15th February 2015, 15:56 | #22281 | Link |
3D movie only + multiangle error
Hello,
I've an error while trying to make a movie only backup of ice age 4. this is a multiangle BR. if i stay on default angle, no error. if i choose a specific angle (french or awhatever), i've got an error: Code:
---------------------- [02/15/15] BD Rebuilder v0.50.03 [12:16:05] Source: ICE_AGE_4_3D_00800 - Input BD size: 28,35 GB - Approximate total content: [01:27:45.259] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:16:07] PHASE ONE, Encoding - [12:16:07] Processing: VID_00500 (1 of 3) - [12:16:07] Extracting A/V streams [VID_00500] [12:16:20]PHASE ONE aborted by user request ---------------------- [02/15/15] BD Rebuilder v0.50.03 [12:16:31] Source: ICE_AGE_4_3D_00800 - Input BD size: 27,37 GB - Approximate total content: [01:27:45.259] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:16:33] PHASE ONE, Encoding - [12:16:33] Processing: VID_00511 (1 of 3) - [12:16:33] Extracting A/V streams [VID_00511] - Extracting video streams [VID_00511] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00511.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00511.m2ts [12:16:44] - Failed to retrieve audio, aborted ---------------------- [02/15/15] BD Rebuilder v0.50.03 [12:17:14] Source: ICE_AGE_4_3D_00800 - Input BD size: 28,02 GB - Approximate total content: [01:27:45.259] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:17:16] PHASE ONE, Encoding - [12:17:16] Processing: VID_00512 (1 of 3) - [12:17:16] Extracting A/V streams [VID_00512] - Extracting video streams [VID_00512] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00512.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00512.m2ts [12:17:36] - Failed to retrieve audio, aborted ---------------------- [02/15/15] BD Rebuilder v0.50.03 [12:32:17] Source: ICE_AGE_4_3D_00800 - Input BD size: 28,02 GB - Approximate total content: [01:27:45.259] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:32:18] PHASE ONE, Encoding - [12:32:18] Processing: VID_00513 (1 of 3) - [12:32:18] Extracting A/V streams [VID_00513] - Extracting video streams [VID_00513] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00513.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00513.m2ts [12:32:39] - Failed to retrieve audio, aborted ---------------------- [02/15/15] BD Rebuilder v0.50.03 [12:32:55] Source: ICE_AGE_4_3D_00800 - Input BD size: 28,02 GB - Approximate total content: [01:27:45.259] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:32:56] PHASE ONE, Encoding - [12:32:56] Processing: VID_00514 (1 of 3) - [12:32:56] Extracting A/V streams [VID_00514] - Extracting video streams [VID_00514] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00514.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: M:\BDMV\STREAM\00514.m2ts [12:33:17] - Failed to retrieve audio, aborted [02/15/15] Checking System Settings - BD-Rebuilder v0.50.03 - Windows Version: 6.2 [9200] - Working Path Free Space: 124,84GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [02/15/15] Systems Settings Check complete the last and only modified file (after closing the err55 message box) seems to be \BDoutputfolder\BDMV\PLAYLIST\00001.mpls |
15th February 2015, 19:17 | #22282 | Link |
I don't think I've ever actually tried doing an movie-only backup from an alternate angle with 3D, although I can't think of why it would be different. I'll do some tests.
I'll also look at your other reported issue. |
15th February 2015, 21:11 | #22283 | Link | |
1. BD starts creating a file named: 00002.track_4114.mvc Code:
Verzeichnis von D:\Temp\_BD.rebuilder\WORKFILES 15.02.2015 19:13 <DIR> . 15.02.2015 19:13 <DIR> .. 15.02.2015 19:13 102.760.448 00001.track_4113.264 15.02.2015 19:13 65.011.712 00002.track_4114.mvc 15.02.2015 19:13 18.874.368 00002.track_4352.dts 15.02.2015 19:13 18.874.368 00002.track_4353.dts 15.02.2015 19:13 0 00002.track_4608.sup 15.02.2015 19:13 0 00002.track_4609.sup 15.02.2015 19:13 0 00002.track_4610.sup 15.02.2015 19:13 587 AUD_00001.meta Can't open file: D:\TEMP\_BD.REBUILDER\WORKFILES\00002.track_4114.mvc 3. BD renamed the files and cannot find them anymore: Code:
Verzeichnis von D:\Temp\_BD.rebuilder\WORKFILES 15.02.2015 19:24 <DIR> . 15.02.2015 19:24 <DIR> .. 15.02.2015 19:24 18.258.929.292 00001.track_4113.264 15.02.2015 19:24 11.837.205.216 00001.track_4114.mvc 15.02.2015 19:24 2.035.171.400 00001.track_4352.dts 15.02.2015 19:24 2.092.235.348 00001.track_4353.dts 15.02.2015 19:24 30.982.730 00001.track_4608.sup 15.02.2015 19:24 33.034.374 00001.track_4609.sup 15.02.2015 19:24 28.265.523 00001.track_4610.sup 15.02.2015 19:13 587 AUD_00001.meta 15.02.2015 19:24 307 AUD_00001_4352.AVS 15.02.2015 19:24 307 AUD_00001_4353.AVS 15.02.2015 19:24 620 MUX_MOVIE_ONLY.meta 15.02.2015 19:24 297 VID_00001.AVS 15.02.2015 19:24 156 VID_00001.CHP 5. Input BD size: 33,80 GB -> Target BD size: 23,44 GB. The created folder is ~ 33 GB, no convertion! Code:
---------------------- [02.15.15] BD Rebuilder v0.50.03 [20:17:30] Source: SIN_CITY_2_3D_00002 - Input BD size: 33,80 GB - Approximate total content: [01:42:15.963] - Target BD size: 23,44 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640 - Audio [1] set to default. [20:17:30] PHASE ONE, Encoding - [20:17:30] Processing: VID_00001 (1 of 1) - [20:17:30] Extracting A/V streams [VID_00001] - [20:29:12] Reencoding video [VID_00001] - [20:29:12] Keeping original video (no reencode) - [20:29:12] Processing audio tracks - Track 4352 (deu): Keeping original audio - Track 4353 (eng): Keeping original audio [20:29:12]PHASE ONE complete [20:29:12]PHASE TWO - Rebuild Started - [20:29:12] Rebuilding BD-3D file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Can't open file: D:\TEMP\_BD.REBUILDER\WORKFILES\00002.track_4114.mvc [20:29:16] - Failed to REBUILD ---------------------- [02.15.15] BD Rebuilder v0.50.03 [20:33:58] Source: SIN_CITY_2_3D_00002 - Input BD size: 33,80 GB - Approximate total content: [01:42:15.963] - Target BD size: 23,44 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=640 - Audio [1] set to default. - Resuming from previously started job. [20:33:59] PHASE ONE, Encoding [20:33:59]PHASE ONE complete [20:33:59]PHASE TWO - Rebuild Started - [20:33:59] Rebuilding BD-3D file Structure [20:54:33] - Encode and Rebuild complete - WORKFILES folder removed. [20:54:33] JOB: SIN_CITY_2_3D finished. |
15th February 2015, 23:39 | #22284 | Link | |
15th February 2015, 23:59 | #22285 | Link |
@emilio99
Any idea how the file sizes changed so dramatically between the two illustrations? Was the first one captured while the extraction was in process? This one is really confusing. Have you had this issue with any other discs? Have you had success with other 3D discs? |
16th February 2015, 03:30 | #22287 | Link |
This isn't a bug report, so I hope you don't mind my asking a quick, general question...
I've never noticed this before after doing re-encodes with BDRB, but in this one case the result looks very good as usual, except I noticed that in scenes with slow pans, there is a noticeable 'judder'. I don't remember seeing this before. The one difference with this Blu-ray is that it is from The UK (I live in the US) It is a movie only encode with the original being about 31 Gigs which I used BDRB to reduce it to fit a BD25. I honestly doubt that BDRB has anything to do with it. I was just curious if there were some known causes of this phenomenon. From what I've found so far in my reading, is perhaps a different frame rate...??? (could this be the case since the Blu-ray is from Europe?) Is anyone familiar with this? Unfortunately, I just deleted the workfiles and everything because I burned the Blu-ray to disc as a backup and overall it looked fine. I feel stupid now because I didn't think to ask about asking here until after I did that. I could re-rip the Blu-ray to get the stats from it, but until I do that, I thought I'd go ahead and ask anyway, just in case there are some fundamental causes of this. Thanks! |
16th February 2015, 07:07 | #22288 | Link | |
There should normally be no need for framrate conversion because there is no longer PAL or NTSC. Blu-ray is blu-ray...... Did you change the resolution or deinterlace which may have forced a framerate conversion? Last edited by Sharc; 16th February 2015 at 07:11. |
16th February 2015, 07:34 | #22289 | Link | |
I'd better go back and check what I did more carefully; I'll check the original too. Thanks! |
16th February 2015, 07:43 | #22290 | Link |
There is always some judder with cinema movies. If it's not the usual judder check whether your Blu-Ray uses 24.000 fps. You will sometimes find such Blu-Rays in Europe but almost never in the US so maybe your equipment does not like it. In the US they seem to stick to 23.976 fps instead. (Or maybe it's some 50 fps stuff, a botched rate conversion even.)
16th February 2015, 09:08 | #22291 | Link | |
thanx |
16th February 2015, 13:35 | #22292 | Link |
I've seen this before -- 'La Mome' leaps to mind. That title was a 1080i stream, possibly at 30fps (there are numerous legitimate formats for Blu-ray). It had a messy judder type of video playback that was quite - quite - annoying, ruining an otherwise great film. The problem was on the original disc, so not the fault of BD-RB.
16th February 2015, 16:22 | #22293 | Link | |
I rechecked and see what you're talking about. There are playlists that call up just segments of the movie's M2TS file. I believe that's from a bonus feature that shows the most exciting moments of the movie for showing off what a Blu-ray can do. I can see how that would completely confuse things. Thanks for taking a look. |
16th February 2015, 16:37 | #22294 | Link | |
16th February 2015, 16:41 | #22295 | Link | |
16th February 2015, 17:47 | #22296 | Link | |
I have lots of original BDs that you can see the movement. Last edited by jdobbs; 16th February 2015 at 17:50. |
16th February 2015, 18:41 | #22297 | Link |
@emilio99
I don't know what I was thinking when I first looked at your problem. Of course the .mvc has a different name... that's because it's in a different M2TS file. I'm still looking at it, and haven't been able to repeat it yet. I have yet to locate a single point in my code in which an mvc file is renamed. Last edited by jdobbs; 16th February 2015 at 18:52. |
16th February 2015, 19:15 | #22298 | Link | |
It's fixed for the next release. Last edited by jdobbs; 16th February 2015 at 19:27. |
16th February 2015, 19:40 | #22299 | Link |
Jdobbs, you're clearly on a roll today So, I'd like to grease your wheels. Donation on the way.
I have a question. More than likely not a bug report, but I notice the rebuilt Boxtrolls 3D, has blocky artifacts when under 3D mode only, and played back on Powerdvd 14. Whether full backup, or movie only backup. I suspect that a standalone will not have this result. I'm simply curious why a rebuilt 3DBD via BD rebuilder, would cause Powerdvd to exhibit this curious outcome.
16th February 2015, 20:26 | #22300 | Link |
Thanks for the support!
I'm not really sure, but I'd be interested to know whether it happens on a standalone. Best guess would be a bug in PowerDVD 14. Try outputting to an ISO (OUTPUT_3D_ISO=1) in movie-only mode and see if that makes a difference. Maybe PowerDVD has a problem with in-mux 3D? It shouldn't since it is part of the standard, but you never know. (note: the HIDDENOPTS.TXT file is wrong, it says OUTPUT_3D_ISO defaults to 1, when in fact it defaults to 0. I edited it for the next release) Last edited by jdobbs; 16th February 2015 at 20:30. |
