7th August 2010, 21:10 | #441 | Link |
Thanks for your hard work on this!
I checked 'use untouched audio' under settings - audio settings, but in the logs I found: Code:
[8/7/2010 3:04:15 PM] 3: AC3, English, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB [8/7/2010 3:04:15 PM] Creating file "D:\TEMP\bluerip\_001_chapter.txt"... [8/7/2010 3:04:15 PM] a03 Extracting audio track number 3... [8/7/2010 3:04:15 PM] a03 Removing AC3 dialog normalization... [8/7/2010 3:04:15 PM] v02 Extracting video track number 2... [8/7/2010 3:04:15 PM] v02 Muxing video to Matroska... [8/7/2010 3:04:16 PM] a03 Creating file "D:\TEMP\bluerip\_003_audio_ac3_English.ac3"... Also, would you consider adding horizontal & vertical scroll bars to the manual crop window? It would be nice if the manual crop window displayed the recommend values from autocrop as well as the final resolution resulting from any manual changes made. When I put in 1280 x 720 for resize & check the resize box, I would expect the preview window to update, but it doesn't seem too change the resolution at all? Last edited by levi; 7th August 2010 at 22:01. |
8th August 2010, 03:02 | #442 | Link |
Just downloaded the latest and I'm getting the following error:
To run this application, you first must install one of the following versiond of the .NET Framework: v4.0.30319 Contact your application publisher for instructions about obtaining the appropriate version of the .NET Framework. I already have that exact version installed. I even tried to reinstall it. |
8th August 2010, 21:59 | #443 | Link |
Is there any manual or help file that describes what different video encoding profiles mean ?
Just tried converting my first video. According to logs, everything went fine but I did not get an output file. I see all the individual files in temp folders but there is nothing in the output directory (log is attached). Last edited by ajamils; 9th August 2010 at 02:32. |
9th August 2010, 08:10 | #444 | Link | ||
BluRip author
"Dialog Norm. is applied during playing back of the audio track. That is done by the decoder. Info about how much attenuation to be applied is stored into the track. When we wanna make a new audio track, we want to keep audio data untouched. This means we don't want Dialog Norm. to be applied during decoding." So I think this message is ok. The track is not reencoded. Quote:
I'll think about adding a preview for the final video size.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter http://code.google.com/p/blurip/ |
9th August 2010, 08:12 | #445 | Link | |
BluRip author
9th August 2010, 08:13 | #446 | Link | |
BluRip author
10th August 2010, 12:14 | #447 | Link |
Wow! This cool tool is so close to perfect it's not funny!
Just a quick question, is there anyway to "hardcode" forced/normal subtitles with BluRip? It works awesomely with softcoded forced subs, would be great if there was a way to do the same with hardcoded! Also just wondering if a better status bar was in the works? It's a bit disheartening not knowing when the job will be complete (aka hours or days!) ... 7ek Last edited by 7ekno; 10th August 2010 at 12:26. |
10th August 2010, 12:41 | #448 | Link |
BluRip author
I will add an option to hardcode subs (think it was done with vobsub/vsfilter?)
A good progress bar will be some more complicated.. It is possible to get a percent value for the encode and the mux step. I could use this and show the x264 eta.
10th August 2010, 20:48 | #449 | Link | |
Hi all,
This is my first post, I joined the forums to say thankyou _hawk_ for such an awesome program. It turns out i need some help now too........... I have successfully used BluRip to rip 2 Blurays on my 32bit machine. Rip and encode took 12 hours approx - is this normal? I've now moved onto my 64bit HTPC with gt240 so i can take advantage of DCdecNV. I have the same problem as below: Quote:
I will PM you the logs when i can _hawk_ if that's ok? Thanks again hawk Thanks in advance for any help Kind regards P |
10th August 2010, 21:28 | #450 | Link | |||
BluRip author
On my system (~3ghz quadcore) I get something about 10fps for 1080p encodes.. Quote:
If you used the advanced audio options and get an error like "can't mux empty filename" from mkvmerge - this is fixed in svn rev 115 (I uploaded this one today) Just copy over your settings.xml open the demuxedStreamlist.xml and hit "Only mux".
16th August 2010, 08:20 | #451 | Link |
BluRip author
v0.5.1 (2010/08/16)
- Some minor GUI fixes (don't reset position on language change etc) - Option to disable mkvmerge header compression (for audio + video tracks) - Resize method selection - Edit functions for demuxed stream list - Option to edit AutoCrop values (crop, addborders, resize) by hand - Lots of minor bugfixes - Show expected size/bitrate in mainwindow when 2-pass profile selected - Compatible with latest DGDecNV
17th August 2010, 21:31 | #453 | Link |
It's not detecting the video in the mkv it creates? MKV opens fine manually using DGIndexNV 2024.
M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 1:41:10, 24p /1.001 [8/17/2010 3:14:04 PM] 1: Chapters, 16 chapters [8/17/2010 3:14:04 PM] 2: h264/AVC, 1080p24 /1.001 (16:9) [8/17/2010 3:14:04 PM] 3: AC3, Spanish, 2.0 channels, 192kbps, 48kHz [8/17/2010 3:14:04 PM] 4: AC3, Spanish, 2.0 channels, 192kbps, 48kHz [8/17/2010 3:14:04 PM] 5: Subtitle (PGS), English [8/17/2010 3:14:04 PM] Creating file "D:\TEMP\bluerip\_001_chapter.txt"... [8/17/2010 3:14:04 PM] s05 Extracting subtitle track number 5... [8/17/2010 3:14:04 PM] v02 Extracting video track number 2... [8/17/2010 3:14:04 PM] a03 Extracting audio track number 3... [8/17/2010 3:14:04 PM] v02 Muxing video to Matroska... [8/17/2010 3:14:08 PM] -a03 Creating file "D:\TEMP\bluerip\_003_audio_ac3_Spanish.ac3"... [8/17/2010 3:14:25 PM] -----s05 Creating file "D:\TEMP\bluerip\_005_subtitle_English.sup"... [8/17/2010 3:18:11 PM] ------------------------------------------------------------------------------- Added fps value (24 /1.001) to MKV header. [8/17/2010 3:18:11 PM] Video track 2 contains 145530 frames. [8/17/2010 3:18:11 PM] Subtitle track 5 contains 888 captions. [8/17/2010 3:18:11 PM] eac3to processing took 4 minutes, 7 seconds. [8/17/2010 3:18:11 PM] Done. [8/17/2010 3:18:13 PM] [8/17/2010 3:18:13 PM] [8/17/2010 3:18:13 PM] Return code: 0 [8/17/2010 3:18:13 PM] Done. [8/17/2010 3:18:16 PM] General [8/17/2010 3:18:16 PM] Count : 267 [8/17/2010 3:18:16 PM] Count of stream of this kind : 1 [8/17/2010 3:18:16 PM] Kind of stream : General [8/17/2010 3:18:16 PM] Kind of stream : General [8/17/2010 3:18:16 PM] Stream identifier : 0 [8/17/2010 3:18:16 PM] Count of video streams : 1 [8/17/2010 3:18:16 PM] Video_Format_List : AVC [8/17/2010 3:18:16 PM] Video_Format_WithHint_List : AVC [8/17/2010 3:18:16 PM] Codecs Video : AVC [8/17/2010 3:18:16 PM] Complete name : D:\TEMP\bluerip\_002_video.mkv [8/17/2010 3:18:16 PM] Folder name : D:\TEMP\bluerip [8/17/2010 3:18:16 PM] File name : _002_video [8/17/2010 3:18:16 PM] File extension : mkv [8/17/2010 3:18:16 PM] Format : Matroska [8/17/2010 3:18:16 PM] Format : Matroska [8/17/2010 3:18:16 PM] Format/Url : http://packs.matroska.org/ [8/17/2010 3:18:16 PM] Format/Extensions usually used : mkv mka mks [8/17/2010 3:18:16 PM] Format_Commercial : Matroska [8/17/2010 3:18:16 PM] Codec : Matroska [8/17/2010 3:18:16 PM] Codec : Matroska [8/17/2010 3:18:16 PM] Codec/Url : http://packs.matroska.org/ [8/17/2010 3:18:16 PM] Codec/Extensions usually used : mkv mka mks [8/17/2010 3:18:16 PM] File size : 11226996299 [8/17/2010 3:18:16 PM] File size : 10.5 GiB [8/17/2010 3:18:16 PM] File size : 10 GiB [8/17/2010 3:18:16 PM] File size : 10 GiB [8/17/2010 3:18:16 PM] File size : 10.5 GiB [8/17/2010 3:18:16 PM] File size : 10.46 GiB [8/17/2010 3:18:16 PM] Duration : 6069814 [8/17/2010 3:18:16 PM] Duration : 1h 41mn [8/17/2010 3:18:16 PM] Duration : 1h 41mn 9s 814ms [8/17/2010 3:18:16 PM] Duration : 1h 41mn [8/17/2010 3:18:16 PM] Duration : 01:41:09.814 [8/17/2010 3:18:16 PM] Overall bit rate : 14797153 [8/17/2010 3:18:16 PM] Overall bit rate : 14.8 Mbps [8/17/2010 3:18:16 PM] Stream size : 223406834 [8/17/2010 3:18:16 PM] Stream size : 213 MiB (2%) [8/17/2010 3:18:16 PM] Stream size : 213 MiB [8/17/2010 3:18:16 PM] Stream size : 213 MiB [8/17/2010 3:18:16 PM] Stream size : 213 MiB [8/17/2010 3:18:16 PM] Stream size : 213.1 MiB [8/17/2010 3:18:16 PM] Stream size : 213 MiB (2%) [8/17/2010 3:18:16 PM] Proportion of this stream : 0.01990 [8/17/2010 3:18:16 PM] Encoded date : UTC 2010-08-17 20:14:06 [8/17/2010 3:18:16 PM] File creation date : UTC 2010-08-07 20:02:38.879 [8/17/2010 3:18:16 PM] File creation date (local) : 2010-08-07 15:02:38.879 [8/17/2010 3:18:16 PM] File last modification date : UTC 2010-08-17 20:18:11.817 [8/17/2010 3:18:16 PM] File last modification date (loc : 2010-08-17 15:18:11.817 [8/17/2010 3:18:16 PM] Writing application : eac3to [8/17/2010 3:18:16 PM] Writing library : Haali DirectShow Matroska Muxer 1.9.355.21 [8/17/2010 3:18:16 PM] Writing library : Haali DirectShow Matroska Muxer 1.9.355.21 [8/17/2010 3:18:16 PM] [8/17/2010 3:18:16 PM] Video [8/17/2010 3:18:16 PM] Count : 180 [8/17/2010 3:18:16 PM] Count of stream of this kind : 1 [8/17/2010 3:18:16 PM] Kind of stream : Video [8/17/2010 3:18:16 PM] Kind of stream : Video [8/17/2010 3:18:16 PM] Stream identifier : 0 [8/17/2010 3:18:16 PM] ID : 1 [8/17/2010 3:18:16 PM] ID : 1 [8/17/2010 3:18:17 PM] UniqueID : 1 [8/17/2010 3:18:17 PM] Format : AVC [8/17/2010 3:18:17 PM] Format/Info : Advanced Video Codec [8/17/2010 3:18:17 PM] Format/Url : http://developers.videolan.org/x264.html [8/17/2010 3:18:17 PM] Format_Commercial : AVC [8/17/2010 3:18:17 PM] Format profile : High@L4.1 [8/17/2010 3:18:17 PM] Format settings : CABAC / 4 Ref Frames [8/17/2010 3:18:17 PM] Format settings, CABAC : Yes [8/17/2010 3:18:17 PM] Format settings, CABAC : Yes [8/17/2010 3:18:17 PM] Format settings, ReFrames : 4 [8/17/2010 3:18:17 PM] Format settings, ReFrames : 4 frames [8/17/2010 3:18:17 PM] InternetMediaType : video/H264 [8/17/2010 3:18:17 PM] Muxing mode : Container profile=Unknown@0.0 [8/17/2010 3:18:17 PM] Codec ID : V_MPEG4/ISO/AVC [8/17/2010 3:18:17 PM] Codec ID/Url : http://ffdshow-tryout.sourceforge.net/ [8/17/2010 3:18:17 PM] Codec : V_MPEG4/ISO/AVC [8/17/2010 3:18:17 PM] Codec : AVC [8/17/2010 3:18:17 PM] Codec/Family : AVC [8/17/2010 3:18:17 PM] Codec/Info : Advanced Video Codec [8/17/2010 3:18:17 PM] Codec/Url : http://ffdshow-tryout.sourceforge.net/ [8/17/2010 3:18:17 PM] Codec profile : High@L4.1 [8/17/2010 3:18:17 PM] Codec settings : CABAC / 4 Ref Frames [8/17/2010 3:18:17 PM] Codec settings, CABAC : Yes [8/17/2010 3:18:17 PM] Codec_Settings_RefFrames : 4 [8/17/2010 3:18:17 PM] Duration : 6069820 [8/17/2010 3:18:17 PM] Duration : 1h 41mn [8/17/2010 3:18:17 PM] Duration : 1h 41mn 9s 820ms [8/17/2010 3:18:17 PM] Duration : 1h 41mn [8/17/2010 3:18:17 PM] Duration : 01:41:09.820 [8/17/2010 3:18:17 PM] Bit rate : 14502690 [8/17/2010 3:18:17 PM] Bit rate : 14.5 Mbps [8/17/2010 3:18:17 PM] Width : 1920 [8/17/2010 3:18:17 PM] Width : 1 920 pixels [8/17/2010 3:18:17 PM] Height : 1080 [8/17/2010 3:18:17 PM] Height : 1 080 pixels [8/17/2010 3:18:17 PM] Pixel aspect ratio : 1.000 [8/17/2010 3:18:17 PM] Display aspect ratio : 1.778 [8/17/2010 3:18:17 PM] Display aspect ratio : 16:9 [8/17/2010 3:18:17 PM] Frame rate : 23.976 [8/17/2010 3:18:17 PM] Frame rate : 23.976 fps [8/17/2010 3:18:17 PM] Frame count : 145530 [8/17/2010 3:18:17 PM] Standard : NTSC [8/17/2010 3:18:17 PM] Resolution : 8 [8/17/2010 3:18:17 PM] Resolution : 8 bits [8/17/2010 3:18:17 PM] Colorimetry : 4:2:0 [8/17/2010 3:18:17 PM] Color space : YUV [8/17/2010 3:18:17 PM] Chroma subsampling : 4:2:0 [8/17/2010 3:18:17 PM] Bit depth : 8 [8/17/2010 3:18:17 PM] Bit depth : 8 bits [8/17/2010 3:18:17 PM] Scan type : Progressive [8/17/2010 3:18:17 PM] Scan type : Progressive [8/17/2010 3:18:17 PM] Interlacement : PPF [8/17/2010 3:18:17 PM] Interlacement : Progressive [8/17/2010 3:18:17 PM] Bits/(Pixel*Frame) : 0.292 [8/17/2010 3:18:17 PM] Delay : 0 [8/17/2010 3:18:17 PM] Delay : 00:00:00.000 [8/17/2010 3:18:17 PM] Stream size : 11003589465 [8/17/2010 3:18:17 PM] Stream size : 10.2 GiB (98%) [8/17/2010 3:18:17 PM] Stream size : 10 GiB [8/17/2010 3:18:17 PM] Stream size : 10 GiB [8/17/2010 3:18:17 PM] Stream size : 10.2 GiB [8/17/2010 3:18:17 PM] Stream size : 10.25 GiB [8/17/2010 3:18:17 PM] Stream size : 10.2 GiB (98%) [8/17/2010 3:18:17 PM] Proportion of this stream : 0.98010 [8/17/2010 3:18:17 PM] Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 [8/17/2010 3:18:17 PM] Transfer characteristics : BT.709-5, BT.1361 [8/17/2010 3:18:17 PM] Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 [8/17/2010 3:18:17 PM] [8/17/2010 3:18:17 PM] Starting AutoCrop... [8/17/2010 3:18:21 PM] Exception: DGMultiSource: Could not find a video track in the Matroska file. (D:\TEMP\bluerip\_cropTemp.avs, line 2) The avs wont open in vdub either - same error - "Could not find a video track" Code:
LoadPlugin("C:\dgavcdecNV\DGDecodeNV.dll") DGSource("D:\TEMP\bluerip\_002_video.dgi") Last edited by levi; 17th August 2010 at 22:10. |
19th August 2010, 12:22 | #454 | Link |
@ _hawk_
I was planning on doing a writeup on BluRip, but had a few questions/issues: 1 - I was trying to create an mkv from a BluRay disc (District 9). I have kept the Video and Audio settings at untouched. When I click start I see in the status bar the demuxing starts but then the whole process just stops. This is what the log shows Code:
[8/19/2010 6:54:19 AM] Command: C:\Program Files\eac3to\eac3to.exe "F:\" 1) 1: "C:\Users\DAMIAN\Documents\BluRip\WTF_001_chapter.txt" 2: "C:\Users\DAMIAN\Documents\BluRip\WTF_002_video.mkv" 3: "C:\Users\DAMIAN\Documents\BluRip\WTF_003_audio_custom_English" 7: "C:\Users\DAMIAN\Documents\BluRip\WTF_007_subtitle_English.sup" 8: "C:\Users\DAMIAN\Documents\BluRip\WTF_008_subtitle_English.sup" 9: "C:\Users\DAMIAN\Documents\BluRip\WTF_009_subtitle_English.sup" 10: "C:\Users\DAMIAN\Documents\BluRip\WTF_010_subtitle_English.sup" 18: "C:\Users\DAMIAN\Documents\BluRip\WTF_018_subtitle_English.sup" [8/19/2010 6:54:39 AM] ------------------------------------------------------------------------------- M2TS, 1 video track, 4 audio tracks, 14 subtitle tracks, 1:52:16, 24p /1.001 [8/19/2010 6:54:39 AM] 1: Chapters, 16 chapters [8/19/2010 6:54:39 AM] 2: h264/AVC, 1080p24 /1.001 (16:9) [8/19/2010 6:54:39 AM] 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz [8/19/2010 6:54:39 AM] (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) [8/19/2010 6:54:40 AM] 4: AC3, English, 5.1 channels, 448kbps, 48kHz [8/19/2010 6:54:40 AM] 5: DTS Master Audio, French, 5.1 channels, 24 bits, 48kHz [8/19/2010 6:54:40 AM] (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) [8/19/2010 6:54:40 AM] 6: AC3 Surround, English, 2.0 channels, 192kbps, 48kHz [8/19/2010 6:54:40 AM] 7: Subtitle (PGS), English [8/19/2010 6:54:40 AM] 8: Subtitle (PGS), English [8/19/2010 6:54:40 AM] 9: Subtitle (PGS), English [8/19/2010 6:54:40 AM] 10: Subtitle (PGS), English [8/19/2010 6:54:40 AM] 11: Subtitle (PGS), French [8/19/2010 6:54:40 AM] 12: Subtitle (PGS), Hindi [8/19/2010 6:54:40 AM] 13: Subtitle (PGS), Korean [8/19/2010 6:54:40 AM] 14: Subtitle (PGS), Estonian [8/19/2010 6:54:40 AM] 15: Subtitle (PGS), Lithuanian [8/19/2010 6:54:40 AM] 16: Subtitle (PGS), Russian [8/19/2010 6:54:40 AM] 17: Subtitle (PGS), Ukrainian [8/19/2010 6:54:40 AM] 18: Subtitle (PGS), English [8/19/2010 6:54:40 AM] 19: Subtitle (PGS), Spanish [8/19/2010 6:54:40 AM] 20: Subtitle (PGS), Portuguese [8/19/2010 6:54:40 AM] [8/19/2010 6:54:41 AM] [8/19/2010 6:54:41 AM] [8/19/2010 6:54:41 AM] Return code: 1 [8/19/2010 6:54:41 AM] Done. 3 - For the encoding profiles you have set up, what does aq-mode 0 do? 4 - there is a checkbox to mux untouched PGS subtitles. How is this different then just selecting "Mux all subtitles (pgs)"
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
19th August 2010, 12:49 | #455 | Link | |
19th August 2010, 14:41 | #456 | Link | |
BluRip author
Try to execute the eac3to command on a shell. Maybe there is a problem with the haali splitter. 2) If you use untouched video autocrop isn't used at all. Theoretically all input methods should give the same result. On win 7 you will need some manual tweaking to use vc-1 with directshow (Windows 7 filter tweaker). If you have a DGDecNV license this should be the prefered input method. 3) aq-mode Adaptive Quantization Mode Default: 1 Without AQ, x264 tends to underallocate bits to less-detailed sections. AQ is used to better distribute the available bits between all macroblocks in the video. This setting changes what scope AQ re-arranges bits in: * 0: Do not use AQ at all. * 1: Allow AQ to redistribute bits across the whole video and within frames. * 2: Auto-variance AQ (experimental) which attempts to adapt strength per-frame. See also: --aq-strength Should be set to 0 for animation movies 4) If you choose mux pgs (not untouched) the subs are splitted into 2 streams if a subtitle streams contains both normal and forced subs.
19th August 2010, 14:43 | #457 | Link |
BluRip author
autocrop.dll is an own (C++) dll. If it can't open a video with directshow (e.g. vc-1 on win7 without tweaking) it will also fail for the encode. The autocrop dll just uses an avisynth wrapper to display the video picture.
19th August 2010, 14:46 | #458 | Link | |
BluRip author
19th August 2010, 20:37 | #459 | Link | |
19th August 2010, 21:00 | #460 | Link |
BluRip author
If you want the DTS-MA and an AC3 track you have to enter '.dtshd' in the Audio extension field and just check the 'Add additional AC3 track' checkbox.
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264 |
