12th August 2009, 18:33 | #5501 | Link |
I use ffdshow r3013 with ffmpeg-mt
UPDATE: r3054 works as well
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 12th August 2009 at 20:16. |
14th August 2009, 04:34 | #5502 | Link |
Hi Guys,
Im having some trouble and Im hoping someone can tell me where im going wrong Im trying to convert some VC-1 stuff to H.264. The problem is the output files, instead of being ~8gb, are ending up ~700mb :-( Im selecting the lock output size (to the 8150 one), not cropping/resizing etc - the preview script is playing fine - there arnt any errors on screen. Here is the log: D:\>"C:\Program Files (x86)\RipBot264v1.14.2\tools\x264\x264_x86.exe" "D:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 10679 --stats "D:\temp\RipBot264temp\job1\job1.stats" --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-adapt 1 --weightb --direct auto --subme 7 --trellis 1 --partitions all --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --partitions none --subme 3 --me dia --output "D:\temp\RipBot264temp\video.264" avis [info]: 1920x1080 @ 23.98 fps (144614 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [info]: profile High, level 4.0 x264 [info]: slice I:580 Avg QP:13.98 size: 12629 x264 [info]: slice P:36442 Avg QP:13.97 size: 83 x264 [info]: slice B:107592 Avg QP:12.01 size: 71 x264 [info]: consecutive B-frames: 0.4% 0.0% 0.0% 99.6% x264 [info]: mb I I16..4: 98.8% 0.0% 1.2% x264 [info]: mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.0% 0.0% 0.0% 0.0% 0.0% skip:100.0% x264 [info]: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct: 0.0% skip:100.0% L0: 0.0% L1:100.0% BI: 0.0% x264 [info]: final ratefactor: -33.65 x264 [info]: 8x8 transform intra:0.0% inter:70.6% x264 [info]: direct mvs spatial:0.0% temporal:100.0% x264 [info]: coded y,uvDC,uvAC intra:0.8% 1.2% 1.2% inter:0.0% 0.0% 0.0% x264 [info]: kb/s:23.9 encoded 144614 frames, 59.92 fps, 27.34 kb/s D:\>"C:\Program Files (x86)\RipBot264v1.14.2\tools\x264\x264_x86.exe" "D:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 10679 --stats "D:\temp\RipBot264temp\job1\job1.stats" --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --mixed-refs --bframes 3 --b-adapt 1 --weightb --direct auto --subme 7 --trellis 1 --partitions all --8x8dct --me umh --threads auto --thread-input --progress --no-psnr --no-ssim --output "D:\temp\RipBot264temp\video.264" avis [info]: 1920x1080 @ 23.98 fps (144614 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 x264 [warning]: target: 10679.00 kbit/s, expected: 21.94 kbit/s, avg QP: 10.0000 x264 [warning]: try reducing target bitrate or reducing qp_min (currently 10) x264 [info]: profile High, level 4.0 x264 [info]: slice I:580 Avg QP:39.18 size: 6224 x264 [info]: slice P:36442 Avg QP:43.43 size: 2606 x264 [info]: slice B:107592 Avg QP:46.71 size: 1302 x264 [info]: consecutive B-frames: 0.4% 0.0% 0.0% 99.6% x264 [info]: mb I I16..4: 30.4% 69.1% 0.4% x264 [info]: mb P I16..4: 9.7% 4.8% 0.0% P16..4: 8.0% 0.2% 0.1% 0.0% 0.0% skip:77.2% x264 [info]: mb B I16..4: 0.8% 0.6% 0.0% B16..8: 13.4% 0.0% 0.0% direct: 0.0% skip:85.1% L0:44.0% L1:55.8% BI: 0.2% x264 [info]: 8x8 transform intra:38.4% inter:97.7% x264 [info]: direct mvs spatial:0.0% temporal:100.0% x264 [info]: coded y,uvDC,uvAC intra:2.8% 16.5% 0.8% inter:0.3% 1.1% 0.0% x264 [info]: ref P L0 63.8% 19.8% 16.4% x264 [info]: ref B L0 78.6% 21.4% x264 [info]: kb/s:316.5 encoded 144614 frames, 26.61 fps, 317.19 kb/s D:\>"C:\Program Files (x86)\RipBot264v1.14.2\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\xxx\Desktop\file (VC-1).mkv" --default-duration 0:23.976fps -d 0 -A -S "D:\temp\RipBot264temp\video.264" --language 0:eng --sync 0:0 -a 0 -D -S "D:\temp\RipBot264temp\job1\audio.1.ac3" mkvmerge v2.9.0 ('Moanin'') built on May 22 2009 17:46:23 'D:\temp\RipBot264temp\video.264': Using the AVC/h.264 ES demultiplexer. 'D:\temp\RipBot264temp\job1\audio.1.ac3': Using the AC3 demultiplexer. 'D:\temp\RipBot264temp\video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1920/1080. 'D:\temp\RipBot264temp\video.264' track 0: Using the MPEG-4 part 10 ES video output module. 'D:\temp\RipBot264temp\job1\audio.1.ac3' track 0: Using the AC3 output module. The file 'C:\Users\xxx\Desktop\file (VC-1).mkv' has been opened for writing. The cue entries (the index) are being written... Muxing took 16 seconds. ------------------------- Elapsed Time: 02h:11m:11s Im using windows 7, 64bit.. Cheers, Bitey |
14th August 2009, 05:03 | #5503 | Link | |
x264 developer
14th August 2009, 21:27 | #5507 | Link |
i had the same problem a while ago. i uninstalled all videotools, filters, codecs and such (e.g. also the Combined Community Codec Pack), then reinstalled only the stuff required for ripbot. the problem never occured again since then.
16th August 2009, 00:38 | #5509 | Link |
I have asked this before the answer has been no
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
16th August 2009, 08:31 | #5510 | Link |
Too bad, this app runs faster and produces higher quality rips
than it's competitors. (HDConverttoX, Staxrip...) The only thing missing is to add multiple Audiotracks and maybe a Statusbar during Analysis (at least in Win 7 it tooks some time, so youre not sure if the app freezes or just works in the background...) Maybe it is possible to add the ML audio support in the next release, would make the app perfect! greetz... |
16th August 2009, 13:41 | #5512 | Link | |
Cheers, Bitey |
16th August 2009, 20:48 | #5513 | Link |
whenever input file contains vbr mp3 audio track, the output file always has out of sync problem. what should i do? should i use EnsureVBRMP3Sync() as megui does for every audio track?
thanks. Last edited by m0nkie; 16th August 2009 at 20:56. |
18th August 2009, 07:14 | #5515 | Link |
I've got subtitle sync issue while encoding an anime
But just the ED karaoke, other than that it's sync'd Sync issue shown in preview too (before encoding) Already check'd the subtitle of source video and tried using other encoder, it's sync'd perfectly.. Any solution Really need RipBot because it's very less time consuming Last edited by holy_reds; 18th August 2009 at 09:12. |
18th August 2009, 07:55 | #5518 | Link | |
ffx264/ffhevc author
18th August 2009, 08:51 | #5520 | Link |
Revealing the site has nothing to do with this. The forum rules explicitly prohibit any discussions or help on content which you don't hold the rights to and is illegally downloaded. I suggest you go read the rules before getting banned or this whole very useful program development and support thread getting closed because of you!
