21st October 2015, 15:37 | #13961 | Link |
Another issue I'm having with this new version of Ripbot is every now and then when I try to preview the movie it says:
"I don't know what 'unununununununununununununununununununununununchecked1' means (J:\Blue Ray Ripping\Tools\Avisynth plugins\scripts\downmixaudio.avs, line 19) (J:\temp\ripbot264temp\job2\job2_a1.avs, line 7) (J:\temp\ripbot264temp\job2\job2_preview.avs, line 38) Last edited by gabbett1; 21st October 2015 at 15:40. |
24th October 2015, 07:06 | #13962 | Link |
Atak,
I made sure that the auto Update was on and I am still getting the invalid time error. I tuned auto update off, restarted program, turned it on and restarted program and I get the same invalid time error. Restarted the computer and get the same issue. |
24th October 2015, 16:12 | #13963 | Link |
hello guys,
ive captured a 1080i25p File from my STB. Now i want to encode it to 720p50. In my darkest memories (lol) i could make it happen with a "deinterlace" button in the encoder settings. But i could not find it in the new version. Any ideas ? |
25th October 2015, 06:40 | #13964 | Link |
Atak,
What is your thoughts on the Non Local Means denoiser? I just started processing a Land Before Time and it is probably the grainiest movie I have ever encountered. I've run the movie through a few times using different settings for HQDN3D but upping spatial settings high enough to reduce the file size to get down to even 5.5GB for a hour and eight minute movie started to really scrub out a lot of detail. I'm going to play around with the temporal settings of the filter now and see how it turns out, but last time I did that I saw ghosting with even conservative settings. I knew that Handbrake has the option of using the NLMeans denoiser. I just ran a two minute preview through handbrake using NLMeans preset Strong, with the Tune of Animation. The resulting output was excellent. Though the processing time for that two minute preview was very long. I'm going to run the whole movie through Handbrake using those settings. Estimated time I think will be longer then a day. |
27th October 2015, 15:01 | #13966 | Link | |
I worked with HQDN3D's temporal settings a few times and I could not get that much of an improvement. So the job is finally done for Handbrake using the NLMeans denoiser. Only took two days with two 12 core Opterons working on it. The resulting output is simply stunning. Why the studio could not have done something similar is beyond me. To me, it looks far better then the original source. The final file size is 3.1GB. Atak, if you would like some clips of the original source and the resulting output file, let me know. I hope you can add the Non Local Means Denoiser to RipBot264. There is a huge hit in CPU, but the resulting output with extremely grainy sources is almost mind boggling. |
27th October 2015, 17:30 | #13967 | Link | ||
27th October 2015, 18:18 | #13968 | Link | |
I upgraded to 1.19.2 yesterday. I encoded two movies successfully. The third movie gave me a "avs2yuv.exe has stopped working" error twice at 95.6%.
I saw on the updated first post that: Quote:
When I hit "close" on the error message, Ripbot continues to the muxing process. Anything else I can do? Machine: Windows 8.1 (x64), i7 4790k, 16gb ram. Using local encoding, not distributed encoding. |
27th October 2015, 18:50 | #13969 | Link | |
I think the Strong setting maxed everything out. The Light setting did not take that much time when I used it on another source. I still think this would be a nice option to have. I think I'll run it again on light and medium using the same source and see how longs it takes. |
27th October 2015, 18:58 | #13970 | Link | |
So far, I've encoded about 20 movies with ripbot's distributed encoding. I do not watch the movies I encode right away. Since I (randomly) found a playback error with one of the movies, and re-encoding simply reproduced the error, I had to stop using ripbot. I would very much like to be able to use ripbot's distributed encoding again, but since I have no clue what produced the error, I can't encode with confidence. Anyone knows what could make the video display the same frame for a few seconds, (while audio playback is still smooth)? Thanks! |
27th October 2015, 19:23 | #13972 | Link |
post mediainfo report of source file.
27th October 2015, 19:46 | #13973 | Link |
I demuxed the audio and video from the disc.
Video: General Complete name : D:\chick\chicken_little.264 Format : AVC Format/Info : Advanced Video Codec File size : 12.0 GiB Overall bit rate mode : Variable Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Bit rate mode : Variable Maximum bit rate : 40.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio: General Complete name : D:\chick\chicken_little.ac3 Format : AC-3 Format/Info : Audio Coding 3 File size : 370 MiB Duration : 1h 20mn Overall bit rate mode : Constant Overall bit rate : 640 Kbps Audio Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Duration : 1h 20mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 370 MiB (100%) Secondary question: I've done two other movies prior to this error, I've used: High 4.1, Slow, Animation with a CQ 19. When using Mediainfo, both encodes show 10 Ref Frames. I thought "slow" meant 5 Ref frames, any reason why I'm getting 10? Last edited by essential; 27th October 2015 at 23:35. Reason: added secondary question |
28th October 2015, 06:55 | #13974 | Link | |
Some of "us" do have some pretty powerful "rig's" And as AMD Opterons aren't Hyperthreaded, 2 x 12 core Opterons would be about the same as 1 x 12 core Intel Xeon. |
31st October 2015, 08:56 | #13977 | Link |
ripbot264 does not muxing encoded video. i tried old ripbot versions and i can find video.264 file in temp folder but there isnt any audio file and i cant see final file (encoded and with audio muxed video) at my source destination. i am using windows server 2008 r2 standart used ripbot profil main 3.1 hd, ipad, iphone what's wrong with my settings? PHP Code:
31st October 2015, 16:10 | #13978 | Link | |
@x110x
Run manually C:\Temp\RipBot264temp\job1\job1_EncodeAudio1.cmd in console and see what went wrong. Quote:
31st October 2015, 23:38 | #13979 | Link | |
PHP Code:
installing microsoft visual c++ packages and updating windows solved my problems, thank you anyway Last edited by x110x; 1st November 2015 at 08:19. |
1st November 2015, 15:24 | #13980 | Link | |
