5th July 2015, 13:06 | #13701 | Link | |
I can post the ipconfig/all info later, OK. Ummm, I actually haven't got a router, it's just an 8 port 100/1000Mb hub that "join's" everything. Some of my PC's "do" have more than 1 onboard NIC, but on the Windows 10 PC, I have disabled the Realtek, and left the Intel enabled. I was using another Windows 8.1 PC with DE, with no problem, so it's either a Windows 10 thing, or the mobo...haven't used this PC for a while. I generally only use 1 PC, with all DE servers running within the same PC...works well, makes a huge difference. I just need to have the hub powered up. I will have a better look tomorrow. Cheers |
5th July 2015, 13:13 | #13702 | Link | |
Also check what you have in those sections. I have router (IPs are associated with MAC adresses) so I do not have to fill in anything.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th July 2015 at 13:16. |
5th July 2015, 14:01 | #13703 | Link | |
No, I do not have device (router) which would control ip association for connected devices (PCs). I just slightly change the IP addresses, on the other PC's, seems to work fine for "normal" networking. So on the PC in question, the settings are :- IP is 192.168.0.3 Subnet 255.255.255.0 No Gateway Preferred DNS 208.67.222.222 Alt DNS 208.67.220.220 Last edited by burt123; 5th July 2015 at 14:03. |
6th July 2015, 05:26 | #13704 | Link |
Hi Atak,
So I checked ipconfig/all, and found a Tunnel TAP adaptor that had DHCP enabled, which generated that IP of 192.55.233.2, so I had several failed attempts at deleting/disabling it, but with no success, then I noticed an Intel TAP entry in Device Manager, it was a hidden device, so I uninstalled that, rebooted, it all came back, so then I switched from the onboard Intel NIC, to the Realtek NIC, and now everything is working. I have a theory on what might have happened, but I would need to do a fresh clean install on Windows 10, and I can't be bothered, as the final release is "just around the corner". I really appreciate your input & suggestions, it lead me in the right direction, to get it working. I am currently DE'ing with the PC I couldn't connect to, yesterday. Many thanks |
6th July 2015, 09:20 | #13705 | Link |
Ripbot stops after first or second pass
This is the first time I have a problem with Ripbot.
It seems only to affect this movie: The man with the iron fists uncut version region B. 5053083037550 Ripbot stops after first or second pass. No error message. HDD > Blu-ray > mkv. Windows 8.1 X64 / Ripbot 1.18.3 If I roll back to 1.18.1, itīs working again. Same settings. |
6th July 2015, 14:00 | #13706 | Link | |
6th July 2015, 15:06 | #13708 | Link |
I need to know what avisynth exactly knows about opened script. Number of frames reported by decoder,fps and so on. MediaInfo will never give me that accurate information.
Gathering information on my machine takes few seconds. No idea why this takes minutes on your side.
7th July 2015, 00:18 | #13709 | Link |
Registered Loser
Again, avs2avi.exe is scanning the entire Audio file. In my latest Movie (Dances with Wolves) - that .dts file is 8.5gb. It took about 3 minutes to scan that on an SSD. MediaInfo scans it in a half a second. Crop the movie, and it scans the whole audio file again (3 more minutes)
Yes, it's lightning fast with SD content, but I rarely am ever dealing with that. On Blu-rays, every audio file is lossless - many are 4gb+ in size. Avs2Avi is over 10 years old. Guess I'll see if I can find something other than mediaInfo which might do the job. Maybe ffprobe? I know it can do similar functions as well. Detailed: Start AVS2AVI - 0m Log outputs to console - 1m 5 sec File scans again - 1m 40sec Total time 2min 45sec Total throughput is 24k IOPS. My SSD is going absolutely nuts. Edit: It's NicAudio.dll which is causing the file scanning. DirectshowSource on the DTS works but shows an incorrect length (large negative number) in info.txt uNicAudio.dll behaves the same as NicAudio.dll Tried NicAudio.dll version 2.06, same behavior. Directshowsource on the source MKV works. Obviously not ideal. Last edited by agressiv; 7th July 2015 at 01:56. Reason: More detail |
7th July 2015, 07:10 | #13710 | Link |
Lossless compressed audio has a variable bitrate. If it's not in an container that supplies total duration (like mkv) it has to be scanned to get the correct duration (and AviSynth needs duration at script loading time, cannot be changed dynamically, I think).
But does NicAudio even do DTS-HD/TrueHD? I don't know if it's the best choice source filter in this case. |
7th July 2015, 10:27 | #13711 | Link |
nicaudio does not see hd part. Only core is decoded.
7th July 2015, 13:45 | #13713 | Link | |
Error
Tnx for your help.
7th July 2015, 14:09 | #13714 | Link | |
Hi, Atak,
I have a strange problem - I upgraded recently from 1.18.1 to 1.18.3 and now encoding of this audio to aac (MOV from camera) Quote:
I tried to copy only new ripbot.exe into old directory - the problem is here. Old ripbot.exe with new stuff - encoded_aac is created, output mkv is here. Any help, please? |
7th July 2015, 17:00 | #13715 | Link |
see log file for details.
7th July 2015, 19:17 | #13716 | Link | |
strangely, there is not any note about audio...
7th July 2015, 19:24 | #13717 | Link |
have you tried this file http://forum.doom9.org/showthread.ph...09#post1729209
7th July 2015, 19:49 | #13719 | Link |
run manually job1_EncodeAudio1.cmd and show output.
7th July 2015, 20:24 | #13720 | Link | ||
here you are
