22nd July 2015, 23:31 | #13741 | Link |
Manono,
Thank you for your reply. I actually just recently found the answer to my SD encoding question. I found a resource on converting SD DVD's which I will post below. After doing the procedure listed it worked fine. I am definitely spoiled by the blu ray quality but it is better than what I had. A lot more steps than what I do on blu ray conversion. Hope this helps anyone looking for the same guide. Here it is: Click Here Now I just wonder if there is something of the sort for better / optimized blu ray recoding... |
23rd July 2015, 05:32 | #13742 | Link |
And you followed his advice to first deinterlace with Yadif followed by decimating to 23.976fps? If so, you seriously degraded your movie. Which is why I asked for a sample - to see what you had before offering advice.
But that's okay. It's your movie. Do with it what you like. |
23rd July 2015, 17:03 | #13743 | Link |
manono is right. You should just select "INVERSE TELECINE" option if you are working with typical NTSC DVD.
27th July 2015, 02:08 | #13745 | Link |
.m4v file import request
Hi Atak,
I have acquired a large amount of .m4v x265 files that I would like to run thru Ripbot, however, this extension is not supported. Are you able to add this somehow, or suggest another process ? Would be greatly appreciated Cheers |
27th July 2015, 06:39 | #13746 | Link | |
And I apologize, as I accidentally edited your post. |
27th July 2015, 07:45 | #13747 | Link | ||
Silent Reader
Did you try to rename them to mp4? Only known difference (for me) is, that m4v can contain DRM Copy Protection (introduced by Apple). http://fileinfo.com/extension/m4v Quote:
28th July 2015, 23:48 | #13749 | Link |
I probably found bug...
if I choose x265 and go in detail, there is option to choose Tune (film, animation, etc). I guess x265 doesnt support these presets and therefore this should be grayed out with selecting x265 (like Level dropdown menu) coz when I select for my x265 project --tune film video wont encode (running job1_EncodeVideo.cmd shows error) also :\\ripbot264 1.18.3\Tools\x265\x265help.txt is empty and also there are some issues since ripbot264 v1.8.1. no output file is generated (created). nor on deafult output path, nor on custom selected path, nor even if I set it in RipBot264.ini file. to finish my project I always must manualy mux all the tracks with mkvmerge GUI (throw there audio from C:\Temp\RipBot264temp\job1\Encoded_Audio_1.acc and video track from C:\Temp\RipBot264temp\video.265). its very unpleasant tho Last edited by Shamans09; 29th July 2015 at 21:09. Reason: update |
30th July 2015, 03:20 | #13750 | Link | |
Click here |
30th July 2015, 22:55 | #13751 | Link |
Atak_Snajpera,
I am re-evaluating my recoding procedures for a Blu Ray DVD. Earlier I believed that using the "2-Pass" mode was the best. Only because the 1-Pass would evaluate the rip and then the 2-Pass would encode it more effectively. Furthermore, using this method I can see an estimated file size of the final product. Typically I would use a KBPS of 8192, however since one of your past responses you mentioned that I was not limited to that. So I been pushing more 9000 or 10,000. This of course increases the file size. Is there a actual science or formula that I could use that would give me a good movie recode yet not be huge in size? I know of the CQ mode, but is this a better option at a particular CRF level? Is there a resource on the web where I can read about this? Appreciate your and the rest of the groups patience. |
31st July 2015, 11:36 | #13752 | Link |
you are trying to invent a wheel again. CQ does exactly what you want! End of story.
5th August 2015, 11:33 | #13758 | Link |
see job folder.
5th August 2015, 11:46 | #13759 | Link | |
Atak forgot to edit the version number on this forum. So, now I can say, thanks for the new version, they've been coming thick & fast, recently Cheers |
5th August 2015, 13:17 | #13760 | Link | |
http://forum.doom9.org/showthread.php?t=172423 http://forum.doom9.org/showthread.php?t=171711
