Old 8th November 2015, 14:43   #34121  |  Link
seiyafan
There will be little to no difference unless you are using SuperRes. SuperRes is more effective when used with Image Doubling.
Originally Posted by aufkrawall View Post
I've never seen a real difference between Jinc AR or image doubling for 1080p -> WQHD, neither with SuperRes. I'm watching every 1080p video upscaled to WQHD.
Thanks for confirming that, I was thinking about the same thing.
seiyafan is offline   Reply With Quote
Old 8th November 2015, 14:58   #34122  |  Link
Thunderbolt8
is anyone able to tell the difference of what sharpen, crisp, thin edges are doing?
and what exactly "enhance detail" means? is it normal sharpening? or do just some things get sharpened and others dont? on what basis?
Old 8th November 2015, 15:03   #34123  |  Link
ibius
How about you read at least 1-2 pages back first?
Madshi's second post one page back covers that.
ibius is offline   Reply With Quote
Old 8th November 2015, 15:09   #34124  |  Link
madshi
Originally Posted by KoD View Post
It happens with both latest two MPC-HC nightly builds (190 and 202). Having "keep aspect ratio" checked or not does not matter. The sample I provided is only 500Kb, so it's easy to download it and test.
Edit: looks like madVR ignores the container set AR (which is 16:9) and instead uses the video stream AR (which is 4:3).
I had tried and wasn't able to reproduce the problem. But I tried again and now found that the problem only occurs with "detect black bars" disabled. Should be fixed in this test build. Can you confirm?
http://madshi.net/madVR8915arFix.rar
Originally Posted by nlnl View Post
Can not reproduce using software decoding.
Debug log:
https://drive.google.com/file/d/0B7a...w?usp=sharing]
Ah, ok, I understand the problem.
In theory the stream could switch between progressive and interlaced all the time, which would mean madVR would have to switch deinterlacing on and off all the time. If I changed refresh rate every time that happens that could be very annoying. So atm madVR only changes refresh rate in very specific situations: 1) When playback starts, if the settings say so. 2) When going fullscreen, if the settings say so. 3) When manually activating video mode deinterlacing.
Not sure whether there are real world videos out there which often switch back and forth between progressive and interlaced?
Software decoding is not affected because it's fast enough to switch madVR into video mode deinterlacing. DXVA takes too long, so at the moment when madVR wants to switch refresh rates, DXVA has not yet told madVR that the video is interlaced.
Old 8th November 2015, 15:19   #34125  |  Link
KoD
The issue is fixed with this build.
KoD is offline   Reply With Quote
Old 8th November 2015, 16:22   #34126  |  Link
madshi
Ok, will release a new official later today, will take a couple of hours, though.
Could you please bring back the radius option for a build or two?
You can add e.g. "superResRadius=80" to the file name now to force a SuperRes radius of 80.
Old 8th November 2015, 17:05   #34127  |  Link
AngelGraves13
Did some testing with SuperRes and will still leave it off as it sharpens the image undesirably. It didn't look too good when I was watching 720p content at 1440p. It was too sharp. Disabled and all was back to normal. I guess SuperRes isn't for me.
AngelGraves13 is offline   Reply With Quote
Old 8th November 2015, 17:17   #34128  |  Link
MS-DOS
AngelGraves13, if you tested it with one of the latest two builds then maybe it's because the Radius option was removed and forced to 0.66, which makes it look way too sharp and aliased sometimes. I used it with 1.00 before and it was totally fine to me.
MS-DOS is offline   Reply With Quote
Old 8th November 2015, 17:18   #34129  |  Link
aufkrawall
You could try a higher radius like madshi explained above or a lower strength.
I noticed that after playing around with different upscaling refinements, madVR somehow disabled NNEDI3 and used Jinc instead. It couldn't be activated again unless madVR was restarted. Haven't been able to reproduce yet, but there must be a small problem.
Old 8th November 2015, 17:21   #34130  |  Link
AngelGraves13
I'm mostly watching 1080p blu-rays from my personal collection that I've remuxed to avoid using discs. The content looks fine with Jinc AR for Chroma and Image. SuperRes doesn't make it look better.
Old 8th November 2015, 17:30   #34131  |  Link
mzso
There are a bunch of sharpening algorithms now. Is there some writing about it? How do they compare to each other quality wise. Or in what situation do they come handy?
For a long time I used the players sharpencomplex2 shader. Now I started using madVR's adaptivesharpen, though to be honest I don't know if it's the best one (for me).
Old 8th November 2015, 17:33   #34132  |  Link
aufkrawall
imho fonts or emblems look too blurry with 1080p -> WQHD without SR. Especially true for fine white fonts.
Old 8th November 2015, 17:47   #34133  |  Link
Sunset1982
I'm using madvr to upscale 1080p Bulray remux files to a 4k Display but there is a lot of noise. Any suggested settings to get rid of it?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 8th November 2015, 18:34   #34134  |  Link
pankov
Honestly, do you have any videos which need rotation *and* have subtitles?? I thought about subtitles, but it's pretty hard to implement correctly, and my thinking was that videos that need rotation are very unlikely to have subtitles. So I simply didn't spend any time on working on rotated subtitles. If you have legit files which need rotation and have subtitles, please let me know where they come from and why they are rotated. Then I'll think about whether it's worth spending time on...
To be hones no, I don't have such video files - it was just an imaginary use case and since you say that it's not easy to be implemented I totally agree with your decision not to invest time in it until there is a legit need for it.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS
NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V
Win 10 64bit 1803 + Zoom Player v14
pankov is offline   Reply With Quote
Old 8th November 2015, 19:30   #34135  |  Link
Thunderbolt8
I found the post you are refering to. just dont refer to page numbers please, some people have different posts per page settings.
Old 8th November 2015, 20:08   #34136  |  Link
6ari8
Thanks for the new build madshi!
I'm an AdaptiveSharpen user and I must say I'm really happy with the new sharpen edges option. I'm torn between the two but I think I'll settle on one of them after some tests.
However, there may be a bug in the new build's "upscaling refinement" options.
When choosing SuperRes on its own, the "refine the image after every...."/"refine the image only once...." is greyed out even though it takes effect according to the checked option of the two.
So If I wanted to change that option I have to check one of the other refinement options temporarily so it becomes visible.
6ari8 is offline   Reply With Quote
Old 8th November 2015, 20:22   #34137  |  Link
obieobieobie
Another black screen log for 0.89.15 with unchanged settings from 0.89.13 where there is no black screen with this clip:
fryingpanfail.webm
log here (dunno why the log is HUGE):
http://s000.tinyupload.com/index.php...52747541458473
obieobieobie is offline   Reply With Quote
Old 8th November 2015, 20:27   #34138  |  Link
XMonarchY
Damn, I still get stutters after pausing and then resume videos and nothing I've tried or that was recommended made any difference... Its SO annoying.
Old 8th November 2015, 20:40   #34139  |  Link
djsolidsnake86
the aspect ration problem finally is gone
the only problem now is the stuttering when going fullscreen with a video with mpchc
djsolidsnake86 is offline   Reply With Quote
Old 8th November 2015, 21:56   #34140  |  Link
madshi
If you find a way to reliably reproduce it, let me know.
Asked and answered twice already in the last couple of pages.
There's no denoise algo in madVR. You could try ffdshow raw video processing with some AviSynth noise reduction script. Sorry, can't tell you any more than this. That's a topic for a different thread. In this thread all I can say is: madVR currently doesn't do denoising.
Ah ok.
Let me know what you settle on and for what reasons. Please judge quality and performance separately.
In the next build SuperRes will always only be applied once, because it simply doesn't make sense any other way. SuperRes has no benefit from being applied multiple times.
I think this should be fixed in v0.89.16.
Please create a debug log with 20 seconds worth of stuttering. Afterwards please stop MPC-HC by pressing Alt+F4, then zip and upload the debug log.
Debug log:
I've done a change in v0.89.16 which should hopefully fix this problem.
