7th February 2011, 11:20 | #621 | Link | |
I don't think it's new. Though some people thought only video/audio header compression needed to be disabled. I doesn't seems so. I don't have a hardware player myself (using a HTPC). I just read about this so I'd though I'd suggest it.
8th February 2011, 12:37 | #622 | Link | |
For those that can't be bothered reading the gist is "all MKV readers support subtitle header compression, or they don't support subtitles at all" :P 7ek |
20th February 2011, 19:29 | #623 | Link |
First off this is a great tool and have been using it quite a bit for the past few months now.
I'm not sure if this has been reported yet but I noticed a bug with the interface. If you leave the About window open (Help > About) while the program is demuxing, it doesn't start muxing after demuxing finishes until you close the About window. I was wondering why it was still demuxing when I woke up this morning but it continued as soon as I closed the About window. I'm not too sure if other windows/menus will do the same thing but this is just a minor snag. In any case, keep up the great work.! |
22nd February 2011, 04:06 | #624 | Link |
Is possible for Subtitles Advanced settings to write some info like "Director Comments" ? Or make a check box named "Director Comments".
Also for audio will be nice. On some Blu-Ray are 2 subtitles streams for every language and if we have some information about the size of stream (or bitrate like in BD Info) we can know which is the forced stream and finally select only the desired track: Code:
Presentation Graphics Italian Presentation Graphics Italian Presentation Graphics Spanish Presentation Graphics Spanish Presentation Graphics Russian Presentation Graphics Russian Mtz |
22nd February 2011, 10:44 | #625 | Link | |
BluRip author
I think I'll have more time for development next month
BluRip : 1-Click BluRay/m2ts to h264 mkv converter http://code.google.com/p/blurip/ |
22nd February 2011, 10:45 | #626 | Link | |
BluRip author
22nd February 2011, 15:49 | #628 | Link | |
BluRip author
The link in my signature is the official homepage. BluRip is an open source project. Official builds you will only find there.
23rd February 2011, 22:41 | #629 | Link | |
I have this error but only with Maxthon browser and IE:
Maybe some add blocker with bad settings. enjoy, Mtz Last edited by Mtz; 23rd February 2011 at 22:45. |
19th March 2011, 21:27 | #632 | Link |
pb with subtitles
I just start using blurip 0.5.2, looks a very nice tool, but I have a problem with subtitles. I want to rip the Inception bluray If I choose "mux all subtitles (sub/idx)", then, when I activate subtitle on my PCH A110, it says "unsupported format". If I choose "mux untouched subtitles (PGS), then strictly nothing happens when I activate subtitles on my A110, however, vlc displays the subtitles correctly. Note that in both cases, mediainfo actually reports the correct subtitles in the final mkv file, so it looks more a problem with the PCH, but if someone can help, I would appreciate. Thanks Last edited by lukyluke; 19th March 2011 at 22:18. |
21st March 2011, 13:04 | #633 | Link |
BluRip author
Afaik only the 200 series supports pgs subs.
Both series do not support highres sub/idx. In blurip there is an option to mux lowres sub/idx. They should work with the a110.
27th March 2011, 17:15 | #634 | Link |
Ripping Blu-ray with interlaced video
Hi Hawk,
Is there a known issue about ripping interlaced video. I tried to rip 2 blu-ray which have video format 1080i50 and 1080i60, but Blurip simply crashes on both of them while "indexing / Cropping", I cannot even get a log since blu-rip hangs... Regards Christophe Edit: I tried to rip it with autocropping disabled (advanced options) then Blurip doesn't crash anymore but the result is unwatchable, encoded as 25fps... Last edited by cge; 28th March 2011 at 19:19. |
13th April 2011, 17:35 | #635 | Link | |
It seems BluRip doesn't write any meaningful message (except "Return code: 1") in the log if there's not enough space to demux. I tried demuxing a BD a couple times and couldn't figure out what was wrong. All I got was an error sound. I finally saw that I didn't have enough space.
This is all that's written at the end before it stops demuxing. Quote:
16th April 2011, 19:24 | #636 | Link |
Hmm. Why won't BluRip mux this? Mux log say "Audio file(s) not found".
log: http://pastebin.com/S4YkhFDh I tried muxing the demuxed files with with mkvmerge and the audio plays fine and is identified correctly as DTS-HD MA. What's the difference between the demuxed SUP files "_011_subtitle_English.sup" and "_011_subtitle_English_complete.sup"? |
24th April 2011, 09:11 | #638 | Link | |
3rd May 2011, 15:19 | #640 | Link |
All my recent remuxes with Swedish subtitles are labeled as Northern Sami (Finnish). I thought it was maybe because of the mkvtoolnix upgrade, but it didn't help downgrading to 4.4.0.
log: http://pastebin.com/ernWhBbX edit: It seems the reason this happens is because "preferred subtitle" (stream selection) is bugged. When I removed Swedish from the settings and chose the Swedish subtitle manually it was correctly labeled as Swedish instead of Finnish when muxed. Last edited by quasit; 23rd May 2011 at 22:30. |
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264 |
