23rd March 2016, 19:58 | #14321 | Link |
Yes it is odd, just trying it the other way round with the X99 as the client and running more than one on it doesn't seem to make much difference. I'll have to test again with the older PC as the client and see what happens. Could it of just been that the FPS happened to ramp up when I tried it as the content of the video changed, thus purely coincidence?
26th March 2016, 01:47 | #14322 | Link |
Hello, RipBot developer, how much You can add distributed server at maximum?
Log time ago ive seen ure using 4 DE, then 8DE, and now 10DE. Is that possible to make it unlimited DE server? I imagine that i can add more and more DE server, this will speedup encoding, especially for the next codec HEVC |
26th March 2016, 10:17 | #14323 | Link | |
29th March 2016, 16:39 | #14324 | Link |
I just recently used Ripbot to convert Insurgent and I'm having an issue. The file I created was a .mp4. When I try and play the movie it takes about 30 seconds for it to begin play, and when it does I only get sound, no video. If I simply rename the file to a .mkv it will play just fine. Rename back to .mp4 and same issue. Takes a while to play and no video. What could be the problem? I could use some help please.
29th March 2016, 17:49 | #14325 | Link |
Are you using MPC-HC player?
30th March 2016, 05:45 | #14326 | Link |
Socket Error
I have been getting Socket Errors on a 2nd PC I use in DE in Ripbot. The log in EncodingServer first says "Socket Error 10060" and after clicking ON within EncodingClient the server logs return "Socket Error 10038". As well as an "Access violation" error.
I tried deleting and re-established the Firewall rules and disabling Windows Firewall all together to no effect. Using v1.19.3 on both PCs. https://www.dropbox.com/s/2fmi3do605...43.18.png?dl=0 |
30th March 2016, 13:14 | #14330 | Link |
Bad idea. Use something more advanced like MPC-HC.
30th March 2016, 13:34 | #14331 | Link | |
31st March 2016, 06:53 | #14332 | Link |
Are there any known issues with using OpenCL on integrated intel GPU's? I have a Core i7 6700 and with Intel 530 and whenever I enable OpenCL in the Ripbot options it comes up with this:
C:\>"C:\Program Files\Ripbot\RipBot264v1.19.2\tools\avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job105\job105.avs" -o - | "C:\Program Files\Ripbot\RipBot264v1.19.2\tools\x264\x264_x64.exe" --opencl --opencl-device 0 --crf 20 --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 197017 --sar 1:1 --level 4.1 --preset slow --tune film --aud --nal-hrd vbr --vbv-bufsize 62500 --vbv-maxrate 62500 --stdin y4m --output "C:\Temp\RipBot264temp\video.264" - y4m [info]: 1920x804p 1:1 @ 10000000/417083 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2 x264 [info]: OpenCL acceleration enabled with Intel(R) Corporation Intel(R) HD Graphics 530 x264 [info]: profile High, level 4.1 x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: OpenCL: Invalid value. x264 [error]: OpenCL: fatal error, aborting encode x264 [error]: x264_encoder_encode failed I tried installing the 2015 vc_redist mentioned a couple of pages ago but with no luck. |
31st March 2016, 09:56 | #14333 | Link | |
31st March 2016, 10:31 | #14334 | Link |
@fatpizza:
did you verify your opencl installation with a tool like "GPU Caps Viewer" or similar? I had a bad time some month ago finding the right drivers at Intel. The "normal" drivers did not support opencl. After some fiddling around and try and error, I finally got it working. and happily living ever after... |
31st March 2016, 13:17 | #14335 | Link | ||
31st March 2016, 16:40 | #14337 | Link | |
Socket Error (RESOLVED)
Thanks for the advice. I had forgotten I installed VirtualBox a while back. It installed its own virtual adapter, once disabled, everything worked fine. |
2nd April 2016, 15:42 | #14338 | Link |
I'm having an issue where when I encode with a locked sized at 23830 to fit on a BD-R disc it no longer will fit correctly. The encoded file size is almost always a little too large to fit on the disc when the job is complete. Ripbot has only been doing this when I upgraded to the newest 1.19.3 version. I believe I was on 1.18.3 before.
Any ideas? Thank you for the help in advance! Last edited by rekd0514; 2nd April 2016 at 15:55. |
2nd April 2016, 16:08 | #14339 | Link |
Just reduce target size to 23800 if you get too big file. Maybe newer x264 builds changed something in 2-pass mode.
