m2 Maximum Frame-Average Light Level : 1577 cd/m2 Video #2 ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 1 h 57 min Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : MLP FBA AC-3 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Format settings : Dolby Surround EX Muxing mode : Stream extension Codec ID : 131 Duration : 1 h 57 min Bit rate mode : Variable Bit rate : 640 kb/s Maximum bit rate : 7 944 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossless Stream size : 536 MiB (1%) Service kind : Complete Main Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 1 h 57 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -8 ms Stream size : 536 MiB (1%) Service kind : Complete Main Text #1 ID : 4768 (0x12A0) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #2 ID : 4769 (0x12A1) Menu ID : 1 (0x1) Format : PGS Codec ID : 144
20th September 2021, 22:18 | #30905 | Link |
Was it something that had to be imported? I'd have to check, but I don't think importing would support a 59.94fps 1080p or 2160p source.
Also, while 59.94fps may be supported as a coincidence of the long-existing support for 59.94fps/720p (and probably the same for 50fps), I'm sure 60fps wouldn't be -- because it was never a part of the original BD standard. |
24th September 2021, 16:27 | #30907 | Link |
I just finished an import (imported just the main m2ts from Gemini Man) and that also worked fine. Didn't try it in the player yet, but at least BDRB did not complain.
As mentioned, 59.94 fps is working, even if by coincidence. The 60fps from the demo disc on the other hand seem to break things |
30th September 2021, 15:48 | #30908 | Link |
BD Rebuilder v0.61.25
I have updated the first post of this thread with a link to the most recent version (v0.61.25) of BD Rebuilder. Changes for this release:
- Added a hidden option IMPORT_LIMIT_LANG that ignores import of audio/video tracks that aren't in your selected list (SETUP). This can significantly speed up import when a large number of audio/subtitle tracks exist. - Fixed an issue that could result in slight aspect ratio issues when padding a 1080p image and then converting to 720p via the SETUP option. - Fixed an error that could cause timed text subtitles (in MP4 files) to not be kept as SRT during import. - Added two new hidden options for control of Menus. MENU_PREVNEXT_X sets the screen X position of Prev/Next. MENU_PREVNEXT_Y sets the screen Y position of Prev/Next. See HIDDENOPTS.TXT for more info. - Added new hidden option MENU_PAGE_ENABLE, if set to 0, menu page number text will not be displayed on Quick-Play menus. - Modified the VFR detection algorithm during import to prevent unnecessary reencode. - Modified the method for reencoding E-AC3 files that are imported. Some systems and sources had randomly experienced channel count discrepancies in the old method. - Corrected code to adjust padding sizing (when present) to accommodate resizing an imported source when using NVENCC. - Added code to recognize forced subtitles during video file import, and set those subtitles to enabled (by default) in the pseudo-BD structure. - Updated MKVMERGE.EXE and MKVEXTRACT.EXE with newest version (v60.0.0). Fixes rare error associated with importing SRT files. - Updated NVENCC.EXE to newer version 5.35. - Other minor corrections and cosmetic fixes. |
1st October 2021, 00:37 | #30909 | Link | |
3rd October 2021, 08:18 | #30914 | Link |
hello, bdrebuilder use more CPU or ram?
Bdrebuilder use CPU single core or more core? the CPU better high frequency single core or lower but more cores? For upgrade pc Last edited by gamete; 3rd October 2021 at 08:47. |
3rd October 2021, 11:11 | #30915 | Link |
Big Bit Savings Now !
Encoders inside are x264, x265, NVEnc, BDRebuilder controls these.
For processor/encoder comparisons you may want to look up cinebench etc. What CPU/GPU you give to them follows your personal speed/price ratio. More CPU or RAM ?...you need both. 16GB RAM should be ok. Single core CPU: Are there any left in that range at all ? 6c12t would be a good starting point. My results with Intel CPUs, all on notebooks (I had no AMD so far): 2004: T7600G (2c2t 2,33..3,16Ghz) x264 first steps ok, slow but pristine 2009: i7-940XM (4c8t 2,13GHz..3GHz) x264 working medium speed possible, x265 just for short tests 2014: i7-4960X (6c12t 1,2..3,7..4,1GHz) x264 with beautiful speed, x265 working medium speed well possible. BTW, I do not suggest my personal approach to have all that squeezed into a notebook, it will cost you a premium, and proper cooling asks for a thick desktop replacement. All those CPUs are obsolete now, almost any recent CPU is faster (Ultra-low-Power CPUs excluded) Multicore/ highclock CPUs are welcome, but I wouldn't suggest spending top money for THE top clock, one below is still sufficient. Expect Clock to be throttled down with many full-load threads, TDP demands it. Expect to give the best cooling system and the best PSU. You need a CPU with AVX, better AVX2. AVX512 would be H.265-valuable, but often outside of a private budget (Server CPUs). Expect thermal throttling to be kicking in on AVX512 load with early generation AVX512 CPUs, so no real gain to spend on that feature. GPUs (1060 upwards with B-frames): quality seems to lack a bit behind CPU, but are reported to be blazingly fast. All these factors come with new chipsets and motherboards, so after all encoding speeds are rarely improved by upgrade of an existing system, but by purchase of a new system.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 3rd October 2021 at 12:17. |
3rd October 2021, 18:10 | #30917 | Link |
For example this pc 1 year life is good for 400€ for bdrebuilder?
Vga integrated in cpu 3400 Case BE QUIET! CASE ATX PURE BASE 600, Black-Silver. - venditore italiano fatt. 06/12/2020 * Scheda Madre Aorus B450 AORUS ELITE (presa AM4 / B450 / DDR4 / S-ATA 600 / ATX) - Amazon.it - 06/12/2020 * Cpu Ryzen 5 3400g 4x 3.7ghz Turbo (4,2ghz) so am4 65 Watt - ebay powerseller nuovo 02/12/2020 * MEMORIA RAM G.SKILL AEGIS KIT16GB 2X8GB DDR4 3200MHz CL16 F4-3200C16D-16GIS - powerseller ebay nuovo 07/12/2020 * SSD NVME Crucial P5 500 GB CT500P5SSD8 SSD Interno-Fino a 3400 MB/s, 3D NAND, NVMe, PCIe, M.2, 2280SS * Alimentatore di rete be quiet! System Power 9 400 W modulare 80+ Bronzo - Amazon.it 12/01/2021 * Dissipatore Be Quiet! BK022 Dark Rock Pro 4 - Ventola per CPU, 250 W, Nero - Amazon.it 16/05/2020 Last edited by gamete; 3rd October 2021 at 18:13. |
3rd October 2021, 20:45 | #30918 | Link |
Although I am not going through the specs now, and give no guarantee on a ebay puchase, this should be good to go.
6th October 2021, 12:40 | #30920 | Link |
Well, you are talking about a used PC with a middleclass Ryzen 5 and a 400W PSU
It may work for you, but I would not shell out 400€ for that, this config is 500.-€ new. Put 80% weight on CPU, its supply (PSU) and waste disposal (cooler). As a ballpark figure I had invested tenfold most of the time for top notch *and portable* en.coding, but that is just me. You might maybe give myself a budget lift to 800, go for a 800W PSU and study CPU encoding comparisons well laid out, you may search. As an example, just one of many: https://www.tomshardware.com/news/am...eon-comparison and we are getting OT here, this belongs to Hardware discussions...
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 6th October 2021 at 12:45. |
