7th January 2016, 15:25 | #23481 | Link |
Are you sure you have them selected? Your logs should have a line like this in it somewhere:
- [15:02:23] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... All I see is the first line. The second one would show, even if the encode ran into trouble. Last edited by jdobbs; 12th January 2016 at 17:32. |
7th January 2016, 19:22 | #23482 | Link | |
8th January 2016, 01:30 | #23485 | Link |
Windows told me multiple files were longer duration than they were, and mediainfo, said they were a mere 9 seconds total. Suffice to say, I don't trust MediaInfo, or Windows to correctly report anymore. Which is unfortunate. Because when I only require one file for my dealings, it helps when it's accurately reported
8th January 2016, 18:28 | #23488 | Link |
mkv remux
I wanted to remux an imported PAL DVD to mkv, keeping video and audio intact (profile [00028] in the alternate.txt)
BD-RB finished without error but left me with a small (20MB) .mkv file only. I suspect something went wrong with the remuxing, because importing and streams extraction etc. went well. I could remux the intermediate .m2ts successfully with mkvtoolnix btw. I could also re-encode successfully with BD-RB, so it seems to be only the "intact" mode which fails) Any idea? |
8th January 2016, 19:10 | #23489 | Link | |
How big are the M2V and AC3 files combined? |
8th January 2016, 21:58 | #23490 | Link | ||
8th January 2016, 22:21 | #23491 | Link |
Check the audio, if it's atmos that's your problem. It's not an officially supported codec in the standard. It's an extension of it. You'll need to keep original audio or check if the audio converter eac3to? has an update that supports atmos. Bdrb doesn't officially support atmos.
Verstuurd vanaf mijn Nexus 7 met Tapatalk |
8th January 2016, 22:56 | #23492 | Link | |
BDRB may not "officially" support Dolby Atmos but I also mentioned that I recently backed up MI5 and Terminator Genisys, both with Dolby Atmos to BD9. At BD9 BDRB uses the Atmos core@640 so no re-encoding is necessary... |
8th January 2016, 23:33 | #23493 | Link | |
.mpv is 3.21GB .ac3 are 2x148MB (2 languages, 2-channel stereo each) Here the log: Code:
[01.08.16] BD Rebuilder v0.50.11 [23:16:52] Source: BRING_ME_THE_HEAD_OF_ALFREDO_GARCIA_00001 - Input BD size: 3.79 GB - Approximate total content: [01:47:55.880] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV, Intact Video, Intact Audio - X264 Tweak(s) enabled - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [23:16:56] PHASE ONE, Encoding - [23:16:56] Processing: VID_00001 (1 of 1) - [23:16:56] Extracting A/V streams [VID_00001] - [23:20:48] Reencoding video [VID_00001] - [23:20:48] Keeping original video (no reencode) - [23:20:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (deu): Keeping original audio [23:20:48]PHASE ONE complete [23:20:48]PHASE TWO - Rebuild Started - [23:20:48] Building ALTERNATE OUTPUT Structure [23:20:58] - Encode and Rebuild complete [23:20:58] JOB: BRING_ME_THE_HEAD_OF_ALFREDO_GARCIA finished. |
9th January 2016, 01:20 | #23494 | Link | |
9th January 2016, 03:42 | #23496 | Link | |
9th January 2016, 04:30 | #23497 | Link | ||
I don't think BDRB uses eac3to... |
10th January 2016, 16:03 | #23499 | Link | |
I tried with another DVD. Same problem. Alternate output to .mkv with intact audio and intact video fails, outputting a small .mkv only which is not playable. BD-RB finishes without error though. |
11th January 2016, 14:54 | #23500 | Link | |
[Edit] Never mind, I found one in a box. I knew I had some for testing. I'll run some tests and see what I can find. Last edited by jdobbs; 11th January 2016 at 15:09. |
