Old 29th September 2020, 19:15   #30021  |  Link
Ch3vr0n
I did, but forgive me for asking, but isn't that the opposite of what i asked?
i'm trying to create movie-only output type but i can't figure it out. I'd like "MKV, Full-SBS (3D)...
. I may very well not be understanding things entirely. I've done plenty full disc 3D backups, 3D MKV's to me are a new ballgame.
What's the difference then between full-SBS (3D) and "no resize". Reason why i'm asking is because my home theatre projection system only has 3D options for OU and SBS (Nebula Cosmos). i have no idea what the outcome would be if i pick "no resize"
Ch3vr0n is online now   Reply With Quote
Old 29th September 2020, 21:00   #30022  |  Link
cartman0208
I did only UHD Full Backups with the new version so far but I noticed two things:
Whenever the size-correcting second pass is applied to the main movie, the disk is slightly (5-10%) oversized
Disks with only one pass on the main movie hit the destination size pretty good.
Also after clearing the batch queue, I get a Runtime Error '35601' when clicking on the Batch tab or trying to add the current project to batch.
That persists even when restarting BDRB.
Old 29th September 2020, 23:11   #30023  |  Link
Originally Posted by Ch3vr0n View Post
I did, but forgive me for asking, but isn't that the opposite of what i asked? . I may very well not be understanding things entirely. I've done plenty full disc 3D backups, 3D MKV's to me are a new ballgame.
If you select "No Resize" and you set the switch I mentioned on a 3D source -- you will get full SBS output. You can also get OU if you want by using the TYPE_OF_3D hidden options (see HIDDENOPTS.TXT). You can even switch the views (left/right), for the rare occasion where a player is different, with the SWAP_3D hidden option.
Old 29th September 2020, 23:21   #30024  |  Link
1. I'll look at the sizing issue.
1. The 35601 error is a weird one. Try deleting the file BDBATCH.INI and see if the problem goes away.
Old 30th September 2020, 00:26   #30025  |  Link
LowDead
Elit Amans
have tested the new version on the problematic disc...
Good news: No more error on that 60fps 4k mux.
Bad news: New error that I can't continue from.
- [01:17:22] Processing: VID_00341 (15 of 43)
- [01:17:22] Extracting A/V streams [VID_00341]
- Extracting video streams [VID_00341]
- Processed 5823 video frames
- Error in attempt to extract video.
[01:17:41] - Failed to retrieve audio, aborted
//LD
Old 30th September 2020, 09:33   #30026  |  Link
Sharc
[Edit] You'll have to use either X264 or X265. I just tried one using NVENCC and it choked on the input. Not sure why, but I'm guessing it either doesn't like the sizing or it has an issue with the AVS. I'll look at it for the next release.
There seems to be a problem with the script. Opening the script in MPC-HC gives the error for line 3 of the script:
"Cannot initialize Intel media SDK session"
#Created by BD Rebuilder - v0.61.17
LoadPlugin("P:\Program Files Video\BD_Rebuilder\tools\frimsource.dll")
SBS=FRIMSource(codec="mvc",filename="F:\BDMV\STREAM\00800.m2ts",filename_dep="F:\BDMV\STREAM\01065.m2ts",layout="sbs",ts=true,platform="sw",cache=24,num_frames=166915)
VIEW1=Crop(SBS,1920,0,1920,1080)
VIEW2=Crop(SBS,0,0,1920,1080)
StackHorizontal(VIEW2,VIEW1)
ConvertToYV12().AssumeFPS(24000,1001)
So it seems not to be related to the NVEncC encoder?
The source is a 1920x1080 3D MVC Blu-ray.
Edit:
All right, I had to put the 'BD_Rebuilder\Tools' folder into the PATH.
Now I am getting the script error:
Crop: you cannot use crop to enlarge or 'shift' a clip
Edit2:
I think that the 3 lines
can be deleted from the script when the parameter 'layout="sbs"' is set, so it seems to work with something like
return SBS.converttoYV12().AssumeFPS(24000,1001)
Edit 3: ... and this also works with NVEncC as the encoder
Edit4: Pulling my hair...
After been through the steps above, I now found that the original script seems to work fine now. So the solution was probably to include the Tools folder (or the libmfxsw32.dll) in the PATH. Oh well .....
Anyway, happy that it works now with NVEncC as well
Old 30th September 2020, 10:36   #30027  |  Link
cartman0208
Forgot to mention, I only used NVENC
Deleted BDBATCH.INI, BDITEM.INI and BDREBUILDER.INI to be sure. Works again and I couldn't reproduce the issue.
I will test some more.
Old 30th September 2020, 16:59   #30028  |  Link
Ch3vr0n
Tried and failed with 61.16. One thing i noticed is that the decoding/frameserving sais "FRIMSource", however the decoding process itself is done by DGDecNV, as there's a part about "completing DGIndexing". Picked the option "VBR Target Site (MB) with a value of 8600"
[09/30/20] BD Rebuilder v0.61.16
[17:35:14] Source:  TOMB_RAIDER_00098
  - Input BD size: 42,66 GB
  - Approximate total content: [01:57:50.438]
  - Windows Version: 6.2 [9200]
  - Mode: MKV Container, Full-SBS (3D), Intact Audio
  - Quality: High Quality (Default)
  - Output folder: H:\Blu-ray\Encodes\BDRB\
  - 3D conversion mode enabled
  - Decoding/Frame serving: FRIMSource
[17:35:16] PHASE ONE, Encoding
 - [17:35:16] Processing: VID_00252 (1 of 1)
 - [17:35:16] Extracting A/V streams [VID_00252]
[09/30/20] Checking System Settings
  - BD-Rebuilder v0.61.16
  - Working Path Free Space: 467,30GB
  - AVISYNTH Version: 2.6.0.6, Ok
  - LAVFILTERS:  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - X265:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[09/30/20] Systems Settings Check complete
 - [17:45:02] Reencoding video [VID_00252]
   - Rate/Length: 23,976fps, 169.521 frames
   - Converting output to Side-By-Side 3D Format
   - Bitrate: 7.184 Kbs
 - [17:45:02] Reencoding: VID_00252, Pass 1 of 2
[17:45:03] - Failed video encode, aborted
[17:48:50] Source:  TOMB_RAIDER_00098
  - Mode: MKV Container, NO_RESIZE, AutoGOP, Auto-AC3
[17:48:51] PHASE ONE, Encoding
 - [17:48:51] Processing: VID_00252 (1 of 1)
 - [17:48:51] Extracting A/V streams [VID_00252]
 - [17:58:26] Reencoding video [VID_00252]
   - Bitrate: 9.236 Kbs
 - [17:58:26] Reencoding: VID_00252, Pass 1 of 2
[17:58:27] - Failed video encode, aborted
[Options]
VERSION=0.61.0.16
ENCODER=1
MODE=3
ENCODE_QUALITY=0
ONEPASS_ENCODING=0
AUTO_QUALITY=1
TARGET_SIZE=23500
AUTO_BURN=0
AUDIO_TO_KEEP=dut;eng;nld;und;
SUBS_TO_KEEP=dut;eng;nld;und;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=0
REMOVE_WORKFILES=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
COMPLETION_BEEP=1
OUTPUT_SBS=1
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=4100
#FRIM_SW_DECODE=0
FRIM_SW_ENCODE=1
#SPECIAL_3D_MUX=1
#General Settings
ENABLE_TEST=1
ENABLE_BLANKING=1
BEEP_SOUNDFILE=C:\Program Files (x86)\ImgBurn\Sounds\Success.wav
OUTPUT_FOLDER=H:\Blu-ray\Encodes\BDRB
MINIMIZE_TO_TRAY=1
MOVIEONLY_TYPE=32
ALTCRF=23
ALT_TARGET=8600
ALT_CRF_TARGET=2048
ALTMETHOD=2
ALTAUTOCROP=0
FRIMSOURCE=0
NVENC_CAPABLE=1
[Paths]
SOURCE_PATH=L:\
DGIndexNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\x32 Binaries\DGIndexNV.exe
DGDecNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\x32 Binaries\DGDecodeNV.dll
WORKING_PATH=H:\Temp\
Will try 61.17 next. just noticed the new version.
** edit ** still failed with 61.17 but worked when i switched encoder from NVEnc encoders to "x264 / x265". Don't know if i overlooked you saying that part, if you didn't, maybe it's an idea to auto use that as a fallback?
Old 30th September 2020, 17:42   #30029  |  Link
Sharc
Try 1-pass (constant quality mode, CQM) encoding.
NVEnc does not support classic 2-pass encoding.
Old 30th September 2020, 17:46   #30030  |  Link
Ch3vr0n
Yes it does, and i didn't specify any pass. BDRB did. I'm using automatic quality settings.
Old 30th September 2020, 18:31   #30031  |  Link
Sharc
It doesn't. See NVEnc documentation. Its '2-pass' applies to single frames rather than for the entire video. This is different from the classic global 2-pass which uses the stats file from pass 1.
In the Alternate Movie-Only output, select 'Constant Quality Mode (CQM)' and put your quality value there, e.g. 22.
Works perfectly here.
Old 30th September 2020, 22:43   #30032  |  Link
BD Rebuilder v0.61.17
I've updated the first post of this thread with a link to the latest release of BD Rebuilder (v0.61.17). Changes for this release:
- Corrected an issue in which attempts to
  perform a size-correcting second pass on
  an AVC source could result in an error
  "PredictAndEncode() 00011  2994".
- Made adjustments to correct for bad time
  codes in .SUP files that could result in
  certain oddly formatted multi-part sources
  (shows itself as subtitles that extend
  well beyond the lenght of the movie)
- Added changes that will prevent occurance
  of some "Bitstream exception" errors.
- Implemented default use of v2.6.16 of
  TSMUXER for all TSMUXER functions.  In
  order to disable and return to v2.6.12
  use hidden option "ENABLE_NEW_TSMUXER=0".
- Added a routine that catches previously
  undetected errors in AAC encoding and then
  attempts reencoding via a new method.
- Corrected a setting used with HEVC that
  could assert HDR when it is not present in
  the original source.
- Updated TSMUXER4K to the 2020-09-25 build.
There have been no changes made since the test release of this version.
Old 1st October 2020, 16:37   #30033  |  Link
ggtop
Hi jdobbs,
can you please check if setting "MULTIPROCESS" is deprecated in the last version?
I have it set to "MULTIPROCESS=2" in my INI and used to see "- Decoding/Frame serving: DGDecNV [2-way]" in the log, but using 0.61.17 I see only "- Decoding/Frame serving: DGDecNV" and one x264 process running. No big deal as it wasn't the speed gain on my system anyway, but I wanted to mention as I remember you changed something for cartman increasing max thread limit.
Thank you,
ggtop
Old 2nd October 2020, 11:19   #30034  |  Link
LowDead
Elit Amans
//LD
Seems I did this test from the already processed/encoded test output instead of the original folder. I'm running from original folder right now and there's no problem at all (yet...)
It didn't work.. I almost got through the whole disc but managed to get the same error as before:
- [12:59:31] Multiplexing M2TS
- [13:00:51] Processing: VID_00359 (33 of 43)
- [13:00:51] Extracting A/V streams [VID_00359]
- Extracting video streams [VID_00359]
- 93.8% complete
- 93.8% complete
- 93.8% complete
[13:15:43] - Failed to retrieve audio, aborted
//LD
Old 2nd October 2020, 20:13   #30035  |  Link
- 93.8% complete
- 93.8% complete
- 93.8% complete
//LD
It's going to be hard to debug from just that. Are you positive you have plenty of disc space. I got an error almost identical to that a couple days ago -- and then realized my disc had gotten full.
Old 3rd October 2020, 01:08   #30036  |  Link
LowDead
Elit Amans
hehe.. You nailed it. How could I miss that.. I should sleep at night, not sit by the computer when my eyes barely can see straight.. ghaa. coffee. must. have.
Sorry for that. Everything is working as it should now. No more errors. Please move along, nothing to see here
//LD
Old 3rd October 2020, 14:33   #30037  |  Link
//LD
Good to hear.
Old 7th October 2020, 00:08   #30038  |  Link
LowDead
Elit Amans
With successful tests of Full UHD x265 encodes resulting in extremely super sweet quality i'm eager to begin testing backup using the NVEnc encoder.
And I was wondering a bit about the encoder settings. Am I right to think that CQM is the constant quality option and the VBR is the same as the old-school version of VBR?
I was somewhat thrown off by Sharc's posts #30037 and #30039. I will not do any alternative output, only full UHDs.
//LD
Old 7th October 2020, 07:13   #30039  |  Link
Sharc
//LD
NVEnc supports both quality based (CQM) and bitrate (target file size) based 'VBR' encoding, and so does BD-RB.
My posts just recalled the fact that - under the hood - '2-pass' has a different meaning for NVEnc than for x264/x265. This has been discussed further up in the thread. You shouldn't have to worry much about this. You can try BD-RB's options and settings. What isn't available is greyed out in the menus or hidden (unless there is a bug ....).
So for full backups using NVEnc you will find under 'Settings->Encoder Settings' the options 'One Pass (CQM) Encoding' (quality based) and 'One Pass (VBR) Encoding' (bitrate based acc. target size). In the case of NVEnc you have to select one of these. You can't disable both to invoke the classic 2-pass encoding as you could for x264/x265. It will however internally trigger '2-passes' as per NVIDIA's per frame definition.
Sorry to have caused some confusion.
Added:
See the discussion around here:
https://forum.doom9.org/showthread.p...54#post1918354
Old 8th October 2020, 02:10   #30040  |  Link
LowDead
Elit Amans
Added:
Great, Thanks for the clarification!
//LD
