21st March 2009, 23:07 | #4541 | Link |
I had 2 jobs in my queue, and the first job said that it was done and it was working on the Job2 (2% first pass).
Job1=*DONE* 00251.m2ts -> 00251.bluray Job2=00244.m2ts -> 00244.bluray I clicked on "Abort job" and went to look for 00251.bluray folder and it wasn't there. I only had ~18 Gig of HD space left. Has anyone else run into this issue? Last edited by hoju3508; 21st March 2009 at 23:17. |
21st March 2009, 23:57 | #4542 | Link |
RipBot seems pretty cool. I currently use handbrake but handbrake needs an extra step to do bluray. One thing I would love to see in ripbot:
For the apple TV, it accepts 2 audio tracks, a AAC track and an ac3 track. This technically isn't supported by the mp4 standard wrapper, but the apple tv plays them back. I believe the ac3 track needs to be the second audio track. Any chance this could be added? Seems silly to have a apple tv preset without supporting the apple tv's ability to do ac3. |
21st March 2009, 23:58 | #4543 | Link |
thanks for your help Atak_Snajpera and b66pak. Finally found the reason for the problem. The chapters in the original .mkv were messed up, but for some reason this doesn't affect any player during playback (guess we have to thank Haali for this) so I presumed that the file was ok and therefore the reencoding had to be the problem.
I'm sorry for taking up your time and trying to blame the problem to ripbot. Won't happen again. And a little anecdote at the end: While the file with the messed up chapters plays just fine with Haali's Splitter in video players as mentioned before, mkv2vfr.exe (by Haali too) created an .avi without the very first chapter |
22nd March 2009, 03:32 | #4544 | Link |
Is it possible to add the subtitles that are soft subbed on a mkv video when converting by a way other than having to extract the subtitles first from the mkv file? Doesn't seem you can select the subs inside the mkv file when converting.
22nd March 2009, 09:11 | #4546 | Link | |
22nd March 2009, 16:41 | #4547 | Link |
Hi Atak,
Troubleshooting with the end of conversion, with the version 1.13.3. tsmuxer.exe error here the code error Code:
Signature du problème*: Nom d’événement de problème: BEX Nom de l’application: tsMuxeR.exe Version de l’application: 0.0.0.0 Horodatage de l'application: 499ae43f Nom du module par défaut: tsMuxeR.exe Version du module par défaut: 0.0.0.0 Horodateur du module par défaut: 499ae43f Décalage de l’exception: 000507e5 Code de l’exception: c000000d Données d’exception: 00000000 Version du système: 6.0.6001.2.1.0.256.1 Identificateur de paramètres régionaux: 3084 Information supplémentaire n°*1: d1c5 Information supplémentaire n°*2: 0f3da3e86590f7440003f670a61bbfac Information supplémentaire n°*3: 09ae Information supplémentaire n°*4: d9b2334c197b461dda5e2083dd1a9bf1 Lire notre déclaration de confidentialité*: http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x040c |
23rd March 2009, 18:54 | #4550 | Link |
First Atak your're a god! Thx for this powerfull tool!
But I have a simple problem in converting my blu-ray-movie. I've installed all the tools, and ripbots exits the process without any error. But the final movie has no sound. VLC tells me, that their is no soundtrack. I think, the solution is only one click in ffdshow or in the other tools, but dont know where to click in the settings. Can you Atak oder somebody help me? Perhaps theire is a install guide for the tools ffdshow, Haali Media Splitter and Avisynth in this forum? Thx |
23rd March 2009, 18:57 | #4551 | Link |
Show me log. Logs\jobx_log.txt
23rd March 2009, 19:16 | #4552 | Link |
G:\>"C:\Dokumente und Einstellungen\The Dude\Desktop\Blu-Ray-Bearbeitung\RipBot264v1.13.3\tools\x264\x264.exe" "G:\temp\RipBot264temp\job1\job1.avs" --crf 22 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-adapt 1 --weightb --direct auto --subme 7 --trellis 1 --partitions all --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --output "G:\temp\RipBot264temp\video.264" avis [info]: 1920x1080 @ 23.98 fps (181200 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 PHADD SSE4.1 Cache64 Slow_mod4_stack x264 [info]: profile High, level 4.0 x264 [info]: slice I:2203 Avg QP:14.86 size:145806 x264 [info]: slice P:91991 Avg QP:18.57 size: 68907 x264 [info]: slice B:87006 Avg QP:21.55 size: 23797 x264 [info]: consecutive B-frames: 17.5% 51.6% 4.7% 26.3% x264 [info]: mb I I16..4: 26.2% 66.7% 7.1% x264 [info]: mb P I16..4: 1.0% 13.7% 0.6% P16..4: 33.6% 13.4% 7.9% 0.1% 0.2% skip:29.6% x264 [info]: mb B I16..4: 0.1% 1.3% 0.0% B16..8: 37.4% 0.8% 1.3% direct: 4.7% skip:54.4% L0:39.2% L1:46.8% BI:14.0% x264 [info]: 8x8 transform intra:86.5% inter:68.8% x264 [info]: direct mvs spatial:99.6% temporal:0.4% x264 [info]: ref P L0 70.0% 18.4% 11.6% x264 [info]: ref B L0 82.9% 17.1% x264 [info]: kb/s:9241.7 encoded 181200 frames, 9.84 fps, 9246.18 kb/s G:\>"C:\Dokumente und Einstellungen\The Dude\Desktop\Blu-Ray-Bearbeitung\RipBot264v1.13.3\tools\tsmuxer\tsmuxer.exe" "G:\temp\RipBot264temp\job1\tsmuxer.meta" "F:\00004.bluray" SmartLabs tsMuxeR. Version 1.8.18(b) http://www.smlabs.net Decoding H264 stream (track 1): Profile: High@4.0 Resolution: 1920:1080p Frame rate: 23.976 Decoding DTS stream (track 2): Bitrate: 1536Kbps Sample Rate: 48KHz Channels: 6 Processed 181200 video frames Creation of Blu-ray playlist Creation of Blu-ray stream info and seek index Muxing time: 4 min 45 sec ------------------------- Elapsed Time: 05h:11m:48s |
23rd March 2009, 19:37 | #4553 | Link | |
23rd March 2009, 22:34 | #4556 | Link |
AVCHD probs
@ATAK
What version TSmuxeR do you recommend using? Can we just upgrade to the newest versions as they come out? I've not been able to get a AVCHD disk to play on my Sony BDP-300. It does have the latest firmware. I'm not sure if it has anything to do with the MKV files I have being cropped to be non standard or what. It does reconize as an AVCHD disk but just sits there and won't play. Any help would be appreciated. |
23rd March 2009, 23:53 | #4557 | Link | |
25th March 2009, 12:32 | #4559 | Link |
@ Atak_Snajpera,
Do you have any plans to allow an option to incorporate neuron2's DGAVCIndexNV, DGMPGIndexNV, etc to RipBot264? I currently use the tools with RipBot264 by avs script, but if you have multiple files it often crashes CUVIDserver.exe (at least in my case). The other issue I have when I import an avs script is that I can't use the auto cropping feature. If you don't have plans to incorporate the tools as an option (which would be understandable), maybe someone else that reads this might be able to solve the minor issues I'm having when I use the tools with RipBot264. Neuron2's tools and your use of 64bit X264 really help in the speed dept. Thanks for all you hard work on RipBot264. |
25th March 2009, 12:42 | #4560 | Link |
Two main problems:
1) I have Ati card. To do tests I would have to run to friend living floor above. 2) These tools are not free. Since I have Ati card I see no reason to spend money for those apps.
